I have a Webasto that today has developed the same fault. I haven’t used it since May. It started then stopped about 6 times this morning but now doesn’t even start. Voltage is 13.4 currently so not a power problem.
Update. I was unable to resolve the issue for 3 weeks so I bit the bullet and bought a new pump (with strainer). Just prior to installing the pump I washed my hands. The hot tap spluttered and the problem resolved itself. Must’ve been a bubble of air in the system somewhere!!! Now I have a spare pump ?
yep. Tried that. Spent a very long wet morning at Ellesmere services filling up and flushing.
so I need a non-return valve and a strainer in there between the pump and the tank in the section at the top of the photo. Also I have read that the accumulator pressure might not match the pump pressure which is between 1 bat and 1.7 bar on this model of pump
There’s also an accumulator on the calorifier
Hi. I ran completely out of water. When I refilled the tank, my pump now runs for 3 seconds with an interval of 5 seconds. There’s no leak anywhere in the system so I suspect it’s a pressure valve, the pressure on the accumulator or, most likely, the pump itself. Has anyone had the same problem and what was the solution?
Yes. I think I need to decide how many watts of panels I intend to have, taking into account possible expansion, first then choose the solar charger that will cope with that.
Yep. I have a bilge pump switch which allows me to turn the pump on as required. This also has a circuit breaker on the consumer board. But my bilge pump is wired from 2 sources, one of which appears to be directly from the starter battery and can be activated by a float. The float was being deceived by some stern gland grease that had gotten into the bilge causing the pump to run continuously and drain the battery. I have learned the lesson of keeping a tidy stern gland and bilge and the pump is now working as it should. Back to topic, I think I know what is required to connect my solar panels to the battery bank. I’m going to get a dual charge controller. Happy days.
The bilge pump is connected to the battery before the isolator switch so the only way to turn it off is to disconnect the battery. Many boats have this arrangement apparently. Although being connected to the starter rather than the leisure battery appears to be uncommon
Unfortunately my automatic bilge pump is wired to the starter battery before the cutoff switches and my battery was rinsed by the pump when it developed a fault so for peace of mind I prefer the starter battery to be charged also
So, upon further research, my options are to either have have one charge controller with a VSR in the line or 2 charge controllers from 2 separate solar arrays or a single dual battery solar charge controller from a single solar array. Am I over complicating this?
Voltage Sensitive Relay. It is wired so as to connect the sets of batteries together when the system voltage is raised to a charging voltage, ie when some source of charging is active (solar, shore powered battery charger, alternator etc).
I have a charger for when I connect to shoreline power so I guess that must have a VSR. I wonder if it would be possible to feed the solar charge through that?
That makes more sense. Especially as starter batteries don’t like to be run flat and leisure batteries tolerate this better. I wondered why that wasn’t the case when I discovered what had rinsed my starter battery. But then I think Liverpool Boats did funny things when it was built in 2004 ?
Thanks for the reply, Tony. What’s a VSR? Currently the batteries are charged by two alternators on the beta 38. Edit. I just googled VSR and found that it splits the charge. I don’t think I have this as I have 2 alternators. So I guess that some charge controllers can split the charge. Otherwise I could have 2 sets of panels with 2 charge controllers; one to charge the starter and one to charge the leisure
Hi. Please can you advise? I am looking to install a couple of solar panels to charge my battery bank. I have 3 leisure batteries and 1 starter. I want to charge both the leisure batteries and the starter. Can I do this from one positive and one neutral output from the charge controller or do I need two; one output to the leisure and one to the starter?
