Hi! Every 15 seconds with cold tap open!
2.9 gallons per minute
When hot tap is open the pump is on constantly but hot water unit sometimes sounds like there’s not enough water going through it
Ok! I pumped up accumulator tank but pump was on and off every couple of seconds, so I assume too much pressure! I released some pressure and pump on and off every 15 seconds now
Ok, yes it does state cut out pressure at 40psi 2.7b Max
Hi! I’ve just installed a 2.9 Par Max pressure pump!
The pump is capable up to 3.5 bar. Should the tank pressure be equal or less?
Pump kicks in for 18 secs before it stops! Ta!
Hi! I have a fixed panel on the roof facing SW on my mooring! If facing South the panel angle should be 42 degrees! For you mathematicians out there, what is the ideal
angle or am I just clutching at straws?
Hi! The water pump is a jabsco shower/ drain one! Do you recommend a ‘Gulper?
The heater is a Morco 6 ltr Ecoplus model
Hi thanks for your advice on pipe size
Hi! Thanks for your reply! Copper Pipe going to heater is 15mm since new! The heater is 6 ltrs. ta!
Hi! The water pump is a jabsco shower/ drain one! Do you recommend a ‘Gulper’?
Hi! I’m looking to buy a new LPG gas water heater because flow is slow to the shower to provide hot temperatures! Heater always sounds like there’s not enough water! My pressure tank is about 3 bar
Which is the best heater for flow rate on a narrow boat please?
Is it the case of ‘the bigger the better? Ta!
