Darrenroberts
Member Map
Calendar
Community Map
Everything posted by Darrenroberts
SOUDAL GENIUS INSULATION FOAM
Darrenroberts replied to Darrenroberts's topic in Boat Building & Maintenance
Cheers black rose, av got two more portholes to install then I’ll foam all 4 in the same hit, just in case the tube gunks up. I’ll post the results shortly 👍🏻 -
Hi there, no it’s not the gun system it comes with a long tube attached av add a bit of a practice and it’s not to hard to build it up in thin layers but you do have to be carful not to blast to much in at once. Oh and it’s definitely worth masking off well too. -
I guess that’s why there is a layer of roofing felt in between the two layers? Well the cabin has been like that since the 80s and looks fine when I took a section of it out to have a look -
Ok great thanks I’ll continue researching To see if any of the others have better data sheets 👍🏻 -
Hi there the top half (gunnel to roof) has no insulation. It’s a 25mm tongue and groove cabin with some sort of ash felt wrap and then the steel cabin wrapped over the top. Screwfix sent been very helpful, and the technical sheet from soudal dosnt say open or closed. Only info is used for sound and thermal insulation plus gap filling. The sunlight shouldn’t be a problem as I’ll slot in a porthole liner effectively seeking the foam in darkness between the wood and steel. I just really want to make sure no condensation will form down there as it will be trapped. I’ll check if the silicone tho thanks. -
Hi guys u have a small gap all the way around my portholes where, by way of construction the steel cabin has been welded over the top of a timber cabin. Iam concerned about winter condensation running down the inside of the cabin sides and collecting on the gunnel between the wood and the steel. I want to insulate the porthole gap with a small amount spray foam and was wondering if SOUDAL GENIUS INSULATION FOAM from Screwfix would be suitable? Anybody used this stuff before? It’s says it’s useful for sound and thermal insulation, but I remember reading some where that boat spray foams need to be closed cell? Any help would be great thanks
Is the mark the visual pastiche of what it used to look like? I don’t see how altering or reducing a Boats length would mean it’s history has now ended, as it still exists. What happens to those vessels that get cut in half, made into two then get put back together or lengthend again using sympathetic techniques....dose said boat come back to life in terms of the history books? ??♂️...... or maybe i have a chip as I don’t know where the back of my boat is ?
I mean, I’ve seen a few well turned boats in images from the 80s/90s that are in stark contrast to how they are at present. I know 30 years is a significant amount of time but you would have thought at least some one at some point during that time might of had a quick whip round with a paint brush ?
Bingo that’s what I was after, thanks Tim ?
It’s crazzy how Boats deteriorate that badly in a relatively short space of time
Cheers Derek, yeh I didn’t find the BCN society website very useful. And the small day boat section of hnbc is pretty much the only photographic reference I’ve come across in one place. There has been verious discussions come up on here about specific BCN boats, but I thought it may be useful if eaither owners or other interested party’s began a discusssion in one place just like the historic boats for sale thread. There are loads out there but they seam to get over looked some what (Maybe due to lack of ID) but from my own experience I always get questions asked by passing boats almost in a daily basis and I don’t really have anything else to say other than, yeh she’s old ?
Hi all is there a thread specifically for BCN day boats/ joeys/ unknown but defiantly old Boats? I see a lot of the history threads discussing and celebrating the gauged, photograph and generally well documented motors and buttys out there ( and rightly so) but is there a specific place dedicated to the old gals still out there on the network.....in what ever form??
Towy for Conway ? no chance
Thanks for all the intel guys, iam als hearing reports of higher traffic and an impending water shortage down that way too ? all in all sounds like a risky trip to say the least, gunna head out to kings Langley and get some eyes on what’s going on there. Thanks again ?
So I am right in thinking it’s just Napton I have to worry about? Am trying to get hold of the Crt construction manager for that area for some more in depth local knowledge of that navigation, the website just says 7ft lol.....I guess maybe some one was been a bit Lazzy filling out all the spec info ?
She’s 50ft and 7ft 1 3/8” at the rear chine
Hi guys Iam trying to get to Braunston but iam sure you may have seen that a gate has fallen off at kings Langley! So iam thinking of heading on to the Thames and up the Oxford. Has the pinch point at Napton being fixed/ are there any others on that route I should be aware of? Thanks in advance ?
Hi there bit of a long shot here, but iam looking for any boat yard/ drydock job vacancies ideally in the Warwickshire area (but I am canal based so can locate to different areas) iam a apprenticed trained cabinet maker, with drydock and boat handling experience. I also have qualifications in Deisel engine manetence and experience with different types of boat fitting and maintence aspects. Just thought I’d post a message just in case anybody closer to those areas knows of any yards that are looking for somebody as google searches are so far limited. Thanks in advance, Darren.
Quite right apologies everyone....back to the boats for sale. Thanks again Pete
Right is see was Noah Hingley a carrier or company? We’ve discussed this before Pete, about Priston and I’ve still been going through any old photos I find of day boats with a magnifying glass for that illusive “107” but I carnt recall wether I actually sent you a photo of the two plates I have which where in the bow. Any way here they are. Do they look like s+l plates or have u seen any that look like this before?
Ah yes quite a while ago then
Do you recall the numbers of the two day boats on the hard standing there in the background, is the front one in s+l colours?
Did some one say dreamer?
That’s great Brilliant. Thanks again to all for your advice and leads.
