Everything posted by Still-waters
Water Explorer - to shut down at end of 2022
Still-waters replied to stuart's topic in Waterways News & Press
Thank you for a very helpfull number of years of use.Wiill miss this as none of the alternatives for us are match up to what you had done. Keith -
such a shame, as I have used it for many years. Pleased the programm will still work for a while athough appriciate the limitations. for me its been the best navigation app/programm available. thanks -
Best Wifi Option to choose for my canal boat?
Still-waters replied to CanalBoatEnthusiast's topic in Boat Equipment
Hi if its any help I have an Archer may be a "400" version. works very well .Will work in good reception areas without connecting to external aerial although I do most of the time have a cheap ebay one connected most of the time. -
Understand Lock gate at Missenden now mended so were planning our escape following an interesting protracted stay on what is a loverly Canal with character .
Hi Lady G, were in similar situation. We were due back on the Trent tomorrow. We did only do 1/2 the Chesterfield as were keen, in light of CV19 etc, to get closer to home soon (no chance now!) also the upper part was closed then. So we plan to take "advantage" of the extended stay to now venture as far as able then we hope back when the lock is sorted. We were also were considering the coal and diesel situation.
https://www.jannel.co.uk/contact-us.html Shobnal marina always been good for us, just a interesting reverse in!
And bang went one of our porthole windows this week. No evidence of damage prior to this, no sign of vandalism nor a particulaly hot day. Just went into many small pieces. Guess this happens occasionally.
very similar experience few days ago on T&M near Swarkstone. Basically just food taken and bit of damage from forcing entry. Police attended. Just an alert for others in case they are still in the area.
believe the flight is now open again.
Ultramax Lithium batteries
Still-waters replied to Still-waters's topic in Boat Building & Maintenance
From the original Question based on the replies some contact with suppliers/distributors and further searching, I have decided not to venture along the drop in lithium route. The problems re low temperature charging and reading that the life span of the batteries may (unless very very carefully managed,) in reality be far less than advertised have strongly influence the change of heart. Seems to me that the drop in versions for narrow-boat usage have a bit to go yet till they are a true drop in replacement. -
Thank you for the wide and thoughtful exportation of this. I see some similar discussion fro the RV world although most USA focused. The you-tube video is a good coverage also. I do plan to raise some of the issues highlighted i.e. the charging aspects with the company who supplies these. My set up is a bank of 5 for the domestic: beta 43 with the higher powered 12v alternator for the domestic batteries, 3 x 110w solar panels with a MPPT and a sterling 3500w inverter/charger (which can be adjusted for the charge rate- looks like the Gel setting is closest) So as current bank is fading but not yet gone have a bit more thinking time. -
I am looking at replacing our deteriorating normal lead acid battery bank with Lithiums. I have discovered the Ultramax LiFePO4 Battery: 12V 100Ah https://www.batterymasters.co.uk/lithium-phosphate-batteries/ultramax-lifepo4-battery-12v-100ah-replace-sla-12v-100ah-with-4-times-cycle-life-lighter-weight-charger-included.html Any experience of these or ideas would be welcomed. I have some caution in progressing as they are cheaper than the other similar lithium replacements available. thanks
Update on 02/11/2016: The boat has now been removed and the lock has been reopened again. from CRT
Thanks amber appeared latter yesterday but now in same situation with 8 others at Junction lock at start of the river Wreaked section .
At Belgrave lock level still at red but has fallen some boats are moving others like us still waiting. Not sure if best to move or to wait.
For info River Soar at Belgrave lock area back in the red so await to see if falls in the morning.
Morse chimney deck plate
thanks much apriecated -
Hi I'm currently fitting a Morso chimney deck Plate supplied with the with the purpose made Morse chimney system (part number 62908511). The instructions say "Locating the deck plate - Use a suitable non silicon based water tight sealant on the deck of the craft before locating the deck plate." most sealants for simiIar situations I seem to find are silicone based. What would be peoples suggestions??, I suspect this will not get very hot as is an insulated system. I have used Sikaflex®-EBT in other setting do you think this is OK for this job? I thought i had seen this question in a previous topic but I failed to find it when searching so apologies if already covered previously thanks Keith
Thanks for sharing your thoughts and experiences. On balance I think I will go with the manufactures recommendations. Cheers
Just close to fixing in a shower tray, the instructions say to set it on mix of fine sand and cement (even on ply) to cover the total area of the tray and not to use silicone, foams, mastic insulation compounds adhesives as an alternative. What are others experiences. I appreciate the instruction relate to a domestic situation and not sure if this is directly transferable to the narrow-boat environment.
Hi I note its the 75lt CALORIFIER that has 22mm feed and outlet for the domestic water whilst the 55lt version has the 15mm so i guess the choice of CALORIFIER is the influencing factor? so addition views on best CALORIFIER size?
Just to revisit this as I am about to plumb in the water system. I have used 22mm for central heating main pipes (15mm reducing T's to rads) and was planning on 15mm for domestic water hot and cold. The calorifier am looking at appears to have 22mm feed for the hot water. So back to the original part of this thread should I use 22m or 15mm for cold down the boat (40ft length of pipe) and ?same for hot water? thanks keith
Keeping a wet edge and best Laying-off brush
thanks for the guidance, will give the easy flow a try once the weather is more favorable. -
Painting a boat outside is a challenge, trying to find cool dry days with not too much sun and not too much wind. The edges between areas painted seem to dry very quickly and this makes laying off very difficult. Any Tips or tricks? are there any additives that help inhibit the drying time that don't interfere with the paints properties. Also any laying off brushes to be recommended? I'm applying the paint with a roller and then laying of with a two and a half inch bristle brush. Sorry I do not have the luxury of being able to paint under cover or to be able to pay someone ----so trying to do the best I can.
Hi just finishing tapping lots of holes in the shell for Mushroom vents, ventilation grills and fender hangers. Do these screws ever vibrate loose after time and if so is there a need for "loctite" or similar, Conversely is there a risk related to the threads rusting and should the screws be greased. Or should i not worry and just leave as they are. I am using A4 stainless steel screws and not using brass fittings. Thanks
