Not needed as stove conforms to latest bs and it's granite on top of 25mm board as sold by midland chandlers and the frame has the required lip all round
For info when the stove is in use I can hold my hand on the underside of the stove as it's fitted with a heat shield as standard
We like the way it turned out looks kind of right
Regards Ray
As above and find other users of the engine in cars tractors etc then cross match filters with premium brands and try motor factors or in my case ebay as my engine is common to loads of uses including isuzu trooper and vauxhall to name but two
I have just obtained 3 x WIX filters for the sum of £7.50 delivered from a well known factor as a stock clearance item
Ray
http://www.marinesurveysltd.co.uk/recreational_craft_directive_summary.htm
If new build is to be rcd complient then does the proposed engine meet the requirements of the directive
Otherwise you can do whatever floats or powers your boat till test time
http://www.ebay.co.uk/itm/Fuel-Shutoff-Solenoid-Replaces-8973295680-for-Isuzu-3LD1-3LD2-4LE1-3LB1-4LB1-/371774994363?hash=item568f8437bb:g:4FkAAOSwS7hXAlQj
As I stated earlier lots of offers out there one must fit
Ray
http://www.ebay.co.uk/itm/MV1-70-Shutoff-Solenoid-Switch-897183-0140-for-Hitachi-isuzu-engine-12V-/172043358712?hash=item280e9551f8:g:jdAAAOSw3KFWgK8k
Not hard to find lots out there
Ray
http://www.ebay.co.uk/itm/Reinforced-CLEAR-PVC-Braided-Hose-Water-Pipe-Flexible-Plastic-Food-Air-Oil-Tube-/140697124967?var=&hash=item20c233c067:m:mJIgq6SqLPBmGHFKpuvpfng
Ray
This is the actual yamaha genset over a grand and both the item in this discussion and the yam made in china
http://www.justgenerators.co.uk/yamaha-ef2000is-portable-generator.html#.WCiui-inyf0
Ray
http://www.worldpowerfaqs.com/en/categories/sound/37-how-do-i-convert-the-sound-power-lwa-into-the-average-sound-pressure-level-db-a-at-a-certain-distance
Ray
A guy moored at crook marina plasterer by trade used plasterboard throughout his fit out circa 2010
Boat still moored there on the offside moorings 12 x 60 ft perhaps someone knows how Wayne and his plasterboard are doing
Ray
Above shown on the Shurecal website
We have 40psi max (set by remote pressure switch) 4US GPM flow rate and the calorifier came fitted with a 4 BAR PRV
Works for us
Ray
Asking re
A good buillder will use blasted and primed plate for the hull and pickled and primed plate for the cabin. Both sorts of plate have had the mill scale removed.
Not a builder who claims to shotblast, however this would be good if protected immediately after blasting
Ray
