Everything posted by Paolo Reale
Engine rattle when engaging forward drive
Paolo Reale replied to Paolo Reale's topic in Boat Building & Maintenance
Thanks for these suggestions. I'll certainly check as much as I can. Couple of quick questions - I don't have a stern gland with a stuffing box - it takes silicone grease and is totally try, I forget its name. Anyway thing in particular to look at there? Also do you feel I'm probably wrong about the bearing issue despite seeing the propeller shaft flex while engaging forward? Is this normal? -
When engaging forward drive just before the gear is in I have a 2 second rattle. Once the gear is in and revs are up, the rattle stops. I don't think it's the drive plate as I've had this before and its a different sound. However I've watched the propeller shaft while engaging the gear and it seems to flex before the gear is fully engaged ( and while I can hear the rattle) and then runs normally. The odd thing is that it never rattles when engaging reverse. I'm wondering if there's a bearing issue in the shaft coupling resulting in the flexing shaft and coinciding rattle? Any thoughts on this would be greatly appreciated.
Had a serious gearbox leak on my PRM150 a month ago. It turned out to be the O-ring rubber seal where the gearbox cable lever is attached - quite common I understand. However ever since the gearbox has continued to "weep" oil and on big lock days can lose 100ml of oil. I check and replace oil daily. Are there any thoughts on using gear box additives which are supposed to seal up small leaks like this? Or might I need to have the the O-ring seal done again?
Thanks for this Slim. Yes, I'm no engineer but if I can order a new cooler I'll have a go at it myself. Any thoughts about how to drain the skin tank effectively?
Useful ideas Ex Brummie. I' ll do as you suggest as there is no rise in level which you'd expect with water getting in. It's keel cooled. What relevance is this?
All this has been really helpful - thanks for the offer Tracy - it'll take a month to get back to Nantwich and I do know an excellent engineer who'll sort it for me - do you think I'll make it with regular oil changes for this length of time?
In the short term - I'm in London and moor in Nantwich - would changing the gear box oil every few days get me relatively safely to a place where I could get some help?
Yes, having read other posts, a gearbox oil cooler leak seemed the most likely. Is this major, will the water damage the gearbox?
Hi Just changed the gearbox oil in my PRM150. The oil that I drained was a bit milky. Just checked the new oil now a week later and it too is a bit milky. I know this indicates water ingress but I've no idea where from or if it's a serious issue or something I can sort when I'm back in my marina in a month or so. Any suggestions or thoughts very welcome.
Thanks Tony, I'll try that.
Thanks for all your thoughts, I'll certainly check the throttle cable as there does seem to be quite a distance between idle and engaging the gear. Just changed the gear box oil. Just to check - this should be right at the maximum mark of the gear stick - unlike the engine oil level which is half way between max and minimum? Quick addition question - how to adjust the level of idle revs?
I have a PRM 150 driving an Izuzu 38. As I engage the forward gear there's quite a rattle. With an increase in revs and the gear engaged the rattle stops. There's no rattle when I engage reverse. I was convinced it was my drive plate but when I asked my marina engineers to look at it they assured me it wasn't the drive plate, although they didn't say exactly what the rattle would be. It doesn't affect the performance of the engine and even at tick over there's no rattle which I know is characteristic of a drive plate problem. Any thoughts or suggestions would be much appreciated.
Are there any practical reasons for not painting a narrow boat roof black? Hope someone might be able to help. Thanks
Hi, Just had 2 days of relentless rain here in Cheshire and at 4am, noticed that the foot of the bed was wet. Further inspection this morning shows a steady drip from the roof on one side of the boat. Nothing major, but still a little concerned. Very difficult to tell internally where the source is as I have oak ply. Looking externally there's nothing obvious. I've checked the mushroom vents and they're fine. I know it's difficult to comment, but does anyone have any suggestions in terms of how to identify the source, without ripping out the interior? Any thoughts and suggestions welcome. Thanks
Perfect. You've confirmed what l thought and having messed around with it for a while, I've managed to set it for the next few days. Thanks for your help. Cheers
Hi, Wondered if anyone recognises this control unit. It's wired in to the calorifier and so l assume it's a timer for hot water when hooked up in a marina, but I'm not sure. If it is this, how would I find out how it works? Hope someone can help. Cheers.
Thanks for that Dave.
Thanks Dave. When you say inspect the holes for 'water tightness', in practise, what does this mean? Checking internally for leaks? Hope this makes sense.
New to boat ownership and have a pump out toilet. I understand they have vents that have filters. Is this right and where might the vents be? It's a 2004: Liverpool Boats built trad. Hope you can help. Thanks.
Cruising to Birmingham in the next day or two from the Stratford canal and wondered if anyone has any advice re. Mooring and good things to do. We wondered if there were moorings by the botanical gardens? Any suggestions would be really helpful. Thanks
Thanks Boater Sam for the prompt response. I was hoping someone would confirm that it's fine. It was cheap, £6.95 for a small tube, but because you use so little in these stern glands, it should last for ages. Cheers
Hi, Managed to find a plumbers merchant near to where we're moored in Worcester. Asking for silicone grease, they said that Osma Silicone Lubricant was the only thing they had. It's a small 50g tube, so I bought it. Having made the mistake of putting K99 grease into my stern gland as this feed will explain, I thought I'd ask if anyone has heard of this and whether it's right for my stern gland. Hope someone can help. Cheers.
Thanks. I won't try that now, God knows what she'd do! but I had a feeling just seeing if the nuts were tight by hand might not be enough. I'll let you know if the silicone works Cheers.
Because of the recent posts about engine mountings, I decided I couldn't wait until the morning and have just checked them, much to the annoyance of my wife who's reading on bed, just feet from the engine! Anyway, the mountings appear really solid, so at least that's one thing I don't have to worry about. Thanks again to all who responded to my post.
Great. Thanks again, really sound advice.
