Hi Guy, thanks for all of your help, but I am getting confused here.
I will wire the earth and neutral into the neutral position on the plug that goes into the generator - I understand this.
Now: Do I also wire the earth and neutral together at the end that I plug into the boat? (Where you would plug in the shoreline if hooked up whilst in the marina).
Also: Do I, (or don't I), earth the genny to the boat via its floating earth? If yes, then I will connect this earth wire to the earth stud on the hull that the inverters earth is fixed to
As I am a mechanical engineer and not an electrician, (but no a little bit about electricity), is it possible for yes / no answers only.
Again, thaks for all your help on this
