dreadnought
Everything posted by dreadnought
  1. hi all,i`m looking for some kind of plastic bucket come container that will fit under the stern tube in that little triangular section,that way i can keep the bilge pump in there and everything will be a bit neater,i was wondering if anyone has something that they have used and proved ideal,many thanks in advance
  2. compartment under the floor/deck semi trad,i thought soundproofing was soundproofing ?
  3. hi all, i`m looking for some good soundproofing for my engine room on my nb, any suggestions/recommendations please, many thanks
  4. i`ve got vision plus status 335, less than a year old with new coax cable to the signal booster box then on to tv
  5. i moor at shardlow in derbyshire,and once we left there to cruise to the llangollen basin we could`nt get a signal at anytime,so no tv for three weeks,i did`nt miss it but the mrs`s did
  6. hi all, just got back from a three week trip on my nb, couldn't get any service on my tv anywhere so going to have to upgrade my aerial so could i get some suggestions on what kind of aerial i should be looking at buying, many thanks
  7. hi all,when out cruising would it be ok to leave the inverter running all day, or just switch it on when needed,many thanks
  8. hi all,we are thinking of cruising to Llangollen this summer but not sure how long it will take,we set off from shardlow marina,near derwent mouth,has any one done this cruise from here?many thanks
  9. thats right what you say, but in mine you can only see about an inch into the bowman because there are pipes in the way
  10. when i take the cap off theres no coolant to be seen, so i top it up
  11. dreadnought
    radiator cap
    hi all,i have a bmc 1800 fitted in my nb,and every time i check the water level after cruising(when cold) i have lost water,about a pint,i no where its comming from i think,around the radiator cap there is a lot of rusty water staining like the cap is not sealing properly,do they fail ? should i get a new one,if so where would i get one from,many thanks in advance
  12. hi all,can anyone in the forum recommend a 12 volt solar panel kit thats within the scope of a diy person to fit, many thanks
  13. hi,can anyone on the forum let me no where i can get hold of flat paint in around 2.5.ltr quantity's, also in a variety of colours for applying to metal, all the tins i seem to see are around 250 to 750 ml size,many thanks
  14. keelblack is a produck you paint on your hull to protect it,it is relatively new so you may not of heard of it,hope this helps you
  15. hi all,just wondering if anyone on the forum has an update on how the keelblack is performing,cheers for now
  16. thank you chipskunk for your reply, ive been a liveaboard many years and a cc`r,so i no all about the pros and cons of boating and life on the cut i had a family member who needed to contact me urgently but was unable to so i thought i would ask the question about the signal booster, ps,try not to assume things about other peoples lifes
  17. hi all,can anyone suggest the best way to boost the mobile phone signal to make and receive calls on board, many thanks
  18. hi all,i`m looking at getting a cratch cover made and have come across titan boat canopies,they sound very good, there not the cheapest but i was wondering if anyone has had a cover made by them and were they happy with the cover, also has anyone any other recommendations, many thanks
  19. hi all, i was just wondering if anyone one on the forum would recommend spraying your nb engine with WD40,i no a couple of people who have done this and i thought is there any benefit from doing so, many thanks
  20. i`m going to show my ignorance now and ask what a cabin shaft is ? is it a barge poll with some kind of hook on the end ?
  21. hi all,after a trip out on my semi trad nb before Christmas i got a coal bag around my prop, i had a hell of a job to remove it mainly because of the access to the weed hatch,i had to crawl over a hot engine and somehow had to lift out the weed hatch cover at arms length,it seemed to be a rather simple job turned into a nightmare,so i thought about cutting a hatch in the back deck above the weed hatch to make it a lot easier to access the prop, my question is has anybody done this or does anybody no someone who could do this for me ,i`m in the notts/derby border area, many thanks
  22. we will be using it to cook simple food for mainly the two of us like burgers ,steak, sausages , and the like,going to be kept on the nb,
