gregich
Everything posted by gregich
It's took a while to get more pics due to it not being my boat but here they are. There's an offer of a Isuzu engine with gearbox but I thought I'd check out getting right gearbox first as this seemed easier to me on paper. The reality seems anything but atm. More pics that might help
- 25 replies
- ava2
- lister petter
(and 2 more)
Tagged with:
If i was to move the gearbox out the way and get some better pics, would you be able to tell what gearbox it was or wasn't or would it take detailed measurements etc. Any more monetary mistakes might just sap the energy out of this effort to put things right as my friend has lived without it for 2/3 years now. Maybe if i took a template of the housing face before purchasing and a close up pic of the 'gear' wheel. I have very little knowledge of gearboxes and the nuanced differences although i'd feel confident fitting one so long as i was sure it was the right gearbox as i'v done this with my BMC 1.5.. I'll have a look over the weekend..
- 25 replies
- ava2
- lister petter
(and 2 more)
Tagged with:
Hi Richard, sounds promising, how would I be able to confirm this is a PH2? Thanks Alec, I'll see what happens with Richard and get back to you when iv determined if the engine is indeed a PH2. It's been a couple of years so I'm tidying up an old mess tbh. Obviously that was my first question. Probably sold on by the conman. That would be my normal recourse but it's not my call so my hands are tied.
- 25 replies
- ava2
- lister petter
(and 2 more)
Tagged with:
Indeed, i was warned off doing it to my SR2 on a previous thread. The AV owner has already been ripped off nearly £300 plus the gearbox so money would be an issue too. She'll need a slice of luck to find the right gearbox by the looks of things.
- 25 replies
- ava2
- lister petter
(and 2 more)
Tagged with:
Thanks. She has a manual for the engine but not sure if that will mention the gearbox but i'll get her to dig it out. Where is he based?
- 25 replies
- ava2
- lister petter
(and 2 more)
Tagged with:
- 25 replies
- ava2
- lister petter
(and 2 more)
Tagged with:
Hi all, my friend has a Lister Petter AVA2 engine in her narrowboat but no gearbox. She doesn't know what type of gearbox it was as it was taken for repair but basically stolen along with a her money. Can anybody help with some info on the type of gearbox used with AVA2 engines or even better have a servicable one for sale?
- 25 replies
- ava2
- lister petter
(and 2 more)
Tagged with:
That's already in there so wouldn't need to change it, just the connection to the rest of the linkage.
It's not a minor problem, i wouldn't entertain the idea if it was. It's like driving a tank at a the winding hole and i hope to sell it in the next year or two so want it sorted beforehand.
Sounds similar to my set up. Could i replace the bar with some 25mm box section maybe 2 or 3mil thick?
The main lever coming off the gearbox shaft is a 30mm diameter solid steel bar stretching about 700mm, I'm pretty sure it doesn't need to be that robust :). You could chuck a hand grenade in there and it would still be intact. I'll try and take some pictures and see if some clever bod can't give me some pointers to improve the set up.
Genius 🙄 No machine shop here unfortunately, I will look into the LH150.
It's always been the same and has very little use really.
Sounds complicated although not beyond me and possibly quite expensive. It might be easier to redesign the leverage operating the gearbox. It's made from very heavy thick steel. I'm fairly sure it doesn't need to be that built to that spec to function properly.
Hi, i have an SR2 engine with an LM100 gearbox, i want to swap this for a hydraulic gearbox as the mechanism is very stiff and heavy and the only way to improve this would be to take the lever through the decking. I have a very dry bilge and would lose this if i do that so looking at hydraulic options. Is this possible and what would it entail.
I'm seriously looking into this, do you know anyone who has painted over it? And if so what was the outcome? I realise its meant to be the finished product but wondering if this would be possible as a black roof would absorb heat and not really my choice of colour.
1k!!! cough splutter. Thanks, this is probably what i'll run with, shame it's so pricey but hey ho.
I dont want to skin it again as i only skinned it 5 years ago, i'm looking for a more permanent solution. T&G matchboard is on the inside and 1in multi foil insulation on top of that, then the 3 layers of ply.
Thanks for the info, only the roof is wood and its very well insulated with 1in reflective multi foil & micro fiber before the 3 layers of ply so is unlikely to get very hot and also is 36ft long so heat would dissipate from directly above burner. I think i could possibly leave the sides of the roof (over 100mm depth) as wood and that would allow it to breath. Also there is some overhang on the cabin sides allowing more breathing. Food for thought.
Iv read that canvas was for tongue and groove and to allow for movement. Canvas was my original plan till i looked into it. Still open to it if it solves my problem. Wouldn't that be a bit messy and difficult to get a smooth finish without bumps?
My mate who built the roof recomended that when we replaced the old roof. I boat single handed though which means theres a lot of jumping on and off the roof at locks, would also need to store stuff on there. my worry is how it would fare with this after a few years.
I wouldn't say iv used a lot, the roofs only been on 5 years but taking it back to bare wood would be an enormous job by sanding and i would lose some of the wood to boot. it is possible that there is a remover for the sealants from Osmo so i'll look into it. Thanks
I'm looking into sealing a ply roof on my cabin, the roof is not leaking but some of the wood is darkening and it looks like water is getting between the sheets of ply (3 in total overlapping). I'm assuming that some of the screw holes are leaking and the joins between sheets as it took 10 sheets of ply to do an 11m cabin (30 in total for 3 layers). I'v been treating the ply with Osmo uv wood seal and Osmo decking seal once every 2 years and using uv resistant silicon every year on the joins to try and preserve the original wood finish. This was a tad optimistic/romantic as the wood has darkened in patches over the years and now i want to seal it properly before it becomes a big problem. Any pointers from experience welcome.
I can verify that this is not made up story and the guy has indeed had his engine head stolen and he did report it to a beat copper the next day who did nothing. He does not own a vehicle either so he is in a very difficult situation. The only way out for him is to fork out an awful lot of money to a boatyard who have quoted £6k to repair. Some of the replies on here defy belief. From a lack of empathy to downright nasty. [/b][/size]
