Posts posted by Theo
5 hours ago, system 4-50 said:
from Wiki:
For nearly all models of induction cooktops, a cooking vessel must be made of, or contain, a ferrous metal such as cast iron or some stainless steels. The iron in the pot concentrates the current to produce heat in the metal. If the metal is too thin, or does not provide enough resistance to current flow, heating will not be effective. Induction tops typically will not heat copper or aluminum vessels because the magnetic field cannot produce a concentrated current, but cast iron, carbon steel and stainless steel pans usually work. Any vessel can be used if placed on a suitable metal disk which functions as a conventional hotplate.
That, to me as an ex physics teacher, looks all wrong. Iron does not concentrate current. It has a higher resistivity than copper or aluminium but the current will be distributed through iron in the same way as through other metals.
8 minutes ago, Theo said:That, to me as an ex physics teacher, looks all wrong. Iron does not concentrate current. It has a higher resistivity than copper or aluminium but the current will be distributed through iron in the same way as through other metals.
Hm...
I had ignored the skin effect. Thanks all. As said, more research required.
N
I have been cogitating on the idea of an induction hob on the boat. We have recently bought a new cooker for our house kitchen with an induction hob for the house and have fund it completely excellent.
I have looked up the literature on how they work and all the articles say that they work by the induction of eddy currents in the base of the pan. If this is the case they should work perfectly well with any metal pan. This is not the case. They don't work with thick or thin ground based or otherwise aluminium pans. AFAICT they only work with ferro-magnetic based pans. We have one or two cast le Creuset pans and they work perfectly. The new ones that we bought are, presumeably, a ferro-magnetic stainless steel.
This indicates to me that eddy currents pay little part in the heating. It also indicates that a more likely heating effect is by the repeated magnetic cycling giving rise to hysteresis "losses". When we use our new pans on our induction hob they make sometimes make a low buzzing noise as the coils in the cooker are energised.
I would be really interested to hear other people's views on this.
Nick
13 hours ago, Tony Brooks said:
Unless the design has been altered, the seal is a carbon ring in a rubber diaphragm pushed onto the back of the impeller by a spring, a bit like the PSS shaft seal. The diaphragm allows the seal to "wave about" yet still stay on the back of the impeller. i don't find it strange, but you were very wise to swap the pump. FWIW unless you have a decent press and a degree of skill to remove the impeller, changing the bearing is not as easy as some here seem to think. You also need to change the seal assembly.
Thanks, Tony. Always helpful and to the point!
Nick
On 07/10/2023 at 19:27, magnetman said:
Why does the water pump need replacing?
Sorry to be really late replying, Tony
The bearing is really loose. There's lots of lateral play, but, and this I don't understand, it's not leaking around the bearing. Very strange.
Nick
...on a BMC 1.5
What sort of sealant should I used for between the gasket and the steel? Will boss white do?
N
On 23/08/2023 at 20:23, mrsmelly said:
Well to be honest its non of the above The nearest would be cassette but my preference without a doubt as a long term liveaboard was Porta bogs, so closest here is cassette so I will play along and tick it
Ditto. As long as I could get one with a couple of spare holding tanks.
11 hours ago, IanD said:
I've seen the same mistake made with a stern line... 😉
So have I. Don't ask when I saw this.
6 minutes ago, IanD said:
And the anchor type/weight?
Danforths and similar are cheap and very common but not very effective for their weight -- or looked at another way, the ones used are often too light for a 60' narrowboat because a heavy enough one is pretty unmanageable... 😉
(before anyone asks me -- 10kg Kobra + 5m of 8mm chain + 25m of 14mm anchorplait...)
16kg danforth
8 minutes ago, howardang said:
Here we go again🫤
Howard
Sorry. 😕
Moderators, please delete this topic if it's all been said too often.
N
- 1
I'm going to bite and be prepared to be shot down.
We have 50ft chain and 40ft rope. I do wonder if that it really enough on the Severn but I hope that as we approach the weir the water get shallow enought for the anchor to bite.
Having just come up the Severn and the Avon the fact that my cooling water pump has just failed emphasized how important it is to have an anchor ready to be deployed.
We are on the North Stratford now and the engine cooling water pump is defunct but it is a manageable problem. If it had happened on the Severn and we hadn't had the anchor ready it would have been life threatening. On wide rivers like the Severn and the Trent we have the anchor at the front. On these rivers, if you are going downstream there is room to be brought up and swing round head to the current. On narrow rivers like the Avon and the Soar we have the anchor at the stern if going downstream. Not ideal but better than being unable to turn and wedging right across the river with the current trying the capsize us.
I know that this topic has been aired before but I think that it's worth saying again that on a river an anchor is an essential piece of safety equipment and needs to be ready for deployment in an emergency.
I frequently pass boats with the anchor neatly stowed on the roof with nothing attached to it. Even if the crew know exactly where the chain cable and warp is it will take several vital minutes of panicky work to get it ready to deploy.
N
- 3
18 hours ago, Alan de Enfield said:
Good as in he is thorough and ensures everything is safe and compliant?, or
Good as in he sits in the cabin has a cup of tea and some choccy biscuits and writes out the 'pass' certificate without looking at the boat?
Tempting just to say the former. Certainly not the latter. The former but leavened with common sense would be good.
Recommendations for a good inspector near to Tardebigge?
Nick
Quite possibly, The name is painted on the side of the boat
We saw you, too, on the Avon, and you kindly warned us of the stoppage on the Stratford. I didn't twig soon enough to realise.
Nick
- 1
Probly a good plan mrsmelly.
Next question. Does anyone know a suitable person to do the job near Tardebigge?
N
I really do need to sort out the horrid state of the engine hole. The issues as I see them are:
- I had a leaky exhaust pipe which sooted things up a bit.
- There is lots of frass from the drive belts.
- The swims need painting scraping and painting
What's the best way to start?
Steam clean? Will that damage the electrics?
Solvents? Will they damage plastic bits?
Polluting the cut should not be a problem because I han direct the bilge pump into into a plastic can.
All hints and tips gratefully received.
Nick
I have solar with a Victron SmartSolar HQ204684PFB controller and an Adverc. I don't think that either of these are adjustable for a lower charging voltage. I will have another look to see if I can disable equalisation if this is advisable.
The Adverc manual says that it keeps the charging voltage down to 14.4V alternating with 13.something. The 14.4V is OK for the batteries. The error starts showing when we are an hour or so into the day's cruise and the SG is showing about 97% SoC. I haven't seen the voltage go over 14.4V.
It seems to me that I can disable the E03. Am I correct?
N
Thanks, Matty. Are Simply bearings local to you or online?
Nick
This is the overvoltage error for the battery type selected. Gibbo said years ago that type 2 ws the right one for my batteries. At what voltage does E03 start to show? I can't find it in the paperwork.
N
Thanks all. Lots of useful advice there.
N
Theodora has a triple drive belt from the gearbox to the prop shaft. I have jsut replaced it with the spares that I keep on the boat and now need to buy a new set. Trouble is there is no legible code on either the old set or the new set. So what do I ask for?
I would imagine that I would cut oneof the old belts so that I can measure its length accurately and measure the width of the pulley groove. Will that be enough information to give to the supplier?
They are a bit of a sweat to replace. What do you think of the PowerTwist belts? Being able to "break" the belt would save my having to unbolt one of the Plummer blocks.
N
On 28/07/2023 at 09:16, Jen-in-Wellies said:
I read the title and my first thought was Leeds and Liverpool.
Ditto
On 30/07/2023 at 08:54, Tonka said:Back pumps from the sea upto the lakes from both sides. It is not rocket science
Not a good idea to put sea water into a sensitive FW habitat. However a commercial advantage would be that you could load the ships more heavilyif the cana became saltwater instead of fresh.
Which bit of FB are the photos on. I can't find them
N
Alvechurch Boat Centres (ABC)
in General Boating
Don't ask me why yet. That'll come later, but I am trying to find out who's on the board. I've tried here but veryone seems to have resigned except Edward John Helps. And had a look here as well but that doesn't have a lot to do with ABC.
Is Mr Helps the person in charge or is ABC collapsing in a heap?
Does anyone have any information?
Nick
