Gender
Location
Potton, Bedfordshire
Interests
Boats, DIY, Writing
Occupation
Freelance writer (90% retired)
Boat Name
Seren
Boat Location
St Neots
philthane's Achievements
Gongoozler (1/12)
0
An update for those interested. The thermostat is in the cylinder head behind the manifold/heat exchanger. The manifold is held by both studs and screws so it has to slide off. Well I've slid it about 15mm, far enough to see the edge of a thermostat, but it won't go further because it collides with the starter solenoid. Next job is to figure out how to remove the solenoid, or the whole starter, when the screws are hidden by the manifold! With a car starter you can often crawl under to reach the screws. Not an option with a boat. After all this I really hope the thermostat is faulty!
- 5 replies
- perkins 100
- perama
(and 2 more)
Tagged with:
Nope. It's a GRP cruiser with a wet exhaust. I'll take the manifold off tomorrow.
- 5 replies
- perkins 100
- perama
(and 2 more)
Tagged with:
I can't be sure the gauge is accurate without buying another to check it, but certainly moves from cold to warmer depending on how hard the engine is working and the ambient temp, so it seems to be a good indicator even if the figures are not quite right. The thermostat certainly isn't where you'd expect. ie where the 'top hose' leaves the engine - because there isn't a top hose on this model. The water from the cylinder head runs straight into the manifold/heat exchanger internally, no external pipes at all. Latest advice from a Perkins dealer is that it's actually inside the heat exchanger body. I've looked for a way in but now I have an exploded diagram it seems that I have to remove the manifold/heat exchanger because the thermostat is fitted between the two. It makes sense in terms of the water flow, but is a pain to get at! Plan B is to fit an electrically operated valve in the 'bottom hose' returning cooled water to the pump with an electronic thermostat and a probe into the heater take-off. Once I get the engine up to temp I plan to fit a DIY calorifer, but there's no point if the engine runs cold!
- 5 replies
- perkins 100
- perama
(and 2 more)
Tagged with:
I think this is 40 years old, vintage enough? My engine is a Perkins 100 series with a Perama Marine conversion, indirect cooling. On a sunny day going against the current on a river the engine temp gets to 70°C. On a canal going slower to about 40°C and on a cold day it barely rises off the bottom of the dial. I assumed either a thermostat stuck open, or missing. I have a downloaded copy of the manual and there appear to be two variants, one with the thermostat behind the water pump, one with it in a housing. I can't see a housing so I took the pump off and there's nowhere behind it to fit a thermostat. Am I being stupid? Or is it possible a previous owner has built a Franken-engine using parts from both types so there is no place for a thermostat?
- 5 replies
- perkins 100
- perama
(and 2 more)
Tagged with:
THanks (again) Tony. I'll have a look at your site.
I'm no expert on diesel installations (my previous boat was home built with a petrol engine modded to run on paraffin!) but now I've got one I'm trying to understand it. I believe the normal fuel line set up has a return from the common rail or high-pressure pump back to the filter and then to the tank, the reasoning being that the fuel injectors react more quickly than a pump can so it's better to have excess pump capacity and return the excess fuel than to have the pressure drop when the injectors want more. My boat doesn't have any of that, just a single fuel line via the filter to the pump. I guess that because it's an old engine (Perkins 100 series) without any fancy ECU set up the injectors just squirt what the pump sends. Could also be that it was originally a petrol engined cruiser and the diesel was fitted by a cowboy, so I'd like your opinions. Is it OK as it is?
Sounds like a good plan.
- 8 replies
- 100 series
- diesel
(and 3 more)
Tagged with:
philthane changed their profile photo
Thanks Tony, I'll investigate more next time I'm onboard. Major jobs like taking the pump/thermostat housing off can wait until winter. There's certainly a cold return from the bottom of the heat exchanger to the pump, but not a 'top hose'. I guess since the header tank and heat exchanger is a single unit bolted onto the cyl head and incorporating the exhaust manifold the water flows internally, no hose needed. The only possible take-off points I've found are both on top of the pump housing. It's quite a small engine, often used to drive a generator, pump or refrigeration unit on a truck, so it won't ever have needed a take off for 'cab heating'. On a related matter, come winter should I close the 'sea cock' and try to drain the cooling system? The engine side can have anti-freeze like a car but the raw water side could freeze?
- 8 replies
- 100 series
- diesel
(and 3 more)
Tagged with:
I've just bought an old Trentcraft GRP cruiser with a Perkins 100 series 3 cyl diesel engine. It has a heat exchanger that incorporates the exhaust manifold and uses canal/river water to cool it (and spits it out of the exhaust). There's a separate clean water supply via a header tank on top of the heat exchanger and a conventional (ie car type) water pump driven by vee belt. There's a bottom hose from the heat exchanger to the water pump but whereas on (old) cars you get a thermostat housing on top of the cylinder head and a top hose to the rad on this there's nothing like that. I assume the flow is through the cylinder head straight into the heat exchanger. According to a downloaded manual (which isn't very clear) there should be a thermostat behind the water pump, but the temp gauge varies from about 40°C on a canal to 70°C going upstream on a river so I suspect the thermostat is either jammed or missing. I'll strip it down at the end of the year and check. There are two tapping points on top of the water pump, currently plugged with threaded blanking plugs. I would like to fit a small calorifer but can't figure our where to connect to. Are the two tapped holes on the pump usable as flow and return? If so which is which, is there some way to find out? Or should I take hot water from one of those (which?) and return to a tee in the bottom hose? Any advice anyone?
- 8 replies
- 100 series
- diesel
(and 3 more)
Tagged with:
