SOLVED!!! Fed up with cold showers using my Aqua Jet pump I decided to have a go a fixing it myself. After all, if I sent the old one away I'd be without a pump so I'd have to buy a new one anyway. Just under a little paper sticker at the pointy end of the pump (I think it said something like 20psi) is an Allen screw which adjusts the pressure. About 2 clockwise turns on this with an Allen key and the problem is solved!! Great pressure and more than enough to run my boiler constantly and have lashings of hot water! If you decided to try this it will almost certanly invalidate your warranty (they'd probably try and wriggle out of it anyway) but it worked a treat for me and saved me about £50 on Ebay for a new pump.
