Twoboxes
Gender
Location
Macclesfield
Occupation
Self employed
Boat Name
Inspired by nature
Boat Location
Macclesfield
Twoboxes's Achievements
Gongoozler (1/12)
0
Starter time relay noisy engine won't start
Twoboxes replied to Twoboxes's topic in Boat Building & Maintenance
OK the problem has been solved with replacing starter battery ! Thanks everyone for all your great advice! 👍 Great news! It's now working. They tested the starter battery by putting in a good fully charge one. It was the battery, showed a good voltage but died on cranking. So new battery now getting installed. Big thankyou to all your fantastic advice and time. Big thankyou from the lady boat owner. Thank you. -
Hi, thanks. Yer no one came out ! I'm not at boat, but a friend is using another battery from a neighbour boater. It's a fully charged starter battery so hopefully see if the battery is the problem. -
Currently can't do, not at boat, but all being well tomorrow a marine electrician is now coming out. -
Extra info...The buzzer does sound when turning the key to heat plugs, but turning key to start position nothing happens, then when turning key back off the relay starts creating a whinning horrible sound. -
Done. Batteries all checked and OK. -
Twoboxes started following REQUIRED Buffalo Board and Starter time relay noisy engine won't start
Can anyone advise please? The kubota v1903 engine won't start. When you turn the ignition the starter relay at rear of ignition panel makes a noisy whining sound, doesn't sound good. Red Lights on panel intermittent on off as you turn key. On turning key to start there is nothing but the whiring noise as you then turn the key into off position. Batteries are all OK. Voltage checked. What i can see, doesn't seem to be any lose wires. It just suddenly stopped working, there been no faults up till it stopped working. Starter has been working fine e every time. Anyone know what the fault is? Could it be the relay be the fault or something else. Where can I get hold very quickly of the relay unit? Relay info... Denso 12v starter timer relay 061700 - 3770. Thanks
Has anyone got any off cuts for sale? I'm moored up on the macc and require a piece of Buffalo Board for engine bay. 2ft 10" x 4ft 3.5" 18mm thickness Thanks
Beta 38 require alternative domestic alternator
Twoboxes replied to Twoboxes's topic in Boat Equipment
Thanks for your links and advice. -
Sounds good... Just need to find a place to do it ASAP -
I'm on the Macc... Marple end -
Thanks Jen. -
All new to me as a new boater.. Learning as I go along. Thanks for the info. -
Looking for part number. 11201883 but can't find it online. -
I have a iskara aak 3119 14v 70amp.... It's not working now. Where can I get replacement please? Thanks
