Posts posted by Canal321
5 year rule
If a craft is entirely built (including the shell) by a DIY boatbuilder only for their personal use it is excluded from the RCR provided it is not placed on the market within 5 years of its first use as a boat. The boat does not have to be complete for the 5 year period to start, but does have to have been used as a boat (e.g. cruised on a waterway). The '5-year rule' does not apply to sailaway craft that have been completed by the first owner, as such craft have to be assessed under Post Construction Assessment by an Approved Body.
Should the 2 threads about the 4 threads be merged?
- 2
- Popular Post
- Popular Post
Just to update this, new belt arrived today so I put that on. Wired it as suggested and all works well. Thanks again.
- 6
Hi all,
I was hoping someone would be able to identify the wiring connection on the back of my alternator. It's been on my engine for a few years, but never had a belt or wiring, so I'm going to see if I can get it going.
There are no markings next to the 2 terminals with spade connectors on them. Would the blue arrow be the B+ , and the red arrow be the D+ ? There was a black wire connected to one of the mounting bolts that went back to battery negative.
I have wired an alternator before but the terminals were all marked up, Any advise appreciated thanks.
Just noticed it for sale
https://narrowboats.apolloduck.co.uk/boat/pinder-36-semi-trad-for-sale/702985
Interesting project. Looks more like a Harborough Marine to me. What engine will be going in ? .
If it was still on that mooring in November 21 maybe it got moved with the others.
https://www.canalworld.net/forums/index.php?/topic/113280-mersey-and-wye-ll-shortboats/
On 02/04/2022 at 13:35, John Griffiths said:
Will A Lister STW2 be powerful enough for a 50 ft narrowboat on the Severn or Trent. Some have said 20 hp, some 28 hp ?. Looking for a thumper but not much room on boat. Any idea's please.
Have a look at Sabb or Bukh.
15 hours ago, Tony Brooks said:
This is an outright informed guess so perhaps you should wait for SirN or one of the Vintage engine chaps to come on.
large terminal on the end - battery negative
The other large terminal - battery positive
The two smaller terminals are for the "solenoid" coil so one negative and one positive from the ignition switch start position.
Thanks Tony
Your wiring instructions were spot on. Got it going. Thanks again.
- 1
Thanks, you've given me something to work with. will have another look at it tomorrow.
Hi all,
I have an old starter motor and I'm struggling with the wiring. It's a cav CA45f12-35m , where do I connect wires to get it going ?. I have read some of sirnibbles previous posts but I can't find any wiring pics.
Thanks
I've circled the terminals.
There is the floating dry dock at Altham.
On 17/08/2021 at 18:52, Tracy D'arth said:
That's a smart boat, worth buying a new engine for. well done. Just don't get ripped of with an engine.
Colecraft?
Looks like a Liverpool to me.
On 30/05/2021 at 18:51, carsten said:
Time to time i need the water pump diaphragm and now no spares are left. I only know Sleeman but they charge 40 pound for one 70mm rubber diaphragm !!! Are there any reasonible part supplier available ?
I bought a sabb 2j from Marine Enterprises, Dorset a couple of years ago. Sean there had 2 complete engines and 4 more stripped for parts. As part of the sale of the engine to me, he replaced the water pump diaphragm. So I think he would be worth a try. http://www.marineenterprisesltd.co.uk/
Have you looked into solar panels? Other than that it would be a decent suitcase genny.
I have a little parweld inverter welder. It's smaller than a toaster but will still run 3.2 rods easily. Rods are available on eBay, 20kg for around £45. That's a lot of welding. Remember with stick you pull towards you, not push away ;).
I just had a check back in, looks like they have got the engine going.
Needs some handrails on the cabin, and that back bit of cabin wants taking off and some gunnels adding. Wonder if that engine can be saved? Looks like a petter.
1 minute ago, peterboat said:
Chuffing hell its happening we are going green whether we like it or not
So rip that Rayburn out, the diesel heating out and the generator as well.
1 hour ago, 1st ade said:
But (almost by definition) if it's stolen you didn't let it go, it was taken?
Not when you hand a stranger the keys and expect to be paid in instalments, over the next so many months.
(Not saying this has happened in this case)
As is always said on here, boat theft is never as simple as it first appears.
Possession is nine-tenths of the law.. I would not let my boat go until I had the money in the bank..
Minor body repair prior to painting...
I like 'Big boy bodyfiller' from Toolstation. Goes on nice and is easy to sand. Get it in the 600ml tub and it's good value.
