Gerkin6000
Gender
Female
Location
London
Occupation
Designer
Gerkin6000's Achievements
Explorer (2/12)
0
BBS standard - wiring behind walls
Gerkin6000 replied to Gerkin6000's topic in Boat Building & Maintenance
Mazing! Thanks for all the info, will have to digest slowly -
So from a very reliable source it's ok not to use conduit if you use double insulated twin flex cable. Theres more info but reception was bad so won't go into that. Thanks for all your helps 10 points to Paul C! -
Thanks people. We've insulated with Celotex boards so not polystyrene so wondering is it ok to touch that and the wood tongue and groove of the wall. It looks like its ok..? I think when we were looking into putting wiring in the ceiling there needed to be a 10cm or substantial gap (?) so not sure if walls are different. -
Hi everyone We're fitting out our boat and are deciding whether to run the 12v wiring outside the walls in conduit or behind the walls. Conduit would be great for access but expensive so I want to know if we run them behind does it also need conduit?/can the cabling sit against the insulation or does it need a certain amount of gap? I've had a look at the BSS handbook but its doesn't give much detail and cant get in touch with any of our sparkys right now. Got loads of work to do but am being held up by not knowing what to do first, walls or electrics.. I'd love to hear your opinions/thoughts/experiences/BSS knowledge.. Thanks in advance
which stove with backbolier for widebeam?
Gerkin6000 replied to Gerkin6000's topic in Boat Equipment
Thanks people, all very helpful, much appreciated. The stove just doesn't get hot enough and the are some not completely burnt bits in the morning. I'll check the bottom vent, I did think it was ok though, and we do clean out all the ash. We've tried different coals some are better than others (i'm not sure what they were). Will let you know if we succeed! -
Mooring around Waltham Abbey near road and water...
Gerkin6000 replied to Gerkin6000's topic in General Boating
which water point is this? and thanks will do prob going to do a reccy next weekend- 7 replies
- winter mooring
- road access
(and 1 more)
Tagged with:
Brilliant, thank you thats really helpful- 7 replies
- winter mooring
- road access
(and 1 more)
Tagged with:
Hi there, We have an Esse Montrose stove on our widebeam at the moment but as it won't stay lit overnight really need another. Unless theres a problem with the stove? The Flue is clear, not really sure what else would affect its staying power.. Anyway we think we need a bigger stove anyway and want a back bolier for 2-3 radiators. We have quite a few big windows. Was wondering what advice anyone might have on the subject. Thinking a Squirrel would be too small but I've read that other widebeams have them and its fine. Our boat interior length is about 56' (its a 68' with cruiser stern). Would be great to get a stove that's at the cheaper end of the scale but dont want to risk the same problem of it not staying in overnight. Thanks for reading
Hi all, Am wondering if anyone knows of any mooring spots around the Waltham Abbey area on the Lee that have road access please? Need to refit our electrics and find an accessible point where we'll be able to stay for a while on a winter mooring. Ideally need to be near a water point but can probably work around this. Thanks! Emma
- 7 replies
- winter mooring
- road access
(and 1 more)
Tagged with:
looking for a welder and electrician in East London
Gerkin6000 replied to chrisjh's topic in Boat Building & Maintenance
Hi Jools, Did you find an electrician in the end? I need one too! Emma -
Electrician needed in East London
we need one toooooo! Around the old ford area of east london. emmaware (at) live (dot) com -
Hello all, I was wondering if anyone had any thoughts on composting toilets... I'm considering getting one, seems like the cleanest most eco general best all round solution. Wondering how it might affect resale value compared to a remote tank pump out. And will I have to store my waste for more than 6 months to compost and do cold winter weather conditions make composting take longer? Thanks, bye
Thanks all, v helpful. vague height is because height will vary depending on how heavily loaded the boat is...
ah, I found this http://www.canals.com/canaldata.htm so just the draft and height to worry about now...
Thanks, yes I think this is the one, I'm aware it had been rebuilt, just seems to be a bit tricky getting exact measurements...
