Eloisec93
Content Count
26 -
Community Reputation
0 NeutralProfile Information
Gender
Female
Location
Bristol
Previous Fields
Occupation
Circus performer
Boat Name
Millie Fleur
Using high powered magnets on a canal boat
Eloisec93 replied to Eloisec93's topic in General Boating
hey so I've recently installed two solar panals on my boat. The boat electrition who wired them in suggested I use high powered magnets on the mounts instead of drilling holes in the boat. Seems like a good idea to me but I just wanted to hear anyone else's thoughts is this going to affect the boat in any way? I have uploaded pictures of the magnets he suggested and a picture of how he did it on his own boat. -
how long does it take to heat hot water with the radiators off?
Is there a way I can just use the alde gas boiler for hot water only and not heating. I have a wood burner and prefer that for heat anyway
hey so we have just got our new boat (new second hand boat) She has an alde gas boiler for hot water and radiators. On our old boat we just has a gas boiler we turned it on full and a few seconds later we had hot water running through the taps. When we turn on the alde gas boiler on our new boat hot water doesn't come out. Am I supposed to leave it on to heat water? Also is there a way to have only hot water and not have the radiators come on as well? The whole system is a bit of an overkill for us as we prefer a simpler system. We a
So she is my third boat. She's second hand and made by sagar marine. She seemed to steer to the left at all speeds Compared to my old boat "millie fleur" my new boat seemed to have a mind of her own. Millie fleur did exactly what i wanted her to do. I'm going to see if i can access the ballast in the hull today. But yesterday I added two slabs of concrete to one side and she looks a little bit more balanced but its hard to tell. I'm not sure the pump out was empty when I got her yesterday as she was very smelly but it soon went after airing her o
hey I got my new boat road transported and craned in yesterday. I cruised her along the canal and moored up. As i was cruising I noticed she wasn't steering straight and kept veering off to the left. She was also listing towards the left as everything is built on one side and potentially the ballast has shifted in transportation. Could the list cause her to veer off on her own accord when steering straight? Or am I looking at a tiller problem.? She definitely felt like she had a mind of her own when cruising!
She was built in 1990 45ft pat buckle semi trad narrowboat
What kind of box? Our shower is like one of those hip bath types things There is a pump fitted in the plug and sucks the water out when switched on
Yes the water tank is at the front and is nearly empty which could be why she is leaning back a bit! There is about an inch of water in both inspection hatches. The only reason why I suspect the shower is because the surveyor said the bathroom was an amature fit out and we should re do it to stop the shower leaking. My water pump only comes on when I run the taps and isn't running all the time. I don't have a cabin bilge pump fitted I don't think. In the shower there is a switch that pumps the water out of the bottom of the shower but only from the shower
Hello we have owed our boat Millie Fleur for just over a month now. I came home today in daylight for the first time (I work early to late hours) and noticed she was sitting slightly lower in the water at the back. I turned on the engine bilge and pumped out the rain water that had collected. But still she sat low in the water 🤔 I then checked the inspection hatched inside the cabin one by our back door and one in our bathroom (also at the back of the boat). Both hatches are full of water 😱. I want to get the water out but I don't know how. I guess I need to buy
We have a charge control/battery charger display by sterling power. This turns on when we hook up to the shore power to charge the batteries. It then beeps after about 10mins saying batteries over temp. We also have solar panels and a different display for the solar In the picture is the Stirling power display one Also I found the picture of the temperature sensor on the internet on the sterling power website https://sterling-power.com/search?type=product&q=Temperature+sensor
Oh yes well spotted! I don't know if mine is the same as that mine is a black and red wire with the metal ring. Perhaps mine isn't meant to sit underneath the battery and actually on the negative of the battery? I don't really know much about electrics only basic knowledge how will I know if it's the same as the picture???
I definitely think it's the heat sensor playing up. It's very annoying all I want to do is charge my new batteries and make sure they don't go under 12v ??? I've move the heat sensor completely away from the batteries and the charge controller is still saying over heating The heat sensor is just a wire with a metal bit on that sits underneath the battery (see picture) I'm gunna have a go at disconnecting all the batteries and reconnecting them properly. Or perhaps I need to fit a new temperature sensor. But I wouldn't really know where to start with that
