Cas446
Everything posted by Cas446
Use proper heat resistant adhesive. https://shop.vitcas.com/vitcas-heat-resistant-tile-adhesive.html
Summit closed and Cobblers lock now failed. At least 30% of the locks on the east side are in a poor state and could fail at any time, most of the locks on the fox hangers flight only have one paddle.
The K and A Bradford on Avon and beyond..........The reality please
Cas446 replied to Uptonlaunch's topic in General Boating
There are a huge number of hire boats from below Caen Hill to Bath, so the issue you will have is other hire boats. You will find moorings at Bradford and Bathampton and if you arrive early afternoon at the top of Bath, so plan to go onto the river and moor at Avon Steet. Also do some of the river and return to Bath. If you don't like other boats you'll hate it, and you will probably get shouted at to slow down regardless of how slow you go. However if you enjoy looking at boats that are different in many unique ways and mixing it with other boats (I.e. like the Llangollen in summer) you will enjoy it. Enjoy. -
..and you can also use engine heat to heat the radiators when you are on the move. Free heat which keeps the boat warm during the day. Obviously only useful if you intend to cruise and avoids flue smoke in the face.
Adding corrosion inhibitor to central heating circuit
Cas446 replied to Col_T's topic in Boat Building & Maintenance
On one of our radiators I installed a drain valve on the radiator, so I can isolate the one radiator both sides and drain it down - then refill with 25% mix. I do this every year, avoids a full drain down and refill, but keeps the inhibitor up. I have a pressurised system hence header tank not an option. -
Then the above should have been your response, not your cheap jibe for a rather inappropriate laugh - it degrades a useful thread. I let my kids take their jackets off when inside the boat, that's all I was saying.
Nice..
If you are fitting kids out, then make sure they can operate the buckles themselves. Arriving at a lock and then spending 10 minutes helping the kids get their jackets on does not make you very popular. This time of year there is no way you can expect them to keep them on all the time.
You would introduce the policy slowly by winding up tenancy periods over a number of years, to gently weed out small private landlords, with less buy-to-let demand the house market would correct. There would still be rented accommodation, it would be owned by rental companies with long term interests. The main issue is that it is owned by the wrong people with the wrong interests. These private interests are damaging, a little bit of government interference is needed to correct.
Absolutely, house ownership is good, buy to let is distructive. As per other countries, tennets should have the legal right to a 10 year tenancy without no fault evictions. This would discourage most private landlords. The ridiculous situation of tenants having no security and landlords being exploited by serial defaulters serves no one.
Heavily considering boating, but i dont know if im ready.
Cas446 replied to Minimal's topic in New to Boating?
A house in the country is the end goal, not the start. To get there you need to use your earned income wisely. Financially secure people who earnt their weath didn't start with a house in the country they start with an ex-local authority house in need of update in some dump. I was next to the M6, we only had peace and quiet when there was a crash on the motorway. Every town has an affordable area, buy one, do it up a bit, bank your mortgage payments, 3 years move and repeat. In 10 years you'll have a decent place in a reasonable area. Then you can refine your goals, and make those all important life choices without being poor, I.e. rent the house and live on a boat. If you use all your savings to buy a boat you will be curtailing your life choices, everything you own will be in a depreciating asset, there will be no way back and you will be poor. When you are fit and active this may not be so bad, but when you get that little bit older, or have some health issues you will be screwed. The one bit I do agree with, avoid renting when working. -
Check that the webasto fuel pump rubber mounting is still fixed in its intended position and that the fuel pump or its piping/hoses are not making contact with anything else, I.e. the hull.
Railway bridge repairs under way to link Gloucestershire canals
Cas446 replied to Alan de Enfield's topic in General Boating
Any idea of the timetable for lifting in the new bridge sections? -
Byron Bay is so last year... bridge 173A aka Meadow Bridge K&A is the place to be on a late summers afternoon 🥴.
- 166 replies
Yes be careful, alcoholism and drugs is an unfortunate reality. You may like to wait for the summer as they seem to be a little less aggressive, although you will then have to suffer the bongos.
- 166 replies
Buy a hand drill mounted pump and two bits of old garden hose pipe. For the hose from the engine to the bottom of the skin tank, take it off at the engine end. Catch what comes out in a bucket, then feed the pump hose down the engine hose to the bottom of the skin tank and use the drill pump to pump the old coolant into a container. Takes all of 10 minutes and minimal spillage. Then change your coolant hoses for new and refill.
Recommendations/advice needed: get yale locks fitted?
Cas446 replied to A Mad Belgian's topic in Living Afloat
When these bolts are extended in the locked position, can you manually push the bolt back in, or is it locked in position? Thanks. -
The webasto reconditioners sometimes crank up the CO2 adjustment setting. They do this to ensure that the unit does not coke up, as they have no idea what exhaust you are going to fit to it. The result is a very noisy unit that runs inefficiently - but it will run through their 'warranty'. So if the fan is just running very fast as opposed to being knackered using the software may help, as you can adjust the setting, but it's trial and error, and you may have a knackered fan.
These are the car type ones, also good and low cost. Hose connections. https://www.ebay.co.uk/itm/For-VW-Jetta-Golf-AUDI-A3-Passat-SKODA-Auxiliary-Cooling-Water-Pump-1K0965561J-/124774001747?mkcid=16&mkevt=1&_trksid=p2349624.m46890.l6249&mkrid=710-127635-2958-0
I use a thermo top V from a jaguar s type, £25, it does not have onboard water pump control which is ideal for me as I use the same water circuit via a heat exchanger for waste heat from the engine so control it with a simple delay drop off relay circuit. The low voltage cut off is set at 10V so no issues, BUT you cannot just use a contact to start it, you have to use W-bus so I bought one of those webasto oval timers from Russia ebay. Alternatively buy the same unit from a Land Rover Discovery for about £45, these have on board pump control, (however do not buy the TTV EVO, as you cant start these from w-bus). If you search around ebay you can also get one with the fuel pump thrown in and look for one with the plugs on and loom cut so you don't have to buy plugs. Looms are available from Poland via ebay but postage cost is high, it is simple to DIY just extend the cut off plugs. There is a guy on ebay who sells a home made W-bus interface card, search for a seller called 'onlywithpaypal'. I have used one of his pcbs for my hot tub for a few years now. Buy all the other bits you need from mvheating.co.uk. and if you need any plugs have a look at the shop on the Land Rover DISCO forum which is very well priced. Great little project. Obviously I did all mine a few years back, but I doubt much has changed.
The 'mains' water pressure can be readily provided by your water pump with an accumulator. However as per the manual you need an expansion vessel as opposed to a header tank, the advantage being it can be positioned low down in the boat.
and leave the ground paddles open as you exit so that water can get past.
You should also have an expansion bottle on the hot side, if the expansion bottle pressure has dropped below the pump cut out pressure it will be acting as a second accumulator on the hot side only (depends on where the NRV is located) has your calorifier PRV been dribbling recently?
