Tim Read
Patron Donate to Canal World
  • Content Count
    3
Community Reputation
0 Neutral
    Woking
Previous Fields
  • Occupation
    Engineer
  • Boat Name
    TBC
  • Boat Location
    TBC
  1. I found a refractometer good for checking coolant ( see attached ). But I wondering if I don't need to add some sort of biocide. Some signs of growth in the header tank and I needed to bleed most of the radiators ( air - or CO2/CH4 from bugs ? ). Anyone put a biocide in their heating system ?
  2. Sadly the loops are on the tank. I should perhaps have added a photo from further back which shows the tank more clearly.
  3. Hi, I have an ex-Black Prince probuild narrowboat which has the weed hatch apparently through the fuel tank. The hatch is secured by a bar across two steel loops welded to the tank. One of these loops has failed ( maybe my fault over tightening weed hatch - appears to be ductile failure of one loop, see picture ). It seems to me that I will need a new loop welded in, but this is on top of the diesel tank. I believe the diesel tank is integral with the boats structure - so does this mean the diesel tank need to be drained first and inerted before welding ? Does it then require pressure testing again ? Any advice on practice here ?
