Bump and Grind
Everything posted by Bump and Grind
  1. I don’t see any trace of water in box or oil in the cooling system. The box (I believe) is quite early, the serial number is 7716, so the dipstick might be sortoff original. Someone else mentioned overfilling so I will take some oil out and retry this weekend.
  2. Oil cooler is connected and cooled by the skin tanks, no leaks or holes. Oil is ATF so is red anyway. The dipstick is not a screw it’s a plug, it’s not original, so I’m not sure if it is even correct.
  3. I have a BMC 1.5 married to a 71C Velvet Drive with a problem. The oil (ATF) is up to the mark on the dipstick but when I get to about 1500rpm oil comes out of the breather. Reducing revs stops this. Has anyone got any idea what is wrong and how can I solve it.
  4. Hi All Being new to narrowboating, I have found I have a lot to learn. I have a stove with a backboiler to heat one radiator using a themo-syphen system (doesn't work very well). I don't need to heat the end of the boat, so what I want to know is - If I drain and disconnect the pipes at the back of the stove (probably remove them altogether), can I still use the stove as normal?
