Everything posted by Profzarkov
Yes, I was seeking replies from anyone who thought that the coal had changed.... never seen the eerie blue flames before Could be a hallowe’en special I suppose??
Yes it has the line down the middle and is in a sealed SuperTherm bag.
Just starts lighting the Squirrel this year and have stocked up with the usual SuperTherm but it seems a bit different .... the coals are covered in a white deposit and it has an unusual blue flame, never seen that before. And shed loads of ash. Might look for an alternative. steve
Thanks, I think that during pump out, I restricted the air vent and this must have caused a bit of a vacuum in the tank, probably killing the gauges pressure sensor. Disconnected now. The Gobios system works a treat. Not cheap but will,prob not fail, so easily. Thanks
Hello i have the MSC waste gauge fitted on my 400 litre waste tank, it started to give odd readings so I installed the Gobious system, externally, brilliant. However the old one still does work but recently it just shows a full scale all the time. The tank Is now empty, is there an easy way to recalibrate the MSC gauge to show zero too?
Sorry, yes, I forgot. I just wanted some help and advice. I forgot I had to do lots of discussion!
Yes, I used the 12V boat group on Facebook and rely on the usually very fast response from the guys on there. I also try to give answers as I believe it should be helpful. There are plenty of other places (viz Facebook, Twitter) for folk to vent spleens and have a go at each other. My Do Eric seems to be behaving a bit better but cut out again when trying to do a machine wash whilst on the go. so will get it checked out
Sorry, apologies. Yes, not my original thread but things do seem to go off topic quite quickly! Thanks for the help and banter.
Um, this was my topic and if you wish to help, then fine if not ...
Tricky to get inside. Can't see any foam filters. Have vacuumed underneath. top fan seems ok and spins
Hi, yes, we're not desperate (yet) as I said it does come back on and works for the rest of the day. we have 660Ah AGM batteries so they take 90A for about an hour before decreasing ... yes, if we were stuck we could use the starter battery alternator! i think a brush thru to remove built up dust, dog fluff on its heat sink might be the first port of call, if I can get inside it and then maybe a service From cox auto - new brushes kit be in order
My travel pack seems to switch itself off, no red or green light. I'm guessing its a thermal cut out as it does come back on. It was delivering 1250 Watts into the leisure batteries at the time. Bit concerning as it's the only means of recharging the leisure batteries. We're going thru Atherstone in a few weeks and will look up Cox auto!
Yes, agree with the above. We went a few years ago. A very good trip. last bit has lots of rubbish in t'canal owing to the fact not many boats cruise it but the entry into the city is amazing! theres lots on me blog plus videos of the last day oh and you have to book your week with crt
We live on our 65 foot Aqualine and don't find it too restrictive. I've cruised most of the canals that our boat won't fit as a hirer. We have friends on the nb Clara, who have a big purpose built cratch that takes their Harley! It even has a lift! So any things possible. A sofa is more comfy and more friendly when others come visiting plus you can store stuff - very important! Have a look around and chat to folk.
We have the stick on window catches - fitch type, see pic. They are glued on with the type of glue you use for rear view mirrors. Pretty good but they do come off. I can't seem to find anywhere that sells them. one pinged off and must have gone overboard cos we can't find it!
Shardlow replied to my email, many never reply, £10 apparently, so I'll pencil them in for later!
My MCS gauge failed, and despite me taking it out & "blowing it thru" , ? it never worked again Daft arrangement IMHO, as it relies on pressure and is bound to get fouled someday. it did work perfectly for years. Installed the Gobious system (got a big discount at Crick show) and since this is external, should never fail. So far so good. With a 400 litre tank it will take us months to fill, but then we can choose where to get the pump out, hence the original question. Sawley sounds good. Have emailed them and Shardlow but no reply, yet. Ditto Castle Marina. Thanks formall The replies. Steve
One of the best pump outs was at Oxley marina, bottom of the Shroppie, where Orpheus Mable did the job all by himself , no timer here and a good rinse all for £12.50.
Sorry, it was not meant to be a definitive comment but more of a i didn't expect that.
Yo im sure I've seen a spreadsheet on here somewhere before but keen to know where the best (?) pump outs are and their price im used to paying £10 in my home marina (Yelvertoft) and even in the Newark (one of the most expensive to moor in the U.K. Marina) it was £10. i know a list may get out of date but few marina's publish costs. i am at Zouch now and looking towards sawley/shardlow/Nottingham cheers steve
A kind neighbour gave me some of the Tolleys, looks good. Squirted it around the mushrooms and the naff tv aerial. See if that works. Doubts if it is the Windahs!
Thanks. I suspect the seals around mushrooms or the old vhf "flying saucer" aerial. The Windows seem fine but will check.
Hi Well, it was a heavy downpour overnight and the first one for ages but we have some leaks. some very curious ones- water is dripping inside a desk and from another spot further along under the gunwales i now suspect a leaky mushroom vent or vents where the rain is seeping inside all my lovely wooden panelling and then out of the gap by the gunwales its an Aqualine boat an so far excellent in most respects but I guess after ten years sommits got to give? its not much but it explains why we get water inside a desk (and all over the printer!) from time to time!
yes, I quite agree, my header tank is much higher than the hoses leading to the skin tank, so any air will arrive at the tank. i had some friends whose system overheated and even shit off the engine, luckily for them, all their coolant had gone and an engineer showed them how to vent the tank for future reference! Thanks for the replies. I think no more read?
Me neither. Mind you I ran my CH and saw that it's header tank was twice the volume, so I bled all the valves on the rads and it's back to normal. Can't see any bleeder valves on mine but then it does go straight into the header tank. The level in this just never changes!
