If you can, isolate the valves at each end of the radiator. Then, with a shallow bowl ready to collect any water they contain, undo the union coupling (the big nut nearest the radiator body). Water will come out - but only the contents of the radiator itself. Once empty, lift the radiator off it's brackets and take outside. You need a fair amount of water pressure, but hold the rad so it is upside down and fill from the rad coupling at one end until the rad is full. Then watch what comes out the other end - usually lots of very thick black water! One it runs clean, turn the rad the right way up, allow to drain empty and do the exercise again. Once this rad is re-fitted, proceed to the next one in line and repeat the process.
