dreadnought
Everything posted by dreadnought
  1. hi,i`m at the stage of my nb fitout that i`m looking to buy a fridge,can any one on the forum recommend a good fridge for a nb, many thanks thanks for all the good advice, i`m now torn between a 240volt and a 12volt, with the 240 volt would you be able to run an inverta 24/7,if so can the forum recommend a tried an tested inverter, i`ll be using the boat for holidays and weekends,it`ll be plugged in to the shore line when in marina(home berth)thanks again
  2. apparently if one drops on you out of a tree,it can cause memory loss,
  3. hi,i`m at the stage of my nb fitout that i`m looking to buy a fridge,can any one on the forum recommend a good fridge for a nb, many thanks
  4. hi all, has anyone on the forum had any experience with replating a nb that has been sprayfoamed as insulation,if the replating were to come up to the waterline would all of the sprayfoam need to be removed,thanks in advance i mean overplating,replating the sprayfoam would come off with the old plate,sorry to not make this clear
  5. hi all, can anyone help me, i`m thinking of buying a new cooker and i`ve been looking at the statesman legacy because of the dimentions( 500x500) and was wondering if anyone has got one and what do you think of it, many thanks
  6. hi all, i`ve got glass fibre pothole liners for my nb and they are a little too deep, i`m looking at trimming five mill off, i`m not sure the best (neatest) way of doing this ,is there anyone come across this before, whats the best method to use, many thanks
  7. hi all,can anyone on the forum recommend a good lpg cooker, i`m looking for one that is 50cm wide x 50cn depth, i was going to buy the statesman legarcy but i`ve seen a couple of bad reviews, its a pity because i found one £200 quid cheaper than midland chandlers, new and delivered, many thanks
  8. hi all, i`m thinking of having a sofa in my nb, it will have to go opposite the squirrel stove and i`m wondering what kind of distance there should be between the fire and the sofa,many thanks
  9. hi all, i`m going to be painting the bare plywood panels above gunnels on my nb,can anyone on the forum recommend a good primer and undercoate,will i need to seal it first or go straight on with primer, any help much appreciated, cheers
  10. hi all, i have been wondering what will happen when my anodes on my nb need replacing, the reason i`m thinking about it is the fact that i have spray foam insulation and welding the steel that is foamed will be a bit of a no no, can anyone tell me of there experience dealing with this, many thanks,
  11. the tanks resting on plywood and the damp patch is comming from under the tank, i`ve checked for any leaks around the doors to rule out rain water,if its canal water then i`m in even more grief,if it was condensation what would be the cure,ventilation?
  12. its a removeable tank at the bow so it will be a right royal pain to remove,i`ve checked the fittings and there all dry,so it`s either leaking from the front of tank or it`s under the tank
  13. hi all, ive got a stainless steel cold water tank and it looks like its leaking is there a way of repairing it or is it scrap,is there any other options open to me,cheers,
  14. use an old hosepipe cut into about 3inch lengths, alternatively get hold of some old twin and earth cable and cut that up to use as spacers
  15. i`m airing towards carpet tiles now,why would you need access to the bilges apart from at the back of the boat (the lowest section)?
  16. hi all,i`ve been looking at flooring for my nb and am a little unsure of what to use,i`ve heard people say use laminate and then someone else will say you cant use it you have to use engineered flooring,the price difference is substantial , can anyone shed some light on this for me, will i be cursed forever if i use laminate, many thanks in advance i will be laying the floor onto a suitable underlay,ie, fibreboard,or the equivalent
  17. hi all, what type of adhesive would the forum recommend for sticking on bathroom tiles, basic ceramic tiles,i was thinking of using pu18, has anyone tried this or anything like it, many thanks in advance,
  18. hi all, i have a bilge pump with a separate switch,the idea is that as the water level risers in the bilge the float lifts and switches on the pump,great,but my problem is that the whole thing floats, has anyone any ideas how to secure the switch to the base plate in the bilge,many thanks.
  19. hi all, i,m fitting my water system on my nb, i have sited a expansion tank after the pump on my water tank, can anyone tell me if i need another tank at the calorifier , many thanks in advance
  20. hi all,can anyone give me any tips on fitting a car sterio into my nb,things to look out for and things to avoid, many thanks
  21. thanks for all the great advice again, i will be going down the sensible route and getting a professional in to install my lpg system, i may need some advice about my electrics though, what size twin and earth cable should i use for my 12volt system, Joking,
  22. Thanks for your input boilerman, but as they say on the apprentice "your fired"
  23. ok educate me, why not 15mm copper pipe for gas i`ve seen it used times many ?
  24. ok so whats wrong in using 15mm copper pipe for the gas!!i!ve seen it used in a number of boats with no problems,i`ve had two boats fitted with it, and no problems with the bss, so now i am confused
  25. hi all, i`m looking at buying a bubble tester for my gas system i`m installing on my nb,i see they come in two sizes, 10mm and 8mm, witch do you recommend, many thanks i`m using 15mm copper up to the gas locker, but not sure what to use to connect to gas, hence the question,thanks for the reply`s so far
