Hi,
Can you name some of these good builders with photo's as when we looked at many here none used the materials you describe
Ray
edit
one we looked at pics of latest builds looks like untreated steel ?
http://www.tylerwilsonboats.com/index/#/brigantine/
Boat now coming up to 10 years old, Not got breakdown cover - done all my own services and up to date no breakdowns so how much have I in the kitty to cover any future problems ?
All insurance is just that you pay out and hope you never need it! and only works as more money comes in than is paid out
Ray
You would have? isolation valve at the end of run with the hose like
http://www.midlandchandlers.co.uk/store/category/1616/product/ah-116.aspx
connected to the cooker - not a domestic bayonet fitting
Ray
edit shown here
http://www.boatsafetyscheme.org/boat-examination/boats-with-gas/
Ray
Hi,
I use one of these
http://www.ebay.co.uk/itm/Very-Low-Pressure-Gauge-for-air-or-gas-63mm-0-100-mBar-1-4-BSP-Connection-/130905998059?hash=item1e7a9b02eb:g:adQAAOSwfcVUCyhZ
Ray
edit
This is the "official" version
http://www.ebay.co.uk/itm/Caravan-motorhome-boat-gas-leak-test-equipment-truma-soundness-tester-/291714545175?_trksid=p2141725.m3641.l6368
R.
I used a 5 position 4 pole 65AMP switch ---- GEN, OFF, SHORE, OFF, INV
Purchased off ebay for £20 bnib !!!! nearest Blue Sea equiv by the same manufacturer $413 yes $413
https://www.bluesea.com/products/9077/AC_Rotary_Switch_-_OFF_%2B_3_Positions_240V_AC_65A
Ray
Also measured the above today whilst there and its 11 ft wide,confirmed by the steerer of the museum trip boat as he was passing through as we measured the channel
Ray
We were at the lift bridge on Friday and apart from not seeing the cables which were off the pulleys the bridge is still in its fallen position and the closure notice is still in place, and when I last called Peel they did not have a date for the removal of the bridge
Talking to CART today at E/Port Marsh lock is to be completed before Christmas ??
However the wide lock at E/Port should be in operation within a couple of weeks
Ray
Blue Sea and others are made by Kraus & Naimer who sell through most electrical factors inc RS
There are always some on ebay with ratings up to and over 60 amps
They have a web site
Ray
Hi,
Mine came from here
http://www.cartwrightparts.com/parts/results.asp?code=21
Based in Altrincham, they cut mine to size and delivered but they are close to the canal at Broadheath
Ray
Either will tell you that you have a leak, however you still have to find the leak in the way you should have checked PRIOR to bubbling or manning on a new or modified system, ie spray on or sniffer
I use a low pressure gauge to test my van and boat, water filled manometers are ok but compromised by temperature etc over an extended test period
Each to etc
Ray
Auto batteries are almost all made standard sizes, if you look at most suppliers website they have a sizing tool
Result on one - as its ony 1335 cc any batts for a similar size diesel car would be fine
https://www.tayna.co.uk/All-SX-1.html?stype=cat&A-1=R246-276&A-2=R160-190&A-3=R205-235&A-5=IMG-4&A-6=IMG-10
Ray
Sat listening to radio TT all doors and windows open, 23 degrees inside 20 outside been the same for days, great here on the sunny Weaver
Not had the stove lit since March
Ray
Two new regs arrived lunchtime today, I had no problems with Clesse apart from a short delay in collecting my two "faulty" regs
They did not query the fact that the two were kept as spares or require any photos etc
Ray
