Excuse the idiot question, but:
My boat has a single alternator running of a Lister SR2
There is an indication light on the control panel that indicates when the alt is charging. When lit green its not charging, increase the revs, it goes out.
I've had the boat six months, when I first got it, it would only charge at high revs and then I'd ease the revs and it would still charge, but stop charging at idle. AT cruising speed my ancient ampmeter would show about 10 amps. Then it stopped charging at any rev speed. I tightened the belt, it started charging again as it was. I thought the belt tension was a bit much, ie only perhaps 5 mm on the longest length.
It's now stopped charging at any rev speed, the belt is already as tight as it can get, the belt is not slipping and the alternator is turning with no noise.
What I haven't done: Taken a volt reading off the alternator itself.
Found out what the alternator type is.
Does this sound like the alternator is knackered?
Is it worth taking it to a car electrical place or simply get a replacement?
Incidentally I have very low electrical requirements, ie no fridge, TV, etc. and an 8o w solar panel that keeps the batteries at about 12.9v (so far)
Thanks in advance for any help AF
