Jo Green
Everything posted by Jo Green
Hi, We are planning to upgrade from galvanic isolator to galvanic transformer. Our boat is currently on 32 Amp. I found this transformer and nearly went ahead and bought it, however, I’m not sure it meets the wattage requirements. (32 x 230 = 7360w), this transformer falls short. Any advice or recommendations of different transformers appreciated. https://www.batterymegastore.co.uk/product/victron-energy-isolation-transformer-7000w-230v Thanks Jo
Thanks BEngo. Yes, it’s the external collar so mostly worried about rust. Don’t want to have to repaint too often!
Thanks Ray. Looks good.
Hi, I have had a flue collar made for my stove chimney and I now need to paint it black. Any advice on which paint is best to use for quality and longevity? Thank you
Good point. I hadn’t considered that the NRV could be part of the problem...
Thanks. I’ve installed a non return valve where the washing machine hose meets the skin fitting hose. Therefore given the washing machine hose necessarily loops up via the top corner of the washing machine it’s unlikely that it’s being filled back up by water running back down the hose. Regarding the pump not being strong enough, this seems most likely but with the waterline being considerably higher than the top of the washing machine I’m not sure what I can do. Any thoughts? thanks
We have plumbed a standard washing machine (Zanussi Lindo300) into our Dutch barge which is moored in a marina with 240v shorepower. We have installed a skin fitting outlet which the washing machine is plumbed into via a couple of metres of hose (additional to the approx 2 metres of standard washing machine waste hose which comes attached). The skin fitting is approx 1 meter above the top of the washing machine. We only installed last week and don’t seem to be able to get it to work. At the end of the cycle there is still a substantial amount of water in the machine. Any thoughts or advice? Thank you
Thanks everyone for your advice. I will look into calorifier + immersion heater. I wonder how many watts it needs? We are only plugged into 16amps. I will also have a look at the potential Morco replacement.
Hi Dave, we have space but because we live in a densely populated marina and have a big, loud engine, we don’t want to have to run it too frequently. We also have two very small children so the instant element of the LPG water heaters is appealing.
Hi Alan, thanks for your reply. I have done a comprehensive search and the Morco F11 isn’t available anymore. I actually ordered one from EBC and they called me the next day to tell me that they’re no longer being produced and aren’t available. Their website just needs updating. We don't currently have an LPG water heater on this boat. I had one on my last boat- not room sealed and with pilot light but I’m trying to increase safety this time round. Maybe not possible and will have to go for standard non-room sealed version.
Hi, We’re looking to fit an LPG hot water heater in our boat. We are moored in a marina so have mains electric. We were planning to get the Morco F11 but it’s no longer being manufactured. Can anyone recommend a decent equivalent? Looking for room sealed with balanced flue and electric ignition (no pilot light.) this is one option I’ve found.. https://www.amazon.co.uk/TTulpe-TTCM1230-C-Meister-P30-White/dp/B0744G9V9G Thanks!
Thanks for this info.
- 21 replies
- toilet
- waste tank
(and 1 more)
Tagged with:
Thanks so much for this information Dr Bob. Really useful. Hi Bob, I don’t know if the tanks were new when installed or recycled. They were already installed on the boat when we bought it. We could ask the previous owners. It seems we definitely need to replace the tank though. Thanks for this very useful info Sam.
- 21 replies
- toilet
- waste tank
(and 1 more)
Tagged with:
Thanks Sam, really useful information. No original tanks. What we have now is what was onboard when we bought the boat.
- 21 replies
- toilet
- waste tank
(and 1 more)
Tagged with:
Thanks all for your advice. We bought the boat in Holland last year and this was the set up that we inherited when we bought it. The boat is a 1925 mussel boat, 26m x 4m. The boat is moved to the pump out point in the marina when the tank is full. So it seems the tank may be inappropriate as we thought. Thanks for taking the time to reply. jo
- 21 replies
- toilet
- waste tank
(and 1 more)
Tagged with:
Hello, Looking for some advice regarding our waste tank situation. The boat has a pump out toilet with large 1000l waste tank. It is quite smelly inside the boat and we’re trying to narrow down why this is. The tank is identical to the potable water tank on board. Could this be the issue? Not the correct tank? Link to the tank below: https://www.directwatertanks.co.uk/1000-litre-new-schutz-ibc-steel-pallet-un-approved?language=en¤cy=GBP&gclid=CjwKCAjwoMPcBRAWEiwAiAqZh94zhssTN0p7KAMB2Jkx4PVkj8vG62Nk0lcVzs92kPXjVSiFedCZZRoC3ysQAvD_BwE If not we’ll have to investigate other possibilities. I’m thinking pipework, seals, tank lid, tank treatment- we use Elsan blue as this had been used previously so more organic options weren’t available to us. Anyone got any ideas of most likely scenario? Many thanks, Jo
- 21 replies
- toilet
- waste tank
(and 1 more)
Tagged with:
Thank you so much Jon. Very helpful.
- 26 replies
- heating
- drip fed boiler
(and 1 more)
Tagged with:
Hi, thanks for your responses. Very useful information. See below photos of what may be the fill point. Any thoughts? Many thanks
- 26 replies
- heating
- drip fed boiler
(and 1 more)
Tagged with:
Hi, Thanks for all your previous help. We currently have the Kabola running. It’s easy to light and runs well, heating three radiators in the boat. Radiator one is small and the highest in the system. (See pic 1) It sits in the engine room, near the Kabola. Radiator two is larger than the other two put together and sits midway down the boat. Radiator three is small and towards the bow of the boat. Radiator one and three heat up quickly from top to bottom and seemingly have no air inside. Radiator two is quite obviously only half filled with water. You can clearly feel the heat ends about half way up. We have studied the system and we think we’ve found an expansion tank (see pic 2); a pressure relief valve (see pic 3); a temp and pressure gauge (see pic 4) and seemingly no fill up point. (Possible fill points- see pics 5, 6, 7.) The pressure gauge indicator never leaves zero whether the boiler is running or not but the plumbers tape where it connects to the Kabola looks new and the gauge looks like the newest part of the system. (I’m hesitant to believe it’s not working.) Please excuse the slighty rambling description. I’m trying to communicate everything as clearly as possible. Is it possible, given that the system seems to be only 60% full of water, that the pressure gauge is working fine but there simply isn’t any pressure in the system? We can’t locate any obvious fill up point (certainly not two check valves in a row.) What would the risks be in seeing if radiator 2 wants to bleed air? Your advice and help is much appreciated. Jo
- 26 replies
- heating
- drip fed boiler
(and 1 more)
Tagged with:
Hi, we have a Kabola E7 series which we now have up and running. There’s a bit of a safety issue though, which I’m not sure how to fix... Every now and again the power cuts out in the marina. When this happens, the circulation pump stops working and the water is left boiling with nowhere to go. Would an overboil protection decide solve this problem? There’s isn’t currently one fitted. Thanks, jo
Hello, the Kabola is working and bringing much needed heat! We are over the moon! One more question- the main radiator is only hot at the bottom so presumably needs bleeding. With a pressurised system can I just go ahead and bleed to radiator? The last system I had (a mikuni) had a header tank so I could easily add more water to the system. How does it work with a sealed and pressurised system? Thanks in advance, Jo
- 26 replies
- heating
- drip fed boiler
(and 1 more)
Tagged with:
Thank you for all your help. We’re working on it tonight.
- 26 replies
- heating
- drip fed boiler
(and 1 more)
Tagged with:
Great. Thanks
- 26 replies
- heating
- drip fed boiler
(and 1 more)
Tagged with:
Thank you. I've ordered a new thermocouple from Kuranda. Hopefully when that arrives and is fitted we might get it lit. I think there is too much of a build up of soot and oil in the bottom of the burner pot so need to get that sorted too. Cuthound- we have no markings on the regulator as it's old and worn. Whereabouts is position 2, do you know?
- 26 replies
- heating
- drip fed boiler
(and 1 more)
Tagged with:
Hello, One thing I forgot to mention- we never saw the thermal shunt supplying fuel. It stayed dry and seemingly untouched by diesel each time we lit it even when we had the button of the fuel protection device depressed. Should fuel have been dripping from this nozzle? Working on the theory that this pipe could be blocked we sought to clean it out but unfortunately broke it. (See picture). We've established that the fuel is flowing into the regulator fine from the daytank and the filters aren't blocked. The regulator is definitely working and allowing fuel to flow through. Any advice? Thanks!
- 26 replies
- heating
- drip fed boiler
(and 1 more)
Tagged with:
