Thanks for the ever so quick reply rusty. In answer to your questions:
1. Burning wood (fence posts and smallish seasoned logs) and smokeless coal from Aldi. 90% of the wood is dry, if I have a wet log I bung it on when the fires going well.
2. Lighting with firelighters and kindling, always start with dry wood and add coal after
3. Fairly sure the chimney is clear, unless I have the door open I never get any smoke coming back into the boat and all the smoke and heat seems to be escaping through the chimney. I not sure what you mean by baffle plate. No boiler attached.
4. When lighting/getting the fire going, I have the door open or all airwash/vents open. Once going, I have the top vents open if it's mostly wood at the start of the night, then switch to opening the bottom vents when it's mostly coal. Unfortunately, I also have a gap at the top of the glass which I'm in the process of fixing with new brackets.
5. No radiators etc, it's just for ambient heat
Edit to add: no.4, meant say I keep the bottom vent open when burning mostly coal, not mostly cold!
