klgilfillan
Everything posted by klgilfillan
Ok. Again, many thanks for replies and detailed advice, Alan and Tony Slim, no need...8mm works
Thanks very much for replies. M8 machine screw ( :^) ) fits. Jonathan and Tony, do you unscrew the machine screw every so often to drain water?
Hi all, I've been told by my boat safety inspector that I need to replace the plastic drain plug on my fuel filter with a metal one. The filter is a Lister 751-18100 and the thread of the plastic plug seems to be about 7.5mm. The smallest metal replacement plug I can find is 9mm. I have looked up a replacement filter that comes with a metal plug (e.g. Delphi) but the spin-on thread is 1.3mm smaller than the Lister filter spin-on thread. Has anyone else had difficulties solving the metal fuel filter drain plug problem? Any suggestions?
Hi all, many thanks for advice. What we did in the end was not pretty but it will hopefully work. The guy I'm working with was not happy with trying to force the battens to bend by putting rods underneath them. He wanted to cut curved battens with a jigsaw. Because I reckoned that would be really time-consuming (I'm on a budget), we decided instead to cut the battens into 200mm sections. I have existing wooden battens screwed into the crosswise steel battens, which are 25mm deep and 10mm wide. So we screwed the 200mm sections into the existing wooden battens and also stuck them to the ceiling and the existing battens with sikaflex. We filled in any small gaps between sections with more sikaflex. The existing wooden battens are in decent condition so I think it'll be ok. Hope no one tells me I've made a disastrous mistake. It looks pretty solid. I tried notching two battens to help them bend (small notches - only about 1.5mm) but one split on a knot when I bent it against the ceiling and the other one split on one of the notches. RW Davis told me that if you have time you can weight them and soak them for a month in the canal before bending them.
Yeah, that's an option I've been thinking about. Am worried that if I run four lengthwise battens, then, with my crosswise battens, I will have to chop the kingspan up into little chunks and lose a lot of insulating value.
Ok, thanks all. Also, just to be clear, I'm bending them on the 38mm side, to put up 40mm kingspan. (So hope that seems doable to people).
(I'm gonna reserve steaming them for last resort just because it might be time-consuming).
Ok, thanks a lot for replies. So, if I'm struggling to get them to bend (later today when I have someone here with bigger muscles than me), is cutting small notches toward the centre of the batten an option? Or will it cause them to split/eventually degrade? (What do you call the steel battens running crosswise on the ceiling?)
Hi all, I've had a look to find techniques for bending ceiling battens but don't have a clear picture yet. My transport options are limited so have got my battens from B&Q. They're 38mm x 25mm. I have crosswise steel battens on the ceiling of the boat at 500mm intervals. So far, my understanding is: Drill holes through steel batten and matching holes through wooden batten and brute force the batten to bend until you can screw it in. Or, dampen/soak the batten in some way (not sure with what) Or, cut small notches into the ceiling-side side of the batten to help it bend. Also, do people agree that sikaflex is good enough for attaching battens (even to the ceiling) or is screwing them in preferable? Thanks for any advice... Kerry
@Neil Smith Ok, thanks a lot, Neil. @David Mack Thanks very much, that helps. I had been told that all steel surfaces need to be covered with insulation but wanted confirmation. Interesting that even 2mm polystyrene will do it.
Oh, I see a bunch of people haven't used screws at all for battens, just stixall/sikaflex/marineflex.
Hi Neil, thanks very much for replying. Ok, so based on what you did, there is no need to attach celotex to floorboards. Just set the celotex sheets down on top of the ballast. Ok, that's a lot simpler. And on the steel channels on the hull sides...ok, I hadn't actually grasped that I needed to attach a horizontal batten down the length of the channels. So, you do that rather than loads of vertical battens, I'm guessing. I assume you screw it onto the steel channel? (And, as you say, put silicone between the steel and the horizontal batten). When I removed the existing lining, there was no horizontal batten attached to the channel.
Hi all, If anyone on this thread has the time to respond to a couple more questions about insulation.... To install 25mm celotex under the floor boards, I'm thinking to cut the celotex to fit between the floor supports, then temporarily lay some loose battens on top of the ballast as a raised surface to lay a strip of celotex on. Then apply the glue to the celotex, then lay a floor board on top. So the celotex would be a sort of 'tile' on the underside of each floorboard. And the floorboards would have a border with no celotex, which will rest on the steel floor supports. Floor supports themselves will just have floorboards resting on them with no insulation. Is this ok? Also, I have two steel horizontal 'runners' on the hull walls under the gunwale (don't know what term for these) - like lengths of square steel tubing with the bottom cut out. Have inserted pic. I would fit my celotex underneath these. But should I put shallow 12mm strips of celotex on the runners themselves so that I don't have bare steel against my lining? Should all steel surfaces be covered with some form of insulation?
@Neal Smith Ok thanks, yeah. The current weather has a....sobering... effect on one's insulation choices. Mildly terrifying to a newbie. Woke up on sunday to 0 degrees inside the boat. No doubt it's -5 right now. (I'm elsewhere). @system 4-50 Ha, ok, some debate about the drainage channel, then. @Tam & Di Yeah, thanks, I'm gonna do some major flake sweepage.
@ BWM Ok, right, I understand. Thanks very much for advice. @nb Innisfree Hm interesting point about the drainage channel. I didn't know about that. Will figure it into plans. Thanks.
Ok, thanks, I'll look into glass mineral wool. But does it come in slab form and also loose, stuffing, form? If one stuffs it in, without using adhesive, will it be airtight enough against the steel? Or do you use adhesive?
Ok, I'd better just do the ceiling then. I'll be getting a loan to cover it all anyway. I can actually see rust under some of the light fittings. So 50mm celotex on the ceiling, I'm guessing? Or is 25mm good enough (since it's more effective than polystyrene)? @BWM Ok thanks for advice about removing loose rust. Will make sure to do that.
Marginally superior to just sleeping under the stars, yeah. Marginally. Yeah, gonna do 25mm celotex above gunwale, 50mm below gunwale and I think maybe 12mm on the floor. Currently 25mm poly on the ceiling. Was maybe going to leave that for later - do you think ceiling is critical?
@stilllearning Ok, so it's just a case of monitoring things via hatches. Ok, thanks a lot for advice. (I'm finding it hard to keep this boat warm! 10mm polystyrene insulation above the gunwale right now. Also, brazier smokeless coal damn awkward to light).
Oh, the baseplate has been overplated, yes.
@Bee Many thanks for the reply. Yeah, interesting point. Someone here in the canal has advised putting floor hatches at intervals. I currently just have two hatches, both at the stern. I had to saw around rusted screws to get that floor board up. For my own understanding (apologies for revealing ignorance), once I have covered the steel of the hull with flag paint, celotex, silicone for joints, and ply lining, where will condensation condense? Is the hope that I will block the steel off from air such that there is no water vapour with access to it, and that the ply will not be cold enough for water vapour to condense? (I am referring to the walls of the hull now - but I'm guessing a lot of the moisture that caused that rust trickled down from condensation on the walls) @koukouvagia Again, thanks for reply. The surveyor did a full ultrasound and seemed confident. I don't have the survey with me but the readings were good. In general the baseplate was 10mm but I do remember that there were areas that were a bit thinner and i raised this with him but he said it was ok. Since it's not actually wet down there do you think I can just let that rust lie? Is it possible my poking will damage the overplating? I'm planning on laying insulation, new ply (on top of old ply) and vinyl down.
Ok, thanks for the reply. It's not currently wet at that spot. And other bilge areas further down are also dry. I have a fair bit of condensation and rust in places on the hull and gunwale but I'm thinking there's no actual ingress of water from outside. So I'm hoping it's old rust. By the sounds of it, you don't think that surface needs treating, right? Just keep it dry?
Hi all, Only my second-ish post here and I wondered whether anyone could offer any advice re. rust in the bilges. I bought my boat a couple of months ago and have made a bit of a start on insulating it with celotex. After stripping away some panelling and polystyrene I found a load of flaking rust where the hull meets the bilge. I took one of the flooring panels off and found a lot of flaking rust in there. (Have included pic). The boat has been overplated and a kind soul on the canal told me that that's encouraging...that possibly this is old rust. Does anyone have any opinion re the pic attached?
