galaxyranger
Posts posted by galaxyranger
Yes. The cable attached to the spade connection goes to the warning lamp and ignition.
When I got sparx it was from the large spade connection next to the warning lightcable.connection.
I checked with a multimeter with the cables in 5heir current location at the battery terminals whilst the engine was running and the reading didn't go up at all.
I will cracking on tommorow
Thanx
the red cable with the blck tape goes to the positive on the battery , i am pretty sure the other end is attached to the B+ terminal, but i didn't get a reading from that terminal but got sparks from the three spade connecters, this is the live feed no.
thanx for input, if i swap the connection over and its wrong , everthing will be ok or will there be sparks
cheers
I measured the terminals at W and B+ and got a reading of zero and from the spade terminal I got sparx and shat myself.
Does this mean the live is from the spade connection. The pully belt is tight
I have just returned from an eventfull trip to Ely with my partner and the kids, Everything was fine untill we ran out of battery pwer in the wild fens.
I went to start the engine only to discover that the television switched off and the engine wouldn't turn over, I thought this was strange as the leisure battery and starter battery are on
seperate systems, I checked the voltage on boyh battrys , they were both the same 11.54, this again I thought was strange, this emplys both batterys are connected as one and
the split charge relay was permanently on. I limped back to ely , I replaced the switch and charged the battery only to discover that I am not getting a charge from the alternator, the alternator is new so I am hoping that I have wired it up wrong.
alternator part no 382-08919
it has terminals W or M
B+
3 spade connections
at the moment the exciter cable from the ignition goes to the spade connection and the charge to my battery is from B+, is this correct,
I think i have the connections the wrong way round.
thanx in advance
It's fixed.
I adjusted the cable to the gearbox. I noticed that the cable was pulling the lever
a long way over whilst in reverse but not that much in forward so I adjusted the toggle on the lever.I shall get her moved then apply the changes to the oil
Many thanxs
- 1
The dipstick was indeed stuck. There was too much oil in the reduction box. I have emptied some out. Slighthe creamy Ness on surface. When engine is stopped the prop is engaged.
I have to leave my mooring by this weekend. If I could get away with changing oil after I move to my new spot . My priority is to move
Thanx for input
Nothing like a bit of drama. A quick cuppa then start her up
Gear differential EP80/90 GL-5 is what I put in. Gona have a cuppa then have a look at prop shaft and levers
I popped up to halfords the other day to get some oil . What it suggestsays in the manual. They didn't have any but suggested I use the gear oil they have.
Tommorow I shall go to Wilcot to get the correct oI'll. Drain the oil and replace
I don't know the exact oil I bought . I shall go to the boat in the morning and find out.
Thanx for the input
I also thouight the reduction box dipstick was stuck, but it pulles out and then won't come any further also i cant see any marks on it, i suppose if it was stuck I wouldnt see the marks anyway. As far as the oil in the gearbox, i have just topped it up and not taken any out, would you suggest I let some oil out and check it?
could I have put to much oil in the gearbox or too much or not enough in the reduction box,
thanx for you time
I have a lister SR2 with hydraulic gear box.The gearbox was engaged in forward so I topped up the gearbox. I also put oil in what I believe to be the reduction box . I couldn't find a dipstick on the reduction box . Just a plunger. Similar to a dipstick but doesn't come out.
Now the reverse and neutral engage but not forward.
I put oil where the tall brass bolt is on the reduction box.should I have done this?.
Any advice.
Regards
Galaxy ranget
alternator wiring question
The yellow is a plastic crimp. The plate it touches is the B+ spade connection. I was going to put a female spade connection on that cable and try it in the large spade connection. I am a bit confused. Nothing out of the ordinary. Shall report back with info in while
Cheers
