yabasayo
Everything posted by yabasayo
Save yourself a lot of potential issues and cost and walk away. Also overplating side plates raises the centre of gravity of the boat and reduces stability. You will be able to find a boat in better condition.
Either slag inclusion in poor quality steel plate (very common) or SRBs, or both. Sulphate reducing bacteria occurs in low oxygen stagnant environments, and produces hydrogen sulphide which attacks iron and steel. Slag inclusion can lead to the formation of small galvanic cells due to the proximity of different materials in the steel. These in turn can give rise to galvanic corrosion and pitting. Galvanic corrosion can also be cause by faulty electrical equipment on the boat. On the other hand it could just be a poorly painted area which has rusted a bit more than the surrounding material.
Positioning Ballast for Stability
yabasayo replied to grahame r's topic in Boat Building & Maintenance
As a retired naval architect and marine engineer I'll give it one last try. In this case, the mass moment of inertia (which I presume is what you are now talking about) is a resistance of the boat to radial acceleration. In other words it is a component of the speed at which the boat rolls and recovers, but not the extent to which it rolls, for given force at a given vertical distance from the axis of rotation. This is complicated by the fact that a certain amount of water also moves with the boat effectively adding to the mass. The amount a boat heels when loaded to one side or other of the centre of buoyancy, effectively the boat's centre line, depends totally on the Righting Moment. End of conversation. -
Quoting basic applied mechanics is not dimensional analysis. Can you explain how your incomplete statement proves anything. You apparently do not understand that in the case under discussion, mass refers to the centre of mass of the whole boat and whatever it contains. To make it simple, if you have a 10 metre pole with a 1 kg weight at each end, the centre of mass is half way along the pole ie 5 m from each end. If your pole is 20m long with a weight a 1kg weight each end, the centre of mass is still half way along the pole. So if the equal weights at each end of the imaginary pole represent the ballast, you can see that both weights combined can be said to act through a point half way along the pole. (if you can't accept that then I give up) The boat rotates around the centre of buoyancy (which itself moves as the boat lists). Length here is the horizontal distance between the combined centre of mass and the centre of bouyancy. -
The only way to "make it slower to tilt" is to increase the Righting Moment. -
Your response does indeed make me think of a dumbell What you call the 'moment of inertia' is for a floating vessel, the Righting Moment, and is expressed in tonne metres. So to claim that "it wouldn't affect the righting moment, but would make it less tender" is a contradiction and an impossibility. 'Tenderness' is the manifestation of the Righting Moment and nothing else. -
Sorry old chap but there is some unnecessary confusion here. Given that everything else is constant (fixed), Inertia is directly proportional to mass (of the whole displacement, not just the ballast) Therefore, yes, by adding ballast you are increasing the inertia slightly. However, as discussed earlier, the whole mass can be considered to act through a single point. So moving the ballast around while maintaining zero list and the required trim, ie moving it symmetrically around the current centre of gravity, alters nothing. -
I believe it makes no difference. The hull shape is obviously fixed so all you can do with ballast is alter the centre of mass of the boat ie given that you don't want any angle of heel you can only move the centre of mass vertically. The centre of mass is a combination of the the weight of the structure and everything in it, plus the ballast you are adding and acts through a single point. If for example you add 1 kg of ballast at an equal distance from the centreline on each opposite side of the boat, the centre of mass of the combined 2 kg is on the centreline of the boat. -
Buying a new build from a start up company??
yabasayo replied to Boating Newbie's topic in Boat Building & Maintenance
I personally wouldn't consider paying them anything until the boat is complete and ready for delivery. If theirs is a viable business they should be able to borrow the money from their own bank. -
Not an exact science. Erosion rate of the anode is not linear and depends on its surface area and condition. The anode would be far less effective when it reaches year 10 of your example than it was when new. For those reasons anodes should be replaced when they have lost around 60% of their mass.
diesel tank Welding on top of fuel tank
yabasayo replied to Tim Read's topic in Boat Building & Maintenance
Fill the tank to the brim (up the breather) before welding. Have a foam extinguisher handy just in case you penetrate the tank whilst welding. Never weld on a empty tank. -
Sounds like you're nearly there. I'm surprised you can get 2.48kw from solar panels though. You must have something like 20m2 of panels. Presumably you've cut your prop down on a lathe ? If so you must have some pretty horrible blade profiles. Once settled on an optimum size you should get an increase in performance by buying a new prop.
Hull Blackening, the latest recomendations?
yabasayo replied to nipper's topic in Boat Building & Maintenance
Shot blast, hot zinc spray then epoxy - then forget for 10 years or more. -
This makes sense to me. I have drilled quite a few holes in my boat (not the baseplate I must add ) and over my life time have drilled a lot of holes in steel and have often felt I go through hard, soft and crunchy bits. Only last week I was drilling some holes in the boat and after a couple of easy ones the drill bit suddenly jumped and snapped, and I know it was a really good bit because I got a whole packet of them for £3 at Screwfix. ................Dave Both above correct in my view. That's why you should have a certificate of origin and quality for steel supplied for a new boat build. See thread on Steel quality and origin in build blog.
Guess what - you have reduced the prop area by about 30% and the rpm has increased by about 30% ie from 900 to 1200 rpm. I think you said the motor should run at 1650 rpm. On that basis you need to reduce the prop area by about another 25% or down to about 14 inches diameter to get your desired full load rpm. As I pointed to in post #41, your prop was overloading your motor by about 100%. Reducing the prop area by a total of 50% or so fixes that.
There is obviously a question over the mechanical reliability of this ship in bad weather. However another question is why did a cruise ship on a non essential voyage sail into this weather in the first place ? The ship's master should have the final say on that, but no doubt under huge pressure from the accountants in the company as a delay would have a significant cost in terms of several thousand delayed passengers.
According to Lloyds List, seas were up to 15 metres. No chance of launching lifeboats/rafts in anything like that. Even in calm water, an emergency evacuation into lifeboats is statistically hazardous with fatalities likely. Evacuation by helicopter is always preferred if logistically possible. Reduction of p.o.b. prior to a possible grounding on a rocky lee shore was the logical course of action. This vessel is diesel electric with four diesels and two electric propulsion motors. Suggestions in some reports that the violent vessel motions could have resulted in contaminated fuel, also that cooling intakes were drawing in air so resulting in overheating. The engineers on board did a splendid job in getting the ship going again. Speaking as an ex passenger liner chief engineer and offshore installation O.I.M.
GRP hulls absorb water and should be out of the water as much as possible (ideally every winter) to give them a chance to dry out. If the hull is pre about 1985 it is likely to be fabricated with orthopthalic polyester resins which are less waterproof. From around the early 1980s the more waterproof isopthalic polyester resins were used and recently vinylester which is the best and most expensive. So the older the GRP boat the less waterproof and most likely to absorb water. The main risk associated with water absorption is osmosis (boat pox) which can cause anything from cosmetic blistering through to structural failure in the worst case. Osmosis is more likely to occur in warm fresh water than in cold salt water. In summary, it is always advisable to allow a GRP boat to dry out whenever possible.
The first technically correct post on this subject. ie you need a prop which can absorb the rated continuous output power of the motor through a combination of diameter and pitch which suits a slow, heavy displacement boat. The figures given by the OP suggest that his current prop is overloading the motor by approx 100 % - which is why it gets hot.
Are you assuming the berth owner is accurately reporting the situation ? Could be the boat owner is not at fault. Similarly, the berth owner should sort the issue out and should not be charging you if you cant use the berth.
Precisely. That is a nonsense statement. Also someone is getting confused using USA units rather than the metric system.
Most small seagoing boats are GRP so they wouldn't fit a steel tube.
Possibly not. However it is more likely that soft protective coating in the blade tip area has been eroded leaving bare metal to quietly corrode away unseen. It takes a lot of high velocity water over a substantial period to erode steel.
The bow thruster tube is effectively part of the hull and should be the same thickness as the hull. Would you be happy with hull thickness of 2.5mm ? Loss of thruster tube material is much more likely to be from corrosion than erosion. As unseen area typically not adequately protected by paint or anode. It is also possible that thruster tube is of a different grade steel than the hull. There may be some galvanic corrosion going on. Thrusters can be very useful, especially if you are in a tight marina berth, and should not be dismissed simply on macho grounds. No doubt there similar 'sissy' comments were to be heard when the flushing toilet replaced the bucket.
The bow thruster tube is effectively part of the hull and should be the same thickness as the hull. Would you be happy with hull thickness of 2.5mm ? Loss of thruster tube material is much more likely to be from corrosion than erosion. As unseen area typically not adequately protected by paint or anode. It is also possible that thruster tube is of a different grade steel than the hull. There may be some galvanic corrosion going on. Thrusters can be very useful, especially if you are in a tight marina berth, and should not be dismissed simply on macho grounds. No doubt similar 'sissy' comments were to be heard when the flushing toilet replaced the bucket.
