Hi there,
I've got a problem with my BMC 2.2 diesel engine that is giving me no end of trouble - any knowledge or advice would be much appreciated.
Basically, the engine starts fine with the normal amount of smoke which dies down after a short while. The boat runs nicely, doesn't hunt or miss and will run for over an hour whilst moored up either just on idle or revving the engine during the process.
The problem occurs when I go up river. After about 10 minutes of cruising at a slow speed the revs drop . If I push the throttle forward then the revs pick up again but after a while they drop again. This happens repeatedly until the throttle is fully open but the engine is only doing perhaps 1000 rpm. The engine will then stall and not restart. After about 10 mins the engine starts and all seems fine but again it will do the same after another short run up the river. At no point is the engine overheating and is maintaining about 60 degrees when warmed up.
So far I've done the following.
Replaced fuel pump and all filters.
Emptied and cleaned tank and put in fresh diesel.
Cleaned air filter.
Replaced fuel pipe on inlet side.
Checked and cleaned tank vent (and tried with fuel filler open)
Checked for diesel bug.
Bled (several times) filters, injection pump and injectors.
I'm really stuck on what it could be.
Any suggestions?
Philip
