Everything posted by Alan de Enfield
swapping wet batteries for AGM
How many times that as the norm you should be charging for 4 hours per day, every day, and thn 8 hours on Sundays !
I thought you had someone coming to fit the batteries you have ordered yourself - what's happened ?
Choosing a Mooring base
If a marina is always full with a waiting list, and the other couple 'in the area' alays have space I'd look very carefully at why. You have already been given a reason fr Caen Hill marina but the other ..........................
Boat licensing update and next steps.
I don't think that it's a secret - we'd all guessed from your posts over the years
I use Red Diesel at home for the machines (diggers, tractors etc) and have just been quoted £1.50 litre, based on a 1000 litre drop - thats with the 5% duty for off road use. (Same as boats 'domestic' rate)
You may have difficulties obtaining a mooring on the K&A - it is a very popular and busy section of the waterways. If you cannot get a mooring where you want and that then means you don't buy a boat - suggest you investigate availability of permanent moorings n the K&A before buying a boat. Our boat is 5-6 hours (depending on traffic) away from home, but that's the price you pay to be able to cruise 'nice' waters.
Boat access
Simples - lower the body down on a rope (as they do for mountain rescue when have to descend a cliff).
Reeves shells
I believe that a key identifying feature of Reeves hulls is the 'ramp' / winching eye on the stem - has yours got it ?
In your case the logic doesn't stack up. The justification is that CCers use more of the reources and 'wear out' more of the facilities than HMers (water, elsans, bins, lock gates etc etc) As you movements are a 'minimum' maybe you could apply to C&RT and get a 'discretionary mileage' range like parents with kids at school.
And, presumably reducing their income, despite soaring costs. Doesn't bode well - You cannot spend it if you don't have it coming in - so who is going to take up the slack ? - maybe, widebeams and CCer's ?
Buying at First Trip to Boatyard
- Buying at First Trip to Boatyard
You don't get 'electric shocks' from 12v unless you put your tongue on the terminals but - you can get loadsa sparks if you do not use insulated spanners (when loosening / tightening terminal clamps and touch the metal) , or, ensure you disconnect the cables in the correct 'order'. The only shocks you WILL get is the price of the "blue boxes" everyone recommends that you need.- Buying at First Trip to Boatyard
After 40+ years and 18 boats neither of the current boats are 100% right for us ...........................................- swapping wet batteries for AGM
I cannot see any retaining straps - it looks as if the battery is simply wedged in with celotex offcuts. I thought the batteries had to sit in a tray/box at least 50% of the height of the battery. Applicability – restraint against vertical movement is generally required. However, batteries may be secured by means of a cradle or framework sufficient to ensure batteries remain secure under any condition up to 45˚ to the horizontal. Recesses, cradles or frameworks extending to half the height of the battery meet this allowance.- swapping wet batteries for AGM
Can you not manage to swap it over for your 'spare' ? Or, have you already used your spare, without ordering a replacement in a timely manner ?- swapping wet batteries for AGM
You really are a frustrating person - you have been repeatedly told that you cannot charge (even new batteries) from 12v to 'full' in 2 hours. As a guide, you should be charging them for 4 hours per day and 8 hours at weekends and - yes, it does cost you money to charge your batteries If you don't listen to what people are telling you you will eventually get no hep at all.- swapping wet batteries for AGM
Or anything else !- Boat access
Yes - I do have some experience with NBs. If anyone wanted it, I'm sure a builder could accomodate a similar roof hatch lengthways on a NB, but, may have too strengthen up a couple roof the rooof-bearers/ribs. Could cause some problems with solar panel placement tho'.- What Three Words - For the dinosaurs here :)
Our local Air-Ambulance only wants 'Lat-Long' co-oordinates. They said they couldn't use W3W. I gave our post code, address and W3W to the 999 handler and she kept me talking - the Helicopter came over me and then started to descend about 2 miles away, I told the 'handler' who insisted they had arrived at my location, eventually told her to tell the pilot to go back up, head due East and look for my smoke flare, they eventually lifted off and were quickly with us We have had them out 5 times over the years.- Boat access
5 steps up/down centrally to both the rear cabin and the galley / dining room and front cabin stairway 'straight' and over 2' wide - you could slide a stretcher / coffin up or down them. Remember she is 14' beam.- Boat access
My cruiser has a roof hatch 6' 6" x 2' 6" (held on by 2 bolts and its own weight) that is removable to allow the engines to be lifted out. Engines are 2x 6 cylinder, 6 litre Fords.- swapping wet batteries for AGM
But of course - a battery "supply & install" person would be buying at "trade price" and 'selling' to the customer a RRP, this mark-up (as much as 30% in my day) is a part of his income for the job - if you are supplying the parts to him do not be surprised if his hourly rate increases to make up his shortfall.- swapping wet batteries for AGM
How will she know where you think she is ?- swapping wet batteries for AGM
If you cannot get to your batteries, you cannot see them, cannot even photograph them what are you going to order ?- swapping wet batteries for AGM
I have 200Ah batteries ( 6 of them) and they each weigh 53-58kgs (depending on brand) They are not a 1-man job to install especially if you are lying down and have to lift them into/out of a 'box'. If you can 'stand over the box' and get a clean lift then it is possible - mine are under the floor in the engine room and having given up trying to do them lying down, I lifted the floor panels up and lowered then into place with ropes. Are they 'big batteries' with both terminals at one end (the narrow end) ? They are Type = 625 270mm wide 500/510mm Long 240mm high Terminals at ‘front’ (short edge) with positive on ‘LH side’ and negative on ‘RH side’. 200-230 Ah Battery Megastore Tel : 01684 298800 Options for FLA : 2x Varta N2 Type 625, price £412.65, Weight 53kgs, Hankook Vented 70027, price £165.95, Ebay. weight 57.1kg 2x Hankook Vented 70027, price £319.00, 2x Hankook 70029, price £361.00, weight 57kg, - Buying at First Trip to Boatyard
