hi Tony,
you may well be right, the governor rod runs through the centre of the spring and pushes the lever to slow the engine down if it overspeeds.
the spring fitted on mine has so many turns (11 or 12 turns if I remember correctly) that there is hardly any travel of the lever before the spring is fully compressed (all coils are touching)
At the moment the engine speeds up quite noticeably then back to idle when moving the gear lever into neutral, for example you are creeping into a lock at tick over, pull the gear lever to neutral to coast the last few feet, the engine will rev up a fair bit then settle back to tick over .
which at the moment is a touch to low I think, should it be around 300 to 400 RPM ?
Not sure how to measure tick over either... some one said listen and count... ???
I thought of using an optical Tacho that I have for measuring model airplane prop speeds.. stick a strip of white tape on the fly wheel and "jobs a fish' as they say
