When I did mine I packed as much grease onto the shaft via the greaser turning the shaft by hand. Loosened nuts etc, removed the old packing and inserted the pre cut new pieces. Having re fitted and tightened the nuts {finger tight] I Tightened the nuts two flats at a time alternately until the shaft was just free and not binding.......I found that the grease was enough to hold back the water, just make sure you squeeze in as much as you can whilst turning the shaft...............not one drop of water spilt.
