Hi, I have a Morco 61B boiler that is fed with water via a Shurflow 30 PSI (2 bar) diaphragm pump. The boiler requires a minimum of 1 Bar before the gas valve opens and it will start to heat any water fed to it and I have a 2 bar pump feeding it.
When the boiler ignites and starts to heat the water, the pump starts to cycle (turn on/turn off rapidly), this causes the water to go cold then hot as the pressure to the boiler drops in and out and the boiler keeps igniting/shutting down. I cannot get a steady flow of hot water. If I open the cold tap, the pump stops cycling and the pressure and flow of water is good, except the water is now cold/luke warm.
If I turn down the the temperature dial on the boiler, i can get a constant supply of warm water to the sink, but not the shower, and at a very slow flow rate. If I try to increase the temperature dial on the boiler, the pumps starts to cycle again and the boiler cuts out and reignites with each cycle. The problem seems to relate to increasing the temperature on the boiler, i can get cold and luke warm water with ease :)
I have checked the flow rate and it is 6 litres per minute as specified on the Morco website.
Does anyone have any pointers? I have been looking at fitting a FIAMMA A20 Expansion Tank - Accumulator Tank.
Thank you (off to bed now but will see any replies on Sunday)
