Barge Maria
About Barge Maria
  • Birthday 27/10/1960
Contact Methods
  • Skype
    timhackett
    The boat is in Belgium
  • Occupation
    self employed
  • Boat Name
    Maria of Zaandam
  • Boat Location
    Belgium
Barge Maria's Achievements
Contributor
Contributor (4/12)
7
  1. That's where my mind is going Richard, thanks. I am willing to put my hands up and admit that I have made a mistake here.
  2. This is a bow thruster not a main engine folks. Yes it is only used for short bursts. No there is no significant voltage drop as the cable runs are very short and very thick.
  3. Hi all I would value some guidance from those forumites that are familiar with battery technology I have just had fitted to my 106 year old Dutch barge an electric bowthruster, 24 volt, 20 hp. Yes, we are all getting older! After some help and guidance from Mr Tony Brooks of this parish the wiring and fusing is all in place, and the unit is up and running. It is a Duco unit for anyone interested, Dutch, good quality, but little by way of technical input for the installation.....luckily the boatyard new how to weld it in! Anyway, in my design for the batteries, I took the view that semi tractions would be the way to go in order to give capacity for long bursts of thrust (this i is running the risk of turning into a Carry On script....) so I bought 4 Yuasa batteries of 6 volts and 225 amp hours, wired in series. They are the same ubnits as our old friends the Trojan T105 but are a bit cheaper. Up and running and the thrust is good, but a bit weaker than I expected. Also noticeable is a distinct warming of the battery terminals after a 3 or 4 second burst. The current is between 500 and 600 amps based on the fusing suggested by both Duco and Tony B. Cables are not really warm, but batt terminal are. I am now thinking that I made a bit of a boo-boo and should have used truck starter batteries with a CCA of c.1000 and capacity of c.180 A/hrs or so, wired in series to give 24 volts. Would I be right in thinking that the semi tractions are not up to providing c.600 amps for such a purpose? I can easily change, and use the Yuasa batts for another purpose in the domestic battery bankl, but before I spend again I would value thoughts. Thanks for reading this far................... Tim
  4. I use Vactan a lot on the barge and generally have no issues. You do need to wash off prior to application to remove salt residue from the rust. I am intrigued that you do not known what your product is called yet you know the suppliers. If you don't know what it's called how can you be sure you are using it properly? Summit not right here.
  5. Pennie, a lot of the DIY sheds do this now so when you're moored it might be worth a walk or cycle. B & Q especially. Good luck. Tim
  9. I think you mean Tayna batteries, although they may have an employee called Tanya!!
  10. Excellent. Thanks very much. I'll give them a call and explain what's happened. Appreciated mate.
  11. Thanks Richard.I'll have a closer look and gently have a go. It happened yesterday but due to other matters I wasn't able to investigate as much as I wanted to, hence the posting today. It would be a shame to scrap it as its part of the original set and you can't get them now, natch!
  12. In the course of cutting a hole in the dashboard of the barge to fit a new gizmo I have noticed that the needle has fallen off the engine temperature gauge. I think it was the vibration from the mulit-tool that caused it, sadly. The needle is still under the glass and I can see it. This VDO gauge is part of the original Scania engine panel and I would like to save it if possible. Does anyone have any experience of firms that would renovate older gauges like these? My (initial and rushed) Google searches seem to take me to places that want to sell me new dials, which are a different size so necessitate more bodgery! Or is it easy to get the glass off and re-glue the needle (it looks as though it was just delicately glued onto the spindle cup that connects to the mechanism). I'd be grateful for any ideas that people may have. Thanks in anticipation. Tim
  13. BOAT is an acronym for "bring out another thousand"!
  14. I concur Blackrose....we're not on opposite sides of this argument.
