Days Won
22
Everything posted by David Schweizer
Historic Boats for sale online
David Schweizer replied to alan_fincher's topic in History & Heritage
If you are referring to the engine, it certainly was not a steamer in 1967. We met up at the Leicester IWA Festival where Binky was very proud of his "new" engine, which he claimed was the most powerfull engine fitted in a narrowboat at the time. The Festival Organizers were organizing Tug-o-war competitions and we challenged Pearl. Our boat, Pisces, pulled Pearl backwards along the entire length of the contest. What we had not told him was that Pisces had a 36HP V4 English Turner fitted, wich proved to be more powerfull than his 3 cylinder Bolinder. -
There was a converted narrowboat called Pearl, moored in Aylesbury Basin in the 1960's. It was owned by Binky Bush, who was one of the founders of the Narrowboat Owners Club. Is this the same boat? -
Over the past fifty plus years. I have used both types of windlass, and have always found that those with the head set at 45 degrees to the shaft seem to be more easy to use. I have no definitive answer as to why this should be, except that the shaft on the 45 degree ones are operating from the outside circumference of the spindle wheras the 90 degree ones are operating from inside the circumference. The bronze windlass I not my one, but it is identical to mine. Mine has nothing stamped on it, and I have to admit, I cannot see anything stamped on the one in the photo. The reason I describe it as a copy of a Harry Neal is because Lawrence Hogg, who commissioned them, told me that the pattern used was an original Harry Neal Windlass.
You beat me to it whilst I was adding the photo, and yes, bought from Warwickshire Fly.
I have five or six traditional windlasses, but tended only to use two of them, a Cast Bronze copy of a Harry Neale Windlass, and a chrome plated double headed welded steel windlass. Both have the head set at 45 degees to the shaft, which makes them more efficient to use.
After something like forty years of removing retailer's stickers from antique items made from wood, I can safely state that the best fluid for their removal is White Spirit. Simply dampen the sticker with White Spirit and wait a few minutes for it to penetrate through to the adhesive layer, then gently lift the sticker away. If it resists removal repeat the process until it will lift without any difficulty. Once removed, any adhesive residue can be easily cleaned off with a cloth dampened with White Spirit. If you have any doubts about the effect of the White Spirit on the paint, test in an area out of view first. I would be very surprised if it did not have side rails. I have never seen one without them, and their absence would, as you suggest, make the stool a very weak construction.
To which stool does that comment relate?
Can a sea going dutch barge sail on uk canal network?
David Schweizer replied to legepe's topic in New to Boating?
Ah yes, I remember it well, but there was no warning sign in 1968 when we took Pisces down the Lower Stratford, and got firmly stuck in one of the Lapworth locks. The water went down, but the boat stayed suspended in mid air, so we re-filled the lock, but the boat stayed firmly wedged. Strenuous efforts were deployed to release the boat, including tightening the hull chains, applying oil along the rubbing strakes, and the volunteer Lock Keeper's Land Rover working hard. All efforts failed to achieve anything until a large party of walkers arrived. With ropes attached to the rear dollies, and about forty people in two groups on both sides of the canal, and the Land Rover and boat engines both running hard, the boat suddenly popped out of the lock like a champagne bottle cork. Once clear of the lock, we had to reverse through numerous lock back to the junction before we could continue our revised journey. The Southern Stratford had not been re-opened very long and, having read the above post, I now wonder whether our experience led to the erection of the warning sign. -
Pedantic Point. I am intrigued to understand why the myth, started by BW, continues to suggest that the maximum width for all single lock canals is 6ft 10ins. Our former boat was 7ft wide and we managed to negotiate all the Central Midlands canals without any difficulty. The narrowest canal we experienced was the Trent and Mersey, which isn't really Central Midlands, and even then we had a couple of inches spare. -
what wood would to use in a bilge area.
David Schweizer replied to Samp94's topic in Boat Building & Maintenance
What a terrible waste of Lignum Vitaem, the hardest commercialy available wood known, and much prized by wood carvers, who use old Bowls to make Carving Mallet heads. -
True, but in reality, persistant contact between almost every type of timber and any ferrous metal in a wet or damp environment will cause some oxidization of the metal and some degredation of the timber. The ozidization is casused by water reacting with tannic acid, which is present in almost all plant life, but in higher concentration in some timbers, including Oak, Walnut, Mahogany, Red Alder, Sweet Chestnut, Western Red Cedar, and Douglas Fir. Apparently, bronze is one of the metals not significantly effected by tannic acid, and a person I know, who works on the restoration of old boats and ships, only uses bronze screws and nails for all underwater fixings, It may well also be the reason wby boat propellers are traditionally cast from bronzw. Definitely not Oak, it is possibly one of the worst timbers for causing oxidization of ferrous metals in a wet or damp environment. Traditionally the timber used in the UK for areas where it is routinely wet is English Elm. It can still be found in specialist hardwood yards, but predominantly in the north of England and the Scottish Borders, where some stands have survived, but it is extreemly expensive. -
Boat dwellers to be able to claim the £400 energy allowance.
David Schweizer replied to Alway Swilby's topic in Living Afloat
A friend of mine cruised continuousy around the system for most of the year, but based himself for a few months in the winter on an official winter mooring. He went to the Local Council in which the winter mooring was based, offering to pay Concil Tax, but they said there was no proceedure for him to pay, so he payed nothing despite attmpting to pay!! -
Actually Arthur there is a legal reason, residential moorings are required to have Planning Consent, conversely leisure moorings do not, hence the differentiation. When I was involved with our local Parish Council, we were consulted over the years, by the Planning Authority on a number of different planning applications for residential moorings. Each one failed when it went to the Planning Authority because, amongst other things, it was felt that they would remove leisure moorings in a very busy and popular tourist area, and there was no consideration given in the applications for the parking of resident's vehicles. -
Higgledy Piggledy sinks on the K&A
David Schweizer replied to Alan de Enfield's topic in General Boating
It is true that it doesn't connect directly with any other canals, but it has navigable links to the Grand Union Canal and the Oxford Canal, via the Thames, and with Bristol via the Avon, or (if you are brave enough) to Gloucester and the Midlands via the Severn The main reason for it's deliberate abondonment was trade competition with the G.W.R. -
The K & A canal did not "fall" into disuse, it became un-navigable because the Great Western Railway, who had owned it since the 1850's , deiberately abandoned any maintenance. It was in effect allowed to fall into decay, often encouraged by failure to repair damage. -
A bit but machine maufactured plywood has been in use commercially since the mid 19th century, although I believe hand cut ply was first used by the Ancient Egyptians. Three ply sheeting has been used in car manufacturing from the earliest days for lining the insides of door panels, usually covered with thin leather or leather substitute. I can well remember helping a friend search for sheets of original 1/8" birch ply when he was restoring the bodywork of his 1920's Armstrong Siddeley. Apparently even though it was almost identical to 3mm ply, and would be covered in rexine, metric ply would not satisfy the vintage car enthusiasts.
May I suggest that you aquire a copy of Tony Lewery's book "Flowers afloat" he features the work of many boat decorators including Dennis Clarke, Ron Hough and Frank Nurser, along with many others.
I'm not sure that it is appropriate to ask Dave's why he is confident that the stool is Frank Nurser's work, Dave has possibly the best informed archive of traditional painter's work in the country. As for Ron Hough and Dennis Clarke, whilst they were both trained by, and worked for Frank Nurser, they both have their own quite distinctive style and the table illustrated is quite cetainly not the work of either Ron Hough or Dennis Clarke.
Not neccessarily. Below is a photo of a plywood panel painted by Ron Hough in the 1980's. There is some deterioration of the timber surface, but regular light sanding and a coat of varnish has preserved it quite well.
I suspect we have to wait for Daniel and the other Mods to make a decision, As two of them haven't even visited the site for more than two years, don't expect anything to happen quickly..
I used to keep a daily record of the hours we spent travelling on the boat, which included miles travelled, number of lock/swingbridges, working water points, places we moored etc. It also included, details of fuelling and servicing. It was quite useful in estimating future trips on the same canals. I still have it in my bookcase.
If suggestions that a Wiki would be a digital compendium of information devoid of of personal opinion or influence is correct. I would be more in favour of one. I can see it's value for contributors who are regularly asked for the same information, requiring them to send messages with sometimes quite large attatchments. For example, I presume that I would be able post the Ellis Heatmaster Installation and maintenance Instructions.
Trying to learn some 'roses and castles'...
David Schweizer replied to ronnietucker's topic in Arts and Crafts
I find roses much easier than castles. My roses are reasonably competent, much influenced by Ron Hough, but my castles are more like something out of a Disney film!
