squarelips
Everything posted by squarelips
im talking about a solid plastic waste water pipe, but there is also gas pipes and flexibale pipes and even the outake from the boiler is has a huge gap around it. Its all been done terribly. ha ha but I thgink you are right that i can find skin fittings for each of them. thanks so much. and im glad you liked the heart
hey thanks for the replies everyone. So i am talking about the waste water from the sink. i dont have a pic and im not on the boat just now. but whoever installed it just cut a hole bigger than the pipe then slotted the pipe through and left it at that. I was a bit shocked in a bad way when i saw it. And Alan de Enfield you are totally correct in the concern of what else is done as shoddy as that. I only have mentioned the waste water pipe but it does seem every in/out point through the boat is done to a terrible standard and there are some serious leaks coming from the superstructure too. so any help or advice in dealing with making these joins watertight would be brilliant. I just mentioned the water one cos it is the worst. And the boat belonged to a friend of a friend and he said i could look at the boat and pay him what I think it is worth depending on what condition it is in. So I am not too worreid about finding all this work to do because the more work needing done the less im going to pay for the boat. So its all good. But I appreciate why yous would be concerned for me that I might have been ripped off if that is the standard the work is done to. Thanks for all your help everyone ha ha sorry i missed you for a love heart. just keep being interupted by my cat crawling all over my lap top.
hey everyone. I am working on a boat I just bought. And I am amazed to find that where the water outake pipe leaves the boat through the hull is totally unsealed. There is a gap all around the pipe of about a cenitmeter all the way round! So how would you recomend I go about fixing that and making it water tight? Is there anything like some sort of rubber seal to attach over the hole and feed the pipe through? If so what is it called cos I've been looking for something like that on google and not getting much joy. Or any other ideas or advice very welcome!! Thank you so much for any help or advice. Hope your all floating happy out there
Hi everyone, I am going to try to fix up the outside of my grp boat but I have never done this before and could do with a little advice. The previous owner painted it some wrong type of paint that has totally peeled off and is really patchy. I have taken as much off as I can but I think I need to buy some paint stripper any recommendations or guidance on how to do it? Thanks And also once I've stripped the paint would like to polish to a nice finish but I'm not sure what im doing? Any recomendations or advice to help me with my research would be mega appreciated! Like do I nneed to buy a polished? Or can I buy a polishing head for my angle grinder? And what compound would you recommend? Thanks for your help everyone. Any help at all to get s handle on what I'm doing. Thank you thank you thank you you wonderful boaters. X
Hi you lot, I have yet another question about my stove. im almost there. I have everything installed but the increasing adaptor is just sitting in the stove. How do i seal this up. the gap is really small and i bought some fire rope at 6mm thinking i could squeeze it in but it wont fit. Can i just fill it with heat proof silicone? then fire cement round the outside????? or shouldi wait and get smaller gage fire rope? What would yea think/recomend? Thanks for all your help. this forum has been incredible for helping me learn how to install my stove safely. hope you are all staying warm out there x
drilling holes in cast iron stove legs???? any help?
squarelips replied to squarelips's topic in Boat Building & Maintenance
Hey keeping up! That sounds like a much better solution. Was worried it wouldn't pass a safety inspection. But if yours has passed then i think thats what i'll do! Thanks for your help!! Totally solved my problem and made the job simpler more than more difficult!!!! Thank you you are amazing x -
Hey boat folks, I'm installing my stove and according to the guidelines the stove must be FIXED FIRMLY IN PLACE. In CAPS so it must be important. My stove is on legs that just end in a stump and i don't know how to fix that to the fire board and plywood beneath????? Any ideas? The only solution i can think of is L brackets on legs then screwed into the base. But this will require drilling holes into the legs of the cast iron stove. Any advice on how to do this???? What type of drill bit? How difficult it is? People are saying to use cutting oil? but i don't really know what that is? I only have a fairly weak battery drill will i need something more powerful to get through cast iron? Or is it better to take the stove somewhere and get it drilled for me. If so would you know where i could go in london? Thanks for all your help. You people save the day for me on a near daily basis these days. thank you x
thanks for the help you boating beautys. I think your suggestion chewbacka is super more complex than i am needing/capable of. I might try that Isopon filler graham. Thanks for the help yous lot. If anyone has any better /easier solutions or advice on using Isopon filler please let me know. I'm looking for a quick fix because it's not really a big problem anyway. Even fixing it in the first place is maybe a bit of over kill. thank you for your help everyone. x
Hi everyone, Any ideas the best way to plug up a hole on my grp boat? It was previously the outake pipe from the sink, It has a hard plastic casing round it for the hose to connect to so I'm looking for some thing that I can put in there like a type of putty or something that will block it up. I'm building my stove there and don't really want to build a wall over the hole without making sure that it is sealed. Thanks for your suggestions and wisdom. Thank you x
Hi you lot of fantastic boat freaks, I am finally putting my stove together. Going to tile the surrounding area this week. Do i need any specific type of heat proof tiles? or just regular ceramic tiles do it? Also any heat proof adhesive or anything? I have 25 mm calcium silicate board with 10mm air gap behind.. Any one know if i can affix tiles directly onto calcium silicate? Thanks for any advise you got for me. You people are beautiful x thankyou
Masterboard under hearth when installing stove?
thanks blackrose - really helpful! I'm slowly but surely getting there and learning a lot along the way. I found these guys https://www.thestonebakeovencompany.co.uk/shop/additional-insulation-materials/2-x-25mm-calcium-silicate-board/ selling really cheap 25mm calcium silicate but i gots a feeling the boards will be really small cos they dont mention size at all. so i might even be able to upgrade to 25mm masterboard! I cant wait to get this stove in and heating up ma little boat! Thanks for taking the time to help me out. Very very appreciated x -
amazing black rose! thanks for that advise. I was totally going to use wood offcuts to create the air gap. I'm really glad you pointed that out to me! I think im gonna get the 12mm masterboard and be done with it. That was really helpful of you. thank you x -
hey you lot - thanks for all your help and advice. still trying to figure all this out. thanks for your warnings too J R ALSOP it defo is hammering home the importance of doing this safe and correct but I have seen lots of grp boats with stoves and am confident i can do this safely. and dave payne where did you get fireboard for 30quid? im looking at masterboard from travis perkins here https://www.travisperkins.co.uk/Product/Building-Materials/Insulation+Plasterboard/Plaster+Plasterboards/Fire-Resistant-Boards/c/1500012 and 12mm is like 140quid. I cant even find 25mm masterboard. I am willing to spend the money if its going to make sure my boat doesn't melt! ha ha I still really cant think of a solution for how to fix my stove firmly in place. thanks for all your help. -
thanks murflynn - do you think because my stove is on legs it'd be safe not to put down master board? just 18mm ply and then cement board? under the ply there is another big air gap of about twenty cm down to the hull. thanks man un -
Hi all, I am trying to instal a stove on my grp boat and i aint never done this before so asking lots of questions of you wonderful boaters to try to keep me right. following these guidelines: http://www.soliftec.com/Boat%20Stoves%201-page.pdf 1 It is saying the surrounds should be made of 25mm masterboard but thats SO expensive. And at a boatyard they said 12mm would do it. Who should i trust? 2 and for the hearth under my stove. i'm worried that the master board will be really brittle under a heavy stove with the 10mm air gap? Is it cool to just put lots off cuts under to keep it sturdy? 3 my stove is on long legs maybe 20cm. do you think under the hearth that will allow me to use less master board under the cement board?? 4 - how would you suggest that i fix my stove firmly in place??? it must be important because they've written it in bold! Thank you for any help you can give me. Sorry if these questions seem really simple but i've never done this before. So thanks for your patience.
stove flue going out through canopy? bad idea?
Wow thank you for so much help and ideas. Really going back and forth on this. I think from all your advise it maybe isn't too hot an idea (pun intended). i can cut a longer flue with more of a bend in it and take it away from the canopy. But thank you all for so much help in thinking this through it was really helpful. I really love the community we have on the water where people have to learn new skills outside their particular knowledge and are helped out by their fellow boaters. Also big thanks for everyone staying so kind and reasonable despite that guy saying I shouldn't live on a boat. maybe he's right but ive been living on one for four years so its a pretty prolonged mistake i'm making. ha ha ha. I'm sure he was just trying to be funny but it's cool that everyone on this thread embraced the fact that we all need to ask for help with stuff at times and its how we get cleverer and develop in the world. Sharing what we know. Thanks for all the help and being the beautiful boaters you are x -
Hi everyone. I am trying to install my solid fuel burning stove on a norman river cruiser. Because of the moulding of the boat i have been trying to measure a chimney at an angle because straight above where the stove will go leads into the centre cockpit. But last night i had a revelation idea and wondered if i could take the flue straight up through the centre cockpit and up out the canopy???? Is it possible to take the flue through the canopy safely? will it be too hot or a fire hazard? what would i need to install in the point where it goes through the canopy??? thanks for any help! x
Hi you lot, I am installing a stove on my grp little boat. I have decided the only sensible use of space is to cut away the moulded seating area and put the stove in there. i just want to cut away about 30cm of the bench. i would like to make as nice a job of it as possible. do you think i can just use a jig saw and buy a bunch of blades? any tips for cleanly cutting into fiberglass? and then im going to have a big hole which i was just going to block back up with wood and masterboard. or is it simple enough to re - fiberglass? I am aware of how vague these questions are but any help would be great. thanks for all your help everyone . stay warm out there on the water x
Canopy frame repair for a norman river cruiser? help?
Thanks tony. I just have a friend who is going to make the canopy for me so i just need the frame repaired. Do you know where i could get this done?? thanks x -
Hi all you wonderful boat people, I have recently moved onto a little Norman conquest River cruiser (moving on from my narrowboat) and the canopy needs repair. I was looking for any advice or help i can get really. Such as how standardized are the frames? There are two metal bars holding the canopy up that are bent and i want to replace. Can you recommend where i might find replacement bars of the same size? And one of the joints connecting to the boat is missing and need to source one of them too. Or is it a case of i need to take it to a boat yard to get them to custom make new frame bars for me. Thank you for all your help. Hope the autumn is being beautiful to you whatever waterway your on x thank you
Hi everyone- another day another boat question! I have a little grp boat and the guy i bought it from painted it really badly and the paint is all peeling off. He told me i should scrape it all off and re-coat it to protect it from the weather. But another guy said to me you dont have to paint the grp superstructure with anything. that i should do the opposite and buff it up with an angle grinder. what would you advise? I am not talking about anti fouling i'm talking about the above water section. I am more interested in what should be done to protect the boat practically than cosmetically. Thanks for all your help you beautiful boat folks. x
