silverbuttocks
Gender
Location
Oxford
Occupation
Archaeologist
Boat Name
Kismet
silverbuttocks's Achievements
Contributor (4/12)
0
BMC Thornycroft 1500 starting (& now smoking) issues!!
silverbuttocks replied to silverbuttocks's topic in BMC
Thanks Rob! So, it takes about 30 secs to 1 min or turning over when cold to get it to start. The starter motor and battery are fine - it turns and keeps ALMOST firing, then not catching, then turning over and eventually starting. Once it has started and is warm then it starts again immediately with no problem. It was only the initial cold start that was a problem. It would smoke during this starting process, but not much afterwards. But when you are a CC you don't want to have to turn your engine over for 1 minute before it starts as it is loud, smokey and presumably unhealthy for the starter motor. Like I say, once it is warm it starts again fine. This was the original issue that our mechanic was dealing with... Now I think the smoking (in idle and under throttle) is due to the some change he made in valve clearances, timing, something like that - I'm no mechanic. I don't know whether this has sorted out the starting problem as I will have to wait until tomorrow morning to find out. But I would rather that it didn't start instead of the amount of smoke being emitted now. Of course I would rather have both problems solved, and presumably the new smoking issue could be easily rectified given that it is due to recent changes. The smoke is white. Yes, Calcutt sorted out our refurbished injectors (which didn't solve the starting problem!). I imagine that getting them over would be particularly expensive!! oh, and there's a slight misfire. there probably was before but it wasn't very noticeable - now it is much more noticeable. yes, i know. i always give 30 secs preheat. the starting problem is after the pre-heat - it then takes between 30 secs and a minute to actually start -
Hi All, We have a TC BMC 1500 in our NB. Over the past few months it has taken longer and longer to start, up to around 1 min of turning over and nearly catching before finally catching, with a 40 sec pre-heat. Between November and today we have had a mechanic visit 4 or 5 times (who we trust), and he has gone through all of the obvious issues (glowplugs, compression, valve clearances, diesel injectors (we had them serviced)) and each time the problem has persisted. Now it's got to the point that our mechanic has tinkered enough to try and get it to start that it now smokes like a ba***rd. Basically now I'm not sure if the problem has been made worse or that the engine just isn't happy. A week or so ago (before refurbished injectors were fitted and some tinkering took place) it would take a long time to start but when started it would run very well, pretty quiet, and with very little smoke. Now this isn't the case (although we'll see tomorrow if it starts quicker). Two things: anyone got any ideas?? Also, does anyone know of a BMC specialist in the Oxfordshire area that could come and give us a second opinion? I trust our usual mechanic, but maybe he's missed something obvious on this occasion?? I can't remember all of the things that our mechanic has done offhand, but I probably would do if reminded. He basically worked through the starting problem bit by bit, starting with obvious things like glow plugs and moving right through to injectors...
does anyone have a definitive answer on which of the two compact washing machines (zanussi 1301 or candy aquamatiuc 100f) is best in terms of power usage, performance etc?? we have a mastervolt mass 12/2000 2kw inverter. could this cope with either of these machines?? we are also in the market for one of these...
HI All, We are thinking of replacing our old and slightly shabby cratch cover. This one was hand made by the person who previously owned the boat. It is made from a big piece of most likely fairly cheap vinyl/plastic. We were thinking of going for the same stuff to keep down costs, or maybe someone knows of a reasonably priced alternative? If we take the old one off, measure the maximum area, but a piece, then overlay one on the other and cut it to size (folding over and gluing to strengthen hems/seams), then it shouldn't be that difficult, no? Anyone had experience doing this, any advice etc?? And if anyone knows of a decent supplier that would be much appreciated. Cheers!!
- 3 replies
- cratch cover
- cratch
(and 1 more)
Tagged with:
calorifier/engine/collant system issue
silverbuttocks replied to silverbuttocks's topic in Boat Equipment
maybe i didn't say. i would like to emphasise, since i have fitted the back boiler and new rads these are all on a separate system and are not connected to the calorifier at all. they have been switched off at the taps and i have put a loop in that end of the rad system...- 16 replies
- calorifier
- engine
(and 2 more)
Tagged with:
hi, yes. i cut them actually inside the boat, about half way down. so no, there is no water being heated up by the calorifier, but there must still be water from the engine going round the actual element (sorry, don;t have the tech vocab for this!). so it seems like the water that was left has just vented. just seems odd that it didn;t vent out of the pipe to the skin fitting... i will run the engine again tomorrow and see what happens. is there anything you think i should do to be on the safe side? hi tony. guess i wasn't clear. i was saying that i definitely would NOT attach the engine coolant system to the rads/back boiler. The back boiler already has a pump and obviously this would be a bad thing. however, the hot water supply that used to go to the taps in the boat could be attached as these are a closed system that are not connected to the engine and do not have a pump (well, they used to be connected via the water pump on the boat, but i have disconnected them now.- 16 replies
- calorifier
- engine
(and 2 more)
Tagged with:
hi tony wow, this is getting confusing. i am not getting water, or steam, or anything from the red cap. i only see the steam in the engine compartment coming from somewhere either from the pipes where they go from the engine bay to the calorifier or around that area. it's only happened once and i didn't see exactly. i'm not sure about your last comment. do you mean that when the rads were working the engine pump supplied water to the rads?? this makes sense as i have never found any signs of a pump. to clarify, this has been turned off (at the taps) since we have had the boat as one of the rads was knackered. if i get it back up and running it would be to connect to the loop of an existing back boiler with pump, in which case i guess i would need to connect the hot water loop to it rather than the old rad/engine water pump system (as then I would have two pumps and i would be pumping hot water from the stove to the engine!!). but i still don;t know why something is over-heating. the rads have never been on so it can't be that. in which case it has to be the hot water pipes that i have just stop-ended. but why would this matter?? should there be a loop instead on the old hot water pipes??- 16 replies
- calorifier
- engine
(and 2 more)
Tagged with:
hi everyone i expect i have been an idiot, but i did think about this for some time and can explain my reasoning! this is the schematic, if it works: taslim, i have indeed made a closed system, but this is why i thought it was ok. the water feed to the rads (on the left of the schematic) was turned off when we bought the boat as the rads were knackered. the water feed to the hot water system (on the right) has always been on though (but also linked to the paloma, so it didn't work well - the paloma is great now that it doesn't feed water into the calorifier!). but now i have closed it off by simply cutting the pipes (which works at the business end and we now have hot water). however i have not created a loop at the end of the severed pipes. BUT, i didn't think this would matter because we haven't always ran the hot water when the engine is running and nothing bad happens (the engine isn't overheating MtB - just steam coming from pipes going from engine to calorifier - i think!! i need to try it again and check). i realise that what was left in the two systems (rads and hotwater) would have nowhere to go, but the rads have been like that since we bought it with no issues. I thought that the pipe (one of the 1, 2 and 3 pipes on the schematic) that went to the skin fitting would just expel this as steam or hot water, but thinking about it maybe this is for overheating of the actual hot water element from engine. So, should I put a loop on the hot water system (on the right), but thing is there's no pump to pump it around so how would this solve the problem??? Or is there a way I can put the calorifier out of action until I decide whether to use it to supplement the back boiler???- 16 replies
- calorifier
- engine
(and 2 more)
Tagged with:
how do you add attachments to these posts?????? hiya. i haven't messed with anything on the engine side of the calorifier so that's not the issue. all i have done is block off the pipes to the rads and hot water system (the pipes to rads were already turned off). can't see how to add attachments to these posts- 16 replies
- calorifier
- engine
(and 2 more)
Tagged with:
sorry, not explaining it very well. but luckily, in an attempt to understand the plumbing a little better i drew a schematic of the calorifier plumbing which I will try and attach to this post. i will attach a photo of the engine and relevant pipework a bit later. basically there is a outlet and inlet from the engine to the calorifier (two of the pipes numbered 1, 2 or 3 on the schematic). the third one of these goes from the calorifier to the skin fitting. i have blocked off the pipes to the rads and the hot water system. hi. i don't think there's an issue with the engine or coolant system - it just started doing this since i blocked up the pipes to the rads and hot water. it's a BMC Thorneycroft 1.5- 16 replies
- calorifier
- engine
(and 2 more)
Tagged with:
vanette grill wont stay lit even with new thermocouple
thanks for that. i may just have managed that prognosis myself, but much appreciated nonetheless. and wotever's pedantry was rather amusing... does anyone know how to dismantle this or at least get at the part that usually goes wrong??- 10 replies
- grill
- thermocouple
(and 3 more)
Tagged with:
HI All, They're great boats, aren't they? The gift that just keeps on giving... and so, another year another set of issues... Over xmas hols i fitted new rads for a newly installed back boiler. I also finally sorted out our paloma plumbing, which was plumbed into the hot water system along with the calorifier (as one system, and therefore did not work properly, as the paloma would pump hot water into the calorifier!). But now both the rads and the hot water are not connected to the calorifier (i have put stop ends on both sets of pipes coming from it). When i ran the engine for three hours a coupe of days ago when I turned the engine off there was a hissing and quite a bit of steam coming from the engine well. When I opened it it seemed like it was coming from nearby one of the pipes going into or out of the calorifier. Am I being stupid? OK, I didn't drain the two systems that were previously plugged into it (but the rads have always been turned off at a tap new to the calorifier as they were blocked (hence new ones). But there appears to be also be a pipe going from the calorifier to a skin fitting in the engine compartment so I would have thought that if it was too hot then steam and hot water should be ejected from this? Could the hot water from the engine that heats up the calorifier element be getting too hot because there is no flow into and out of the calorifier to take the heat away? If the latter how can I block this off?? I might start using the calorifier again soon as I think I will connect up the rads again and have it feed in (with taps to turn off when engine not in use) to the back boiler-heated central heating system. Does any of that make sense?????
- 16 replies
- calorifier
- engine
(and 2 more)
Tagged with:
HI All, HNY! We have a vanette oven and grill. when we bought the boat in the summer we were told by the previous owner that it needed a new thermocouple. 6 months on and i finally bought one and fitted it! Sadly though it still doesn't work!! Bugger. It doesn't matter how long I keep the button pushed in, when I release it the grill turns off. Frustrating, especially as this probably means that the thermocouple i just pulled out was still working. Does anyone have any ideas what might be the problem? The thermocouple is new so nice and clean and no fat/oil deposits. The tip of it is in the flame of the burner when it is on. Not sure what else I can do? Cheers!
- 10 replies
- grill
- thermocouple
(and 3 more)
Tagged with:
washing machine and inverter/generator query
Thanks for that! appreciate your quick reply! bummer, i was looking at this gennie: http://www.ebay.co.uk/itm/IG-2600-Suitcase-Generator-2-6Kva-Kipor-IG2600-Pure-Sinewave-Digital-Generator-/320862118591?pt=UK_BOI_Industrial_Tools_Generators_ET&hash=item4ab4df62bf and hoping that it would run washer dryer with 2150w rated load anyone????- 26 replies
- inverter
- washing machine
(and 2 more)
Tagged with:
hey you lot - hope you are enjoying festive season... I am trying to re-ignite this thread... We bought a washer dryer but rather predictably the crappy Wolf generator did not deliver the goods. As soon as the machine started doing anything the generator threw a wobbly and the machine popped up an error message. balls! So, we are going down the decent generator route (rather than modifying boat - new alternator/inverter etc - cos we might be swapping her for a different one this coming year...). I'm aware of the nice quiet Honda suitcase gennies - are these the best?? Or are there other (slightly cheaper) contenders that will run our washer dryer (around 2100w) with nice clean electric power??...- 26 replies
- inverter
- washing machine
(and 2 more)
Tagged with:
