Hi all
putting steps on the rudder as way to climb out of the canal would this cause problems with the steering of the boat as the water passes around the rudder,or would it be better to have them removed and buy a proper escape ladder, reason being I find the tiller quite hard when under power whilst turning.
Sorry when I read the eBay blurb it said semi submersible so I assumed you put it in the bilges, that makes more sense And I still think it’s a great modification should be standard on all new boats.
So you still drain the coolant into the bilges? I thought you had inline pump to Pump the coolant straight into a container but I still like the ball valve idea thanks for the info.
That’s a great system what type and size is your pump? I’ve spent most of last Friday draining into my bilges then pumping the out the bilges not something I want to do again.
This seams a good idea because I have large bleed nuts on both my skin tanks that will take the pump tubes, so I’ve ordered one on eBay £12.99 with free delivery.
Hi all for some reason my pink antifreeze has started to turn dark pink with a sediment in the expansion tank, engine And boat only 2 years old any ideas welcome.
