James Owen
Posts posted by James Owen
The works currently being undertaken involve the building of a new road across the adjacent field, there is slow but steady progress being made.
29 minutes ago, Stroudwater1 said:
This weekend I gather I t looked like just one hawthorn tree thats uncut (quite a large one). This is pretty much over the navigation though it’s still navigable with canoes/small boats to the original slippage. All the rest of the wood in the whole slippage bar roots have been removed.The only possible further slippage is over some of the gabions but not really into the canal. I had thought that occurred when the rest of the slip had taken place?
It doesn’t look like anything much has been done with any of the spoil. I pity the narrowboat hire firms.
You're absolutely right, I must have imagined what I saw earlier.
There's been a fair drop of rain recently, this has resulted in more trees down over the cut now and further slippage spilling over the towing path and into the water.
26 minutes ago, tree monkey said:
Or as I suggested it's a complete waste of time and resources, if it was an 'eco worryers" issue it would be stacked on site
There's very little available space along that stretch to stack anything, least of all several tonnes of felled wood.
Notwithstanding that many dossy boaters would then help themselves to a few logs, creating significant mess and further damage along the way whilst posing a risk to themselves and the surrounding area......best to take it all away.
I've worked on and rebuilt a few of these boxes over the years Chris, once you get here (Brinklow) I can take a good look at it and make the necessary adjustments.
If you're not confident on making the bottom road trip without first looking at the box I can probably get over to the Cyprus, tail end of next week if that's any help?
2 hours ago, Hudds Lad said:
There was a vid posted by Narrowboat Spudley on YouTube where he walked down to the slip, looks like quite the job
Found it...
It's a fair bit worse now too...
There's a further slip where the gabions are which has now blocked the towing path (lucky for the Spudley fellow he wasn't there) although the navigation at that point isn't affected.
In itself not the greatest issue but it does highlight the instability of the cutting and the resulting hazards the contractors will likely face while working.
I can see the bottom road getting a fair uplift in traffic for the foreseeable unless that's closed as well....
What are you looking for?
If anyone is interested (and I don't mean the usual negative, doom mongers on here that pick fault with everything) there is an opportunity for the right person to acquire the Gort.
It hasn't been advertised yet and I by no means claim to have any 'inside knowledge' but I believe the current owner has very recently decided to sell up.
8 hours ago, stagedamager said:
yes I believe so.
That would make her 69' 9"?
11 hours ago, stagedamager said:
I'm aware of Ash, but she is now 9 inches shorter.
Shorter than the original shortness?
6 hours ago, magnetman said:
Nice job on the swim.
It must be a very limited market. I'd want to see a black canvas over the front section of the cabin with some nice cotton rope work.
I think that was probably the intent, but with the canvas going forwards from the conventional cabin shape to the cratch (once built of course) but also providing a section that was watertight and connected to the main conversion??
3 hours ago, Derek R. said:Nice swim work on HYDRUS, but that awful ersatz 'dog kennel' as a cabin extension defies belief.
The whole boat look almost artificial. Might as well be a 'new build'.
Maybe, yes...but a 'new build' fully riveted hull, which is correctly proportioned and topped with engine room and back cabin in an 'as built' style with an additional sympathetic conversion..you couldn't commission that level of 'new build' for the same price now?
2 hours ago, magnetman said:While we we are criticising it I also think the guard irons are too thin.
They look like two inch guards to my eyes.
I'm surprised the Hydrus hasn't sold yet, there can't be many boats of that standard available on the market?
- 1
10 minutes ago, stagedamager said:
Chiswick?
Fresh horses!!!
11 hours ago, zenataomm said:
It's very easy to tell the difference between the Fuller twins.
One is handsome and the other isn't.
I was once told the easiest way to tell which is which was to look into their eyes... Roger's were ££ signs 😁
23 minutes ago, alan_fincher said:
I'm not sure I think that is the answer being given.I think it is being descried as a Ruston box, internally very similar to a Lister Blackstone 3G, (but not actually a Lister box).
Whether internal parts from one can be used for replacements in the other has not so far been stated.
Even with very common Lister Blackstone boxes I'm not convinced spares are always commonly available. Both my Blackstone boxes have at times relied on second hand part to effect a repair.
That's because you ask the wrong people 😉
5 hours ago, Jeremy G said:
A noisy ahead gear will, as Tony says, be failing/worn reduction gears and I can probably hazard a guess as to the reason why.
As mentioned, they are straight forward to repair and most parts are either obtainable or makeable. The only part I had to make on the last one I rebuilt was the main shaft itself but that box had really gone awry 😀
It's a Ruston's version of the 3G Blackstone box, dissimilar casting/housing but near identical internals.
They're straight forward and easy to work on although the OP doesn't mention what the "problem" is...
Yeah I know but I'm after a genuine marine version 😊
13 hours ago, stagedamager said:
Nowt wrong with an AS. Much nicer than a common Lister....... 🤣
Exactly, I want the AS out of the Anson...
12 hours ago, Peugeot 106 said:
Please explain further. Have you had bad experience?
Not a bad experience per se, they used to be rather helpful and keen to go the extra mile. These days they're a bit 'Sleeman and Hawken' -ish...fine if you have a part number.
On 04/07/2023 at 11:26, SiFi said:
.... how is their reputation these days?
Very much depends upon what you're after?
Specialist Surveyor for 1900 era Dutch barge. Serving Oxford
in History & Heritage
Darrell Broscomb is based near Oxford and has plenty of experience with Dutch Barges.
From memory I think he also lives on one??
www.dbmarinesurvey.co.uk
A thoroughly nice chap and knowledgeable too.
