svetlovska
Gender
Female
Location
Brighton
Occupation
Civil servant
svetlovska's Achievements
Explorer (2/12)
2
Naive generator question - how to hook up?
svetlovska replied to svetlovska's topic in Boat Equipment
Thanks all, very helpful, I'll be keeping the generator under the rear deck and the cylinder with the other cylinders in the bow gas locker when not in use with towpath operation and a stout chain! -
Hi, I'm a newbie so please be gentle. My recently purchased boat has a Victron Energy Phoenix Multiplus battery management system which automatically switches from shore power to Inverter, and manages battery charging for me. I also have solar panels integrated into this, topping up the leisure batteries. At the moment I am marina based, and just plug in the shore power and that's it. Next year I will be continuously cruising, so am looking at getting a Propane driven Honda EU20i suitcase generator to top up the leisure batteries on days when I am not cruising and the alternator isn't running. I'd rather do this than run the main engine just to charge . Is this simply a matter of taking the 240v output of this generator and feeding it into my shore power socket via a suitable cable, or is there more to it than that?
Help! Liveaboard boater Victron Multiplus Phoenix crisis
Problem (apparently) solved! - Thanks all for the replies and that, err, illuminating discussion about polarity, which I must confess was above my head. Very fortunately for me a logically minded ex-engineer man friend of mine decided to visit today, and took me through that isolate-one-thing-at-a-time-thing. We didn't get very far before he pointed at my in-line galvanic isolator cable which has sat happily connecting between the dockside power post and my mains cable for the past three months, and asked: "Have you tried it without that?" I harrumphed and spluttered a bit, and then admitted I'd overlooked it in all my other frantic day and a half of wild stabs in the dark. So he unplugged it, connected the mains cable directly to the power post, switched both the 'power in' and 'power out' breakers in the mains box to 'on' (no red 'reverse polarity' light, so I guess I was wrong about that too) and, hey presto, everything was back to normal, live 240v sockets from shore power as usual, and the batteries now (at 10.30 pm, 5 hours on) on 'float' trickle charge after a brief bout of 'absorption'. I've taken pictures of the switch positions for my own future reference in case of future difficulty. So: I'm out £20 for a booked support phone call to Victron dealers onboardenergydirect.co.uk which I haven't had yet and now apparently don't need, but, hey, some learning has occurred anyway. I dunno what witchcraft affected the galvanic isolator lead, but for now I'm happy to let it be. At least it means I can put the stove on again! Hopefully anyone else with this weirdness in their life might find this post and try swapping out the mains cable or any extensions to it before trying anything else. I am *very* relieved. Thanks again all for your contributions.- 36 replies
- victron
- multiplus phoenix
(and 1 more)
Tagged with:
svetlovska posted a topic in Boat Equipment
I have no technical expertise whatsoever, so please be gentle with me! I'm attaching pictures of this in case it helps. I am a newbie liveaboard narrowboater in a marina in Milton Keynes. It's a great boat but for some reason the previous owners loved their shore power, so although I have 12v lights and pumps, the fridge, tv etc are all 240v. Worse, I recently discovered that the Morso Squirrel stove back boiler also relies on 240v for it's pump. No 240v = no heating as I can't operate the stove without the pump running. For the last three months my Victron Phoenix Multiplus 12/3000/120 unit has been left switched to 'on' and happily showing 'Mains' and 'Float' lights on the left 'Charger' side of the front panel, and 'inverter' only away from the dock, as you'd expect. Yesterday, something tripped out the breaker on the power post my boat plugs into, and the breaker in the main shore power switch box (? - it's labelled 'Mains' and looks like a domestic fuse box, see attached.) I was not running anything on mains at the time. The 'mains' box has a green light labelled 'Mains On' up top, and inside the fuse panel, red and green Lights, and breakers labelled Power In, Power Out and Immersion heater. Labels inside the box say : 'Red on reverse polarity' and 'Green mains on'. My recollection from earlier days when everything was working fine was that the red light was usually on. I assume that flipping the breakers up is turning them on? As is the case for the power post I connect to. The Victron panel is split between Charger and Inverter sides. In normal operation, I leave the central switch to 'on', and the Charger side shows Mains On and Float. In this state, all the 240v sockets are live, pulling power from the shore. The Inverter side only comes on when I disconnect shore power to cruise, as you'd expect. On resetting the post breaker, I discovered that as soon as I attempted to also reset the breaker, the Victron flipped from the 'On' setting, where it usually displayed mains in and 'float', to 'Inverter' with no signs of life from the 'Charger' side of the Victron front panel, and the post breaker tripped again. Here's the thing: if I switch mains power to the boat off using the 'Power Out' breaker in my mains box, the Victron shows mains input and starts charging as normal (but there is obviously no power to my 240v sockets.) If I switch the Power Out breaker on, it immediately trips the shore post breaker, and mains power shuts off at the mains box (judging from the light going out up top). Then the inverter kicks in, and all my 240v sockets work, but are doing so obviously by pulling power from the battery bank to do it, which, worse, are receiving no top up charge, so this is not sustainable. My 12v gear (lights, pumps etc) are unaffected by any of this, and continue to work in either state. From this I deduce it is something to do with the automatic switching from mains to battery power by the Victron, or between the mains box and the Victron, caused when I attempt to supply mains power to the boat. Do you have any suggestions, or a contact for a service engineer in the Milton Keynes I can pay to resolve the issue? As I live on the boat and can't operate my fridge or my heating without mains power, this is quite urgent.- 36 replies
- victron
- multiplus phoenix
(and 1 more)
Tagged with:
I have a newly purchased second hand Narrowboat moored in Milton Keynes. It has a Morso Squirrel stove with a back boiler hooked up to two rads. I haven't used it yet, have no instructions and don't even know if it is pumped, where from, or how to get to anything vital. Can anyone recommend a suitable engineer or yard near MK who can check the system out for me before I blow myself up?
Does anyone know of someone who can install a composting toilet professionally? I have zero DIY skills, but would also like to stop using and if possible remove the pump out on the second hand boat I recently bought.
Hi. I've just bought my first boat, secondhand, moored in Milton Keynes. It's well served with 240v sockets and has a Victron box of tricks handling switching from shore power to inverter or battery, but no 12v or USB sockets. It has a mains only fridge, TV, and washing machine, and seems set up for marina life, not off line cruising. Can anyone recommend a good marine electrician in the MK area who could install some 12v and USB sockets for me, so I can swap out the main gadgets for battery powered alternatives?
Newbie query - upgrading power generation for a liveaboard?
http://www.engelfridges.co.uk -
This is the 12 v fridge freezer I had in mind. http://www.engelaustralia.com.au/2products_details.asp?pid=11&productid=21627 And yes, twin tub camping style washing machine. No hairdryers, irons, toasters... -
Trust me. It'll have the cleverest damn power management that money can buy!! -
Thanks, that's good to know. Lucky I'll be a continuous cruiser then -
Thanks Mike. So: ballpark, obviously, but how many hours a week should I expect to have to run the engine in the winter to keep the batteries in good shape? -
Calorifier on moving days, back boiler and/or gasring on non moving days. A navy shower once a week. -
Fess up? Um - I already did? Laptop; wifi hub; Cello 12 v tv/DVD; low power led lights; 12v fridge/freezer; kindle; mobile phone; usb rechargeable pushbike lights; radio; small washing machine to be operated only whilst under way. I'm planning on 400 to 600 w of solar panel, the power concern is that I will be moored up off line for up to a fortnight at a time, so I want to minimise running the main engine just to charge batteries. Thanks Mike. I will be retired to so no working days. Most of my web surfing is via iPad or mobile phone, 2-3 hours a day, similar use of the tv. -
Hi. Good to know about modern Beta 43s. The boat is a 2009 build, if that helps - I'll find out more on my next visit in a few days time. Frugal: I don't know, this is a first time for me, I'm aiming to do whatever I can to avoid using the inverter, running most gadgets off USB rechargeable batteries (eg laptop, music system), but I still expect power to be an issue, so I'm trying to prepare for the worst!
