Eloisec93
Everything posted by Eloisec93
Yup this is why I'm asking for quotes on reconditioning 😊 Yup this is why I'm asking for quotes on reconditioning 😊
Hey So I've been having issues with my propella not engaging when in gear. Sometimes it works fine other times there is a delay. I had a mechanic come and look and he says I need to have the gearbox out and reconditioned. I have a hurth gearbox Model no. Zf 10 m Fitted on a vetus m4 engine I'm trying to get a quote for how much it will cost to compare it to getting a new gear box. Has anyone had this done before? Or have a contact number of where I need to send it off to to get a quote? Any help or information would be much appreciated I have someone who can take out and fit the gear box I just need info or contact to get a quote for reconditioning. Or alternatively what new gearbox would be recommended?
Hey I have a pressure release valve on my calorifyer with a pipe that goes to the engine bilge. It only leaks a drip every few seconds when the engine is running and heating up hot water in the calorifyer. I have replaced the pressure release valve but the same thing happens. Drip by drip it fills up my engine bilge as the engine is on. When the engine is off no dripping I don't really understand has anyone got any advice or suggestions? I have an expansion tank near the water tank and water pump. I know I have posted already but I wanted to post again with the information that I do have an expansion tank.
Using high powered magnets on a canal boat
Eloisec93 replied to Eloisec93's topic in General Boating
hey so I've recently installed two solar panals on my boat. The boat electrition who wired them in suggested I use high powered magnets on the mounts instead of drilling holes in the boat. Seems like a good idea to me but I just wanted to hear anyone else's thoughts is this going to affect the boat in any way? I have uploaded pictures of the magnets he suggested and a picture of how he did it on his own boat. -
how long does it take to heat hot water with the radiators off?
Is there a way I can just use the alde gas boiler for hot water only and not heating. I have a wood burner and prefer that for heat anyway
hey so we have just got our new boat (new second hand boat) She has an alde gas boiler for hot water and radiators. On our old boat we just has a gas boiler we turned it on full and a few seconds later we had hot water running through the taps. When we turn on the alde gas boiler on our new boat hot water doesn't come out. Am I supposed to leave it on to heat water? Also is there a way to have only hot water and not have the radiators come on as well? The whole system is a bit of an overkill for us as we prefer a simpler system. We are worried we are going to use so much gas if we have to leave it on for a certain amount of time to heat the water Thanks
So she is my third boat. She's second hand and made by sagar marine. She seemed to steer to the left at all speeds Compared to my old boat "millie fleur" my new boat seemed to have a mind of her own. Millie fleur did exactly what i wanted her to do. I'm going to see if i can access the ballast in the hull today. But yesterday I added two slabs of concrete to one side and she looks a little bit more balanced but its hard to tell. I'm not sure the pump out was empty when I got her yesterday as she was very smelly but it soon went after airing her out and letting her settle after being craned in. Water tank is full I will check Diesel today
hey I got my new boat road transported and craned in yesterday. I cruised her along the canal and moored up. As i was cruising I noticed she wasn't steering straight and kept veering off to the left. She was also listing towards the left as everything is built on one side and potentially the ballast has shifted in transportation. Could the list cause her to veer off on her own accord when steering straight? Or am I looking at a tiller problem.? She definitely felt like she had a mind of her own when cruising!
What kind of box? Our shower is like one of those hip bath types things There is a pump fitted in the plug and sucks the water out when switched on
Yes the water tank is at the front and is nearly empty which could be why she is leaning back a bit! There is about an inch of water in both inspection hatches. The only reason why I suspect the shower is because the surveyor said the bathroom was an amature fit out and we should re do it to stop the shower leaking. My water pump only comes on when I run the taps and isn't running all the time. I don't have a cabin bilge pump fitted I don't think. In the shower there is a switch that pumps the water out of the bottom of the shower but only from the shower it seems
Hello we have owed our boat Millie Fleur for just over a month now. I came home today in daylight for the first time (I work early to late hours) and noticed she was sitting slightly lower in the water at the back. I turned on the engine bilge and pumped out the rain water that had collected. But still she sat low in the water ? I then checked the inspection hatched inside the cabin one by our back door and one in our bathroom (also at the back of the boat). Both hatches are full of water ?. I want to get the water out but I don't know how. I guess I need to buy a water pump. Please can people recommend a good water pump? As I have no clue. Also any suggestions on what to do? I hope I'm not sinking and I suspect the water may be leaking from the shower when I have a shower?
We have a charge control/battery charger display by sterling power. This turns on when we hook up to the shore power to charge the batteries. It then beeps after about 10mins saying batteries over temp. We also have solar panels and a different display for the solar In the picture is the Stirling power display one Also I found the picture of the temperature sensor on the internet on the sterling power website https://sterling-power.com/search?type=product&q=Temperature+sensor
Oh yes well spotted! I don't know if mine is the same as that mine is a black and red wire with the metal ring. Perhaps mine isn't meant to sit underneath the battery and actually on the negative of the battery? I don't really know much about electrics only basic knowledge how will I know if it's the same as the picture???
I definitely think it's the heat sensor playing up. It's very annoying all I want to do is charge my new batteries and make sure they don't go under 12v ??? I've move the heat sensor completely away from the batteries and the charge controller is still saying over heating The heat sensor is just a wire with a metal bit on that sits underneath the battery (see picture) I'm gunna have a go at disconnecting all the batteries and reconnecting them properly. Or perhaps I need to fit a new temperature sensor. But I wouldn't really know where to start with that
No not hot to touch I just went and checked
Yes we have a heat sensor connector to the batteries that monitors the heat of the batteries and their outer casing. Both these temperatures show up on our battery charge controller The batteries are around +45degrees and the outer casing +22degrees when on charge
Hi We recently bought 3 new leisure batteries as the old ones were not holding any charge. We have plugged in to hook up to charge the batteries as they weren't even half full on our solar charge control. But every time we we plug in the hook up to the battery charger the battery charger beeps saying the batteries are over heating. Is it something we have done wrong? What is causing the batteries to over heat when on charge? What are the dangers of over heating batteries? We have a sterling power product battery charge controller And we have fitted 3 new leisure batteries from halfords Voltage: 12V with Capacity 115Ah im getting very stressed and worried because I don't want overheating batteries but also I don't want them to drop below 12v
Hi Tony I think your right! I have just researched the three stages of charging. Why do you think it may be to early for an optimum charge? Please can you explain? Sorry I am new to all of this and learning!
Hey guys So we fitted 3 brand new leisure batteries today as our others were not holding any charge and on the recent survey it was recommended we replace them. I replaced the batteries with 3 brand new leisure batteries from Halfords Voltage: 12V with Capacity 115Ah everything is working fine on the boat the solar charge control has a happy face with full batteries our other charge control was saying 78 mins absorpt wet open (see picture) I have no idea what this means and wondered if any one knew??? We are new to this boat and getting to know it. It may be a silly question but I'm curious to know what it means Thanks
Thank you so much this information is such a great help! I will pass it on to my mum ?
