Hi All,
This is my first post and I apologise if it's in the wrong section.
I have been living on my newly purchased narrowboat for 3 months now, and I love it! It has however, been a very steep learning curve and I think I'm the victim of the previous owners neglect.
When I first moved on I noticed the shower was leaking pretty much everywhere and the bathroom smelt quite damp. So, I decided to rip the tiles off and investigate. This had obviously been a long term problem and the tile backer was just wbp ply, which had rotted to death. Anyway, all is replaced and I have cement backer board and shiny new tiles now. Upon further investigation I noticed that the water pump had a leak at some point, as there was loads of staining around it. This got me to thinking, where has this water gone?
I found an inspection hatch in the rear wardrobe that gave me a wonderful view of a paving slab, and the ply it was cut in was extremely damp. I also noticed a small amount of water in the engine bilge (which is usually bone dry). After extending this hole to the bulkhead I found over 70 litres of water, god knows how long it's been in there!
To cut a long story shorter, the survey said that the boat was listing port and that ballast needed to be removed rather than adding, as the weed hatch was already a little deep on that side. So I cut a hole in the floor under the bed and removed one 45kg paving slab. I thought this would cancel the list and also help air the cabin bilge out. The problem is the boat wobbles (tenders?) a lot when you walk around, and takes along time to correct itself, but the list is gone.
Soooo....
I guess my three questions are:
1) How can removing one paving slab from a 15 tonne (roughly) boat make that much difference to stability? I know that weight sits on the very bottom, but the difference it has made it crazy.
2) How do I rectify this? I was going to put a couple of concrete blocks either side of the engine bulkhead (as it's the only place I have access). But, the weed hatch is already deep enough and I don't won't to make it any deeper. I also don't want to put all the weight back in the same place as the list has gone.
3) Will all that water in the cabin bilge of done much damage? And, as it managed to find itself through a weld on the bulkhead, will it have eaten away at the welds on the baseplate?
Many thanks in advance for your help and sorry for the super long post, just wanted to give as much detail as I could.
Just to add, it's a 50ft 2004 Colecraft trad hull.
