Rivelin
Everything posted by Rivelin
Most people I have spoken to about it do want to move to electric propulsion - I guess it's just down to who you talk to. For me the benefits seem obvious:- Travelling along your favourite waterway with only the sound of the water lapping against the boat and the birds singing No fumes to breathe in when in locks or when the wind is in the wrong direction Big savings on fuel costs when batteries are charged from solar panels and / or wind turbines At some point, we're going to have to stop using combustion engines On a recent demo, the 55' narrowboat I was on was propelled purely by a 10kw electric motor at ~3mph and the power coming from the solar panels exceeded the current being drawn by the motor. Obviously this was a lovely sunny day so this wouldn't always be the case, so the boat had a little diesel generator for our dull weather ( yes I know that's most days 😉 ). My current thinking is to attach (bolt or weld) a splined pulley onto the prop shaft close to the coupler, then bolt on an electric motor with a suitably sized splined pulley on it's shaft, with a nylon belt driving the shaft. The resistance from the gearbox is very low when in neutral so I don't think this would add much load to the motor when in electric mode, and the motors turn freely when turned off, so equally wouldn't add much load to the engine when under diesel mode.
Ouch!
I bought a Halfords HB013 starter battery for mine about 3 years ago and it still works fine. It was about £60 then, and now they're £82 Choosing the right leisure battery is much more important, but IMHO for starting, it's just the same as a car starter battery so save yourself some cash.
Fairer - absolutely 👍 Fairness seems to be a dying art...
Just got an email from EA informing the outcome of the licencing consultation: They will: implement many elements of the charge framework as proposed and consulted not implement the area-based charge on any of the waterways, we will keep the current charge mechanisms for powered and unpowered enclosed boats increase charges by 4% in 2022, 4% in 2023 and 2% in 2024 I'll be up upgrading to an extra-wide beam for no extra charge then...
Insulation Materials - Polystyrene and rusting?
Rivelin replied to TitaniumSquirrel's topic in New to Boating?
I used commercial foam insulation panels (the kind with aluminium skins) and sealed gaps as best as I could with aluminium tape. After 3 years it's all looking fine behind the ones I checked. As others have said, keeping moisture laden air out is key. -
When I was a kid, my Dad always said "pitch fully fine, 49/50" before we set off in the car (he was in the RAF) - maybe this is where it all came from? 😋
Spot on with your rpm estimates! Probably nearer too 1400 for cruising, so maybe I just need to get better soundproofing / silencer. The prop is 440mm according to the pre-purchase survey.
Hi all, I'm keen on having my engine run at lower revs so it's quieter so if possible would like to increase the propeller pitch. Are there any prop experts that might hazard a guess to the pitch in the attached photo? fyi the engine is a 33bhp Vetus M4.15, which is based on a 1.5L Mitsubishi engine, driving a 38ft narrowboat. Thanks in advance. Nick
Thanks all - fairly unanimous recommendations that converting would be a very bad idea!
Thanks TD I quite like the idea of having a separate throttle control / gear lever - I know some trad boats have setup - what's the thinking on doing this conversion on a more recent boat / engine?
Hi all, I've got a Vetus M4.15 with a Technodrive TMC60P gearbox. Everything works well except it's a bit difficult to find neutral. It clicks when I go into neutral, but it isn't very loud or definite. Would new cables help, or is this a typical characteristic of this engine / gearbox? Thanks
You're right there Matty - I held back because I thought there might be condensation to deal with. Double d'oh!
1st of May I started preparing my boat for painting. It's rained ever since. It's now more rusty than it was before I started. D'oh
We've got a Boatman too and very pleased with it (and delivered personallly with useful tips from Eddie). I wouldn't have a coloured finish though.
There's lots of short rage on this forum
I got 3/4 inch BSP to 22mm compression adaptors which screw into the brass fittings in the tanks. The front tank fills from the top (drilled to take the filler), and feeds to the back tank via the 22mm pipe, then a 22mm to 15mm tee allows a 15mm pipe to take water from both tanks through the bulkhead to the pump. If you can fit any raised breathers in the deck I would recommend this to reduce condensation on the inside of what was the old tank.
Yes, I unscrew the lids so I can grab hold of the lip, and lift them out.
The inside is treated, but if need be I can easily disconnect the compression fittings, pop the tanks out and clean / repaint.
