bizzard
Everything posted by bizzard
  1. Pop Pop tube propulsion is safe and simple. Camphor chip is too.
  2. Providing there is no back boiler in the stove. You could drill a hole through the centre of the plate and place a length of s/steel bar inside the stove with a hole in the middle. A length of s/steel threaded stud and nuts or bolt and nut. Place the bar inside, place plate on it's hole in the stove with high heat proof putty around as a gasket. Poke the bolt or studding through both plate and bar, add nut or nuts and bolt up tight. Be careful drilling cast iron. It drills easily but be gentle it can crack like a carrot if ill treated. DO NOT CENTRE PUNCH!!! Just stick a bit of sticky tape over the spot to drill to stop the drill bit skidding.
  4. I spent a week sailing on the the Norfolk Broads in my GP14 camping on the bank at night. One early morning about 6am I was forced out of my tent because of the heat of the sun, at that time of the morning!!!. I was camped at Thurnmouth at the junction with the Bure. I needed to go to the bog so took my bucket and toilet roll along the bank a short way and sat down on it with pants down on the bank between two bushes facing the river. It was lovely and peacful at the time in the morning, birds twittering, fish jumping until suddenly around a bend right in front of me came a big cruiser going dead slow, why I didn't hear it, with folk sunbathing on the cabin top. I couldn't do anything it was too sudden. I couldn't do anything but just sit there like I was asleep accompanied by my bog roll alongside. I did hear em laughing.
  5. Acetylene is in the zest of oranges.
  6. Brown rice is the way to go, more nutricious but takes longer to cook. Some Malay customers of mine ate it all the time, wouldn't touch any white rice. The Chinese plefur blown lice too.
  7. Eating horse meat was quite common way back fost ww2. I remember visiting a mate a few doors along from us in the mid 1950's and he was exulting over that they had horse meat for dinner that night.
  8. Save energy. If you follow my instructions you could switch off your fridge during the colder months. Make yourself a cold cupboard larder which can be cold enough for a few days between shopping trips to keep fresh most stuff like milk, bread, meat, fish ect. I made mine by converting a very low down cupboard which is below the waterline outside. First of all have the cupboard with all it's internal walls completely separate from any other space, the back wall is the boats hull. I squashed flat loads old aluminium pie dishes which I saved for some time and stuck em all over the walls and ceiling if you like to call it that and the inside of the door, all stuck with dots of cheap silicon. It's bean wonderful, once or twice in mid winter I've gone a week between shops and nothing had gone off. Saved a bomb of gas that my fridge would have used, a similar saving would be had with an electric fridge 12v or mains.
  9. Porridge also likes a drizzle of rum on it. Raisins too.
  10. Pasta and rice, especially pasta,it holds moisture and helps to keep you irrugated especially in hot weather, dried fruit, prunes and Figs to keep you regular.
  11. The cottage there also runs off the generator, or did do, no mains supply.
  12. Playing on Smartphones is often the reason.
  13. I reckon that's it, or it would do alright. You can see the oil gallery bulge in the block casting with filter, that plug and the copper pipe take off all inline.
  15. Check for rain on line. Meteor RainRadar. Add your post code. You will see any rain, moving approaching.
  16. bizzard
    Truex
    Don't be nasty to Haza folks, she's trying.
  17. Remove both cables from the start battery before dealing with the starter motor or sparks may fly. You will probably need a socket and long extention to deal with the bottom starter nuts.
  18. Do you have jump leads, like the leads which folk use to jump start cars, ie battery to battery.
  19. Stop cock turned off in it's circuit perhaps.
  20. Speed bumps are mainly used on rat runs or short cuts through residential areas.
  21. And of course horrible low profile tyres at higher pressure than the old deep profile tyres make pot holes and speed bumps feel much worse. Also big luxury cars may seem to ride these quite smoothly BUT the suspension and shock absorbers are still going through hell.
  25. The gearbox dipstick is at 26 on that diagram. The gearbox holds about 2pts. If you have no dipstick drain the box of oil then fill with 2ts of 80/90 gear oil you can then make a dipstick marking the full mark with a stroke or two with a hacksaw. The reduction gear also has a fipstick and holds 1pt of the same oil.
