quovadis
    Australia
  • Occupation
    Retired
  • Boat Name
    The Lady Leah
  • Boat Location
    Hillingdon Canal Club
1,401 profile views
quovadis's Achievements
Explorer
Explorer (2/12)
0
  1. I have dealt with these guys before. A mechanic replaced an alternator for me. I did not think it was faulty, took it to them and they put it on the test bed for GBP10-00. I now have a spare alternator. When I say the BT need a service I'm being kind, its seized solid, I tried to remove brushes but could not. The boat has been sitting for 3 years due to no covid travel. So I'm getting her back to "ship shape", just fitted an extra 12 anodes, 2 pack resin hull coating, new leisure and BT battery, funny the starter battery is fine. New PRM gear box by Alex Fowler from Nantwich, brilliant mechanic. The moral of the story, especially the BT, "Use it or loose it". Will report the damage once I know
  2. I confess and plead guilty to not being a proper boater, more of a fair weather rookie from down under, even though we brought her down from Cheshire without incident (oh no my wife fell in the pound on number 18 of the Wolverhampton 21 and was rescued by 2 huge, I think polish guys who came from nowhere. This was in March at about 20:00 hrs FREEZING and dark. I'm sure this was reported in the Wolverhampton Mail (amazing scene on the 21 as woman was caught stripping off on the deck so all her wet clothes and thick coat stayed outside before her hot shower.))
  3. Progress today. Cleared the work space this morning, took out battery and removed other wiring. Off on my bicycle to Screwfix for a hex bit set, needed the 6mm Hex socket. Removed the solenoid cover and the control wire and then unscrewed the 4 hex screws. Lifted (struggled a bit, I'm not as young as I used to be). off she came. A service being needed, I took her via my trolley to, DBJ Auto Electricians in Uxbridge. Run by two elderly gentlemen who can rebuild any motor. They work in an overall but are dressed in collar and Tie. Delightful gentlemen and a pleasure to deal with in their old and cluttered shop. The refurbishment is going to be between GBP300 and GBP400, so I'm saving my pennies.
  4. Thank you. Just spoke to a most helpful engineer who advises that when removing the motor I must be careful with the Spline gear (I think he said this) as it needs to go back the same way. Im going to have a go but will probably end up blowing something.
  5. Thanks this is really helpful. Ok no tapping! It is a Vetus Bowthruster, does that help with the ratio and should I be able to turn it. A few years ago I had ir serviced. The mechanic took the motor out while it was in the water. I cant remember how he sealed it as the motor attachment (Allan key screws) is lower than the water line. Any idea how I can remove the motor and not flood the thruster bay.\?
  6. Thanks let me understand. when not in use should the propeller run free? If it is stuck is the engaging mechanism still engaged? There is a click. Now I know on the farm we used to tap the stater motor on the tractors to help them along, is the click indicating the thing is stuck or a power issue?
  7. Hi Just got over from Aus to get the boat back to running order. Spending a fortune on the upkeep after 3 years of idleness. Just replaced the dead bow thruster battery and all I get is a click when engaging it. Opened up the weed hatch and put my hand down onto the prop. It is stuck. If I remember correctly the prop used to rotate freely, Should the propeller be stuck as engaged or rotate freely?
  8. Thanks all to date, keep the comments coming as these things change all the time. Here is a "googlie" about 2.4 v 5GHz The primary differences between the 2.4 GHz and 5GHz wireless frequencies are range and bandwidth. 5GHz provides faster data rates at a shorter distance. 2.4GHzoffers coverage for farther distances, but may perform at slower speeds.
  9. How can you "suck" wifi into your boat. The 2 systems I have been able to find are a Kuma wifi repeater(170-00) and Solwise Patriot/3000 Router & Bracket Kit (110-00) Does any one know anything about these products and if so how do they perform
  10. Will start a new thread as suggested thanks
  11. thanks Rusty, Im basically an ignoramus on most things boating including this. After reading a lot Im still not sure, however my question is how do I suck free wifi into my NB. Have you ha any experience with this. I also note Solwise is mentioned in a number of forums are hey up to speed with the latest wifi " sucker"
  12. Hi Delta which setup did you purchase Im looking at the KUMA at 169.99 a bit expensive if it does not do the job
  13. Hi My Vetus waste gauge is stuck on high. Is there any way I can service is as I can get to it at the top of my tank or should I flush the tank with a hospipe.
  14. Hi NMEA What type of NRV (where do I buy it) and where do I fit it ? Will it put more pressure on the macerator and pump Do most chandlers have them.
