Everything posted by Wee Vee
Vactanned water tank - two years on
Wee Vee replied to Québec's topic in Boat Building & Maintenance
You're welcome Steve, glad it helped. Ours too was very brown and silty – I took buckets of crap out after scraping. It looked to me like ours had been bitumined once upon a time, but it had degraded to the point that water had ingressed behind. Glad I got shot of it. To clean up the water taste I added a carbon filter after the pump (so water tank–pump–filter). They're not big money in the grand scheme and I've yet to need to change the filter inside it. Have a look on Screwfix. You might want to add a one-way valve too, as I got flow-back initially, which caused the pump to cycle periodically. A valve between the filter housing and the pump sorted this out. Our water is now like Evian. Good luck! It's a shitty job but it's worth it. Vickie -
Just Vactan. -
Hello Steve! Re. our rusty old water tank: I knew the prep wouldn't be perfect without it being sandblasted, but I spent the best part of a week with a mix of power and hand tools. The pitted areas is where I struggled to get a really good result – the white mineral deposits were very difficult to remove completely. So in the end I decided to go just with Vactan (two coats), until I could assess how successful the prep had been. That was nearly nine months ago, and bar a few white streaks coming from the heavily mineralised areas, it's still looking pretty damn good. My intention is to drain again next time the boat is out for blacking and prep and touch up those areas which have failed. The only other gem of wisdom I can offer is that Vactan takes a very long time to cure below the waterline. I certainly wouldn't attempt a refurb outside of spring/summer if the boat's in the water. I used a heater to speed things up and that was early May. Hope that helps! Vickie PS. The casualties of this project were: 1 x headscarf 1 x tee shirt 1 x bra 1 x pair of trainers 1 x set of overalls The washing machine and a friend's bath It took over a week for the greasy rust coating to completely leave my skin. I looked like Donald Trump for quite a while. My advice would be to purchase a hazmat suit! PPS. 'Before' pics attached, I'll upload 'after' pics, in another reply. Here are the 'after' pics. -
Isn't it! Hi Mike, nice to hear from you. Yep, grit blasting could be interesting if stood in the tank – we'd need leather chaps. ? I wondered if a good prep followed by Vactan would be a solid base to paint on. I'm going to make a start and see how good I can get it. Doubting if Maxkote is any more cost effective than Jotun DW though, as 1L only covers approx 2sq m (I can't find coverage specs for Jotun). It's about £85 for a 2L tin so that would add up in a tank our size. As always when I start investigating anything boat-related, it feels like a can of worms has been opened. ? -
Hello all, Thought I'd share some info on a product I came across today, just in case you think it may be a top coat solution for our water tanks. Have a read, see what you think. https://www.maxkote.co.uk/shop/maxline-100-flexible-water-tank-lining/ I've ordered the Vactan, now to dig out the face mask, goggles and wire brush. ? -
Correct. I wouldn't use the other products you quoted in your earlier edit in a potable water tank. -
That is the smallest tin. -
I have read of some people using Jotun 2 part epoxy over the top. It comes in white and light grey. It's around £250 for a 15L tin – we'll have to start a syndicate. -
1L will cover approximately 8 – 9 sq m. So have a reccie at your tank dimensions. That sounds like a pig of a job. How will you get the rusty crap out when you're finished scraping? Perhaps a small sand blaster might be an easier solution, though I'm sure if you start a separate thread on it you'll get some better advice. -
That's just the news I needed, thanks Paul! We do drink our water, and my plan is to add a decent water filter inline once this refurb is completed. After 15 years of drinking from the current tank I think we're pretty hardy. Certainly no iron deficiencies on this boat anyhow. I can climb into our tank with relative ease so I should be able to do a really good prep job on the metalwork prior to painting the stuff on. The lads at the boatyard where we are have rigged me up a separate water tank so that I can bypass the boat tank for as long as the project requires. I'll be sure to check a weather forecast to get favourable conditions. One last thing – do you give it just one coat, or two? Thanks again for your help, really appreciate it. Vickie -
Hello Quebec! I'm dredging up a very old post of yours here because I'd be interested to know your thoughts on Vactan after the years have passed. I'm about to start the unenviable task of sorting out our rusty water tank in the bow and choosing the right product(s) seems to be a bit of a minefield. Your insight would be greatly appreciated. Thanks :) -
Glad it worked out for you Peter, sounds like it's made a lovely boat. As Mike said, because of our interior requirements being a little unusual, we're sure that stretching is the way to go. It also gives us the chance to increase the size of the galley & bathroom, which are a little pokey at present.
That's really useful info – thanks for sharing Peter.
That's really useful information, many thanks. Do you take on interior refurb work too?
Very similar to renovating a property I'm guessing – it's only once it's taken apart that the true extent of work can be appreciated. We'll bear this in mind, thanks Mike.
Hehe, thanks Neil! I'd hate to spoil the party, so I'll happily start you a new thread if you like. I'm actually impressed by how much science you were all applying.
Thanks for all the input on hull speed/water displacement calculations chaps, but this has rather moved away from my original enquiry. Our existing engine has been checked and will do the job, the extra ballast required will be calculated by the company who stretch the boat. We were more interested in people's experience of having their boats stretched – the pitfalls and things to look out for.
Thanks Mike! You're absolutely right - on all counts. We've done a lot (as you know) of searching and researching to get to this point. We feel it's the right path to take, now we need to make sure we understand and mitigate the potential pitfalls before going for it. Cheers again for your help and advice to date.
Love it! Though I'm utterly dizzy after that.
I can see why you chose not to – that all adds up! Our engine and gearbox have been checked and are powerful enough to cope with the 61' length. We were about to have a heating system plumbed on the 50', fed from a stove back boiler. So the extra radiator/installation shouldn't be too scary and the back boiler is plenty large enough to heat all rads. Hot water will continue to be fed from a Morco gas boiler. The beauty of stretching the existing is it gives us the opportunity to alter the layout, improve and increase the existing somewhat jaded facilities, which we were intending to do in the near future anyway. We can also add in a good sized office area – which is what the butty idea was for in our initial thinking. We both work from home so this bit is important. Many thanks for the recommendation, we'll follow that up.
We've looked at changing boats, but none were patch on the build quality and condition of our own. We've also looked at having a butty built, but after much investigation, we've decided that keeping our 'known quantity' and getting it lengthened is the way we'd like to proceed. There are only two canals we can't use with a 61' boat, the rest of the network is accessible (we're currently on the Lancaster at the most northern point ).
We've checked that the engine and gearbox will suffice, so all is well on that front thanks.
Thanks for your help both, we'll take a look at your suggestions.
Hi all! I'm new to this forum. I've joined to inquire about boat stretching as we're considering getting our narrowboat increased from 50' to 61'. We realise this makes a couple of canals off-limits – it's more the technical side that we are interested in – pitfalls and things we should be considering/asking first. We'd also appreciate any recommendations you might have for reputable companies to do the stretch work. Many thanks, Vickie
