Gender
Sunnydays's Achievements
Explorer (2/12)
Thanks everyone .....I've just tried some wet & dry dipped in nail varnish remover. Seems to work. Will mask up portholes on the weekend and make a start. Would rather not lacquer them again but i might change my mind in due course....
Ok folks...all very helpful. My gut feeling is remove portholes and do a proper job or leave them as they are....
Can anyone help me re restoring various external brass items on our boat that have been laquered by the previous owner and are now very dark and almost black in areas. Wanted to start with the portholes but really dont want to go to all the hassle of removing them. Suggestion welcome.....
Puzzling Alternator bulb question?
Sunnydays replied to Sunnydays's topic in Boat Building & Maintenance
Now there's another challenge- 59 replies
- tacho
- alternator
(and 1 more)
Tagged with:
Thanks Chew - That might be the best option. For those of you concerned re the Glow plugs . As mentioned by others this particular Barrus doesn't require pre heating of glow plugs. The fact there is a warning lamp and the problem re the alternator light would suggest that this is the wrong panel for the engine spec, hence, as I've now learnt, some modifications needed. However I am pretty sure that this was the only option available with regardes repalcment option on my original 10 year old panel. Thanks again for all your help and interest.- 59 replies
- tacho
- alternator
(and 1 more)
Tagged with:
Yep....confirrmed. Barrus fit LED warning lights to their latest panels. My starter battery alternator is is around 10 years old and unlikely to work with the LED. Therefore I am going to exchange the LED lamp with the 2W filament type. (See pic) It won't match the others and I'll have to enlarge the hole from 8 to 13mm which is shame with a brand new item... but at least it will sort the problem. Thanks all for your input.- 59 replies
- tacho
- alternator
(and 1 more)
Tagged with:
Yep this is definately the latest panel and as far as i know they are the original alternators ....so 10 or more years old. Odd that the light from the liesure alternator goes out though? Will call Barrus tomorrow as suggested. Cheers again for your interest and help.- 59 replies
- tacho
- alternator
(and 1 more)
Tagged with:
I am pretty sure they are LED but then why would Barrus fit them to a new panel if they dont work with the alternator? I think I'll call them tomorrow. Abd if they are meant to run with a resistor then surely the guy sent out from the factory would have fitted one?- 59 replies
- tacho
- alternator
(and 1 more)
Tagged with:
Yep pretty sure . All 5 lights look like these...https://www.autoelectricsupplies.co.uk/mobile/product/711/category/57- 59 replies
- tacho
- alternator
(and 1 more)
Tagged with:
Thanks folks - I knew there would be an explanation. If its sorted the problem and not going to do any damage then I'll leave the filament bulb and holder in place . Does lead me to another question though.... how come the monitor light for larger alternator (leisure batteries) doesn't have the same problem?- 59 replies
- tacho
- alternator
(and 1 more)
Tagged with:
We've had our n/boat for just over a year and I've never had a lot of confidence in the original Barrus Shire 10 year old instrument panel which had a suspect ignition switch (lose, floopy key slot) and a tacho that never moved. So I replaced it with the latest version which I rather naively thought would be a straight swap - Same size, same block connecter etc. There was however some wiring mods needed one of which was due to now having individual battery/alternator lights for both the starter battery and the leisure batteries. I explained this to Barrus as they originally told me it would simple swap and they, all credit to them, sent a guy out to the marina within 48 hours to modify the block connector etc to get things connected. However he identified that the starter battery wasn't charging due to a faulty alternator which was the reason for the tacho problem and the battery/alternator light staying on. So it was frustrating that having fitted the newly refurbished alternator, both the above problems still continued. However following a suggestion from another marina colleague, I disconnected the LED bulb and holder from the back of the panel and reconnected to a traditional 12 volt/2w bulb and holder. On starting up....hey presto the light went out and the tacho needle sprung into life!. So....whilst some might say - well that's the problem sorted....I am puzzled by such things? Comments welcome but please bear in mind those of you who posses a far greater understanding of electrical matters that my knowledge is limited and I am merely keen to know whether by simply changing the bulb from an LED really has solved the problem and why the starter battery alternator would work with the LED? Thanks in advance
- 59 replies
- tacho
- alternator
(and 1 more)
Tagged with:
Yep i checked their website but couldn't see anything the same but i think these are 7 or 8 years old so things have moved on i guess. The size is 340x170 x 250 high so i think its a reasonably standard size although Ive been advised to go for gel batteries which may come in smaller dimensions . Anything else i need to know before ordering ??
My existing batteries are Alpha Uktra Plus 12v Type 140L. Does that mean anything to anyone?
All good advice. Thanks. Will vist the boat tomorrow. Remove dud battery. Leave other one in place for now with redundant cables temporarily removed. Next job....order 2 new batteries. I wont mention charging as theres rafts of information elsewhere but i might just ask....wheres the best place to buy batteries?
All very helpfull thank you. You are correct Alan ....with the humidifier being 240v and an electricity hook up there is no real need for the battery at all whilst in the marina. With hindsight I'll probably remove both for now, keep the better of the two as a spare and then replace in the spring with 2 2 ones. The boat is pretty well insulated woth little or no condensation and the reason we've got the dehumidifier is to stop Mrs Sunnydays worrying about the new expensive mattress and new Nabru sofa getting damp.....
