Ok. With big tiles like that, the trueness of the wall is vital. It doesn't matter whether it's vertical as long as it's all the same. Any twisting will cause headaches with corners protruding and spacings varying. If it's not true then you can thicken the adhesive in places to compensate. This may be by buttering the back of some tiles in places or, if extreme, using dabs. A hollow is easier to deal with than a bulge as you simply thicken the adhesive in that place rather than the rest of the wall. If using a brick-bond pattern the trueness is even more important as regular patterning can cope with some curving on a single axis.
The first row is by far the most important. Spend plenty of time getting that right and the rest will fall into place. Make sure it's absolutely level and straight. If the floor is significantly out of level you can start with the second row and support it on pins or props then cut in the bottom row later. This method is also helpful when the finished level at the top is vital. Work out your spacing to give the most pleasing effect. For example, if the run is five and a half tiles wide, it normally looks better to have four tiles centered and a three quarter at each end. It's a bit more complex with brick-bond but the important thing is to try to avoid small cuts of tile.
A diamond disc in an angle grinder (or tile cutting saw if you have one) will cut any type of tile. Ceramic tiles can be scored and snapped but most others cannot. I always use powdered tile adhesive and grout and mix them myself.
