Just called sleeman and asked for a quote, I need three items headset switch water temp switch and oil pressure switch. all items for everything are cheap elsewhere. why are the charging 5x the amount of standard prices.
I need advice can I buy cheap alternatives. I don't have the lister gauges, and I don't know what to do?
when I got the boat it was filled with rain water, after it dried run fine. but during lockdown my float failed drained the batter and filled with rain water again, it was over the starter motor so that area would of been under water with a lose nut
that gear end scares me, I really don't have the money for a mechanic
there is a friend of mine in the boat club a lot more mechanically minded reading over the manual for me, I did suspect it was 58 and 53 that area, just praying it will soak down that far
ive been told wd isn't a real penetrating oil, been advised to get something else
Just wanted to update you all, its not worked. where the pin and nut go, its seized most likely why it sheered the pin.
does any one know a way to access it.
at the moment im just filling it with wd and tomorrow im buying penetrating oil, fingeres crossed it will free it self.
unfortunately tightening the bolt done nothing, so ive disconnected it and appears there should be a pin. mating the two marts together but I still cant find the part number in the master parts manual.
will do, and are even upload photos to this post. the lack of the lexicon doesn't help. week of hard works has really taken it out of me, so day off tomorrow but on Wednesday I will get back to you guys, been a great help. fingers crossed I can get to play on it for three weeks before the clubs lift out. then its hull painting and cabin time, things I know more about.
Ive got it thank you, does seem to be the issue, wasn't mating the spindle correctly. the relief I feel now knowing its a spindle. I can understand that. if tightening hasn't worked, removing it and mounting it again will
